Error evaluating a 2D exact solution using User-defined expressions by subclassing
Dear Colleagues
I have a problem when evaluating the L2 error norm or when interpolating it by using an Expression by sub-classing, I share whit you the essential of the code that shows the error, thanks by advance for your help!
from ufl import nabla_grad, nabla_div
from math import *
L = Constant(48)
D = Constant(12)
P = Constant(1E3)
I = Constant(pow(D,3)/12.0)
E = Constant(3E7)
nu = Constant(0.3)
domain = Rectangle(Point(0, -D/2.0), Point(L, D/2.0))
mesh = generate_mesh(domain, 50)
V = VectorFunctionSpace(mesh,‘P’, 1)
class Exact_disp(Expression):
def init(self, P, E, nu , I, D, L, **kwargs):
self._P, self._E, self._nu, self._I, self._D, self._L = P, E, nu, I, D, L
def eval(self, value, x):
	self._P, self._E, self._nu, self._I, self._D, self._L = P, E, nu, I, D, L, x
	value[0] = ((-P*x[1])/(6.0*E*I))*((x[0]*((6*L) - (3*x[0]))) + ((2 + nu)*((pow(x[1],2)) - (0.25*pow(D,2)))))
	value[1] = ((P*x[1])/(6.0*E*I))*(((3*nu*pow(x[1],2))*(L - x[0])) - ((0.25*pow(D,2)*x[0])*(4 + (5*nu))) + (pow(x[0],2)*((3*L) - x[0])))
def value_shape(self):
	return(2,)
u_exact = Exact_disp(P=P, E=E, nu=nu , I=I, D=D, L=L, element=V.ufl_element())
u_ex = interpolate(u_exact, V)
The error:
File “exact_sol.py”, line 37, in
File “/usr/lib/python3/dist-packages/dolfin/fem/interpolation.py”, line 70, in interpolate
if hasattr(v, “_cpp_object”):
File “/usr/lib/python3/dist-packages/dolfin/function/expression.py”, line 432, in getattr
return self._parameters[name]
[Previous line repeated 329 more times]
RecursionError: maximum recursion depth exceeded
Fenics last release ubuntu 18.04 installed from source
Thanks!
There is a corrected code for Exact_disp , in Fenics 2018 and higher versions Expression changes to UserExpression.
You don’t need to set the parameters E,P, … in the eval since it is done in the __init__.
class Exact_disp(UserExpression):
    def __init__(self, P, E, nu , I, D, L, **kwargs):
        super().__init__(**kwargs)
        self._P = P
        self._E = E
        self._nu = nu
        self._I = I
        self._D = D
        self._L = L
    	value[0] = ((-self._P*x[1])/(6.0*self._E*self._I))*((x[0]*((6*self._L) - (3*x[0]))) + ((2 + self._nu)*((pow(x[1],2)) - (0.25*pow(self._D,2)))))
    	value[1] = ((self._P*x[1])/(6.0*self._E*self._I))*(((3*self._nu*pow(x[1],2))*(self._L - x[0])) - ((0.25*pow(self._D,2)*x[0])*(4 + (5*self._nu))) + (pow(x[0],2)*((3*self._L) - x[0])))
    	return(2,)
Thank you so much that’s running perfectly!!! :smiley:
