Problems interpolating a UserExpression and plotting it
Hi everyone,
I’m using macOS Mojave (10.14.6), miniconda, and FEniCS 2018 with Python. I want to define have an expression/function e: \mathbb{R}^2 \rightarrow \mathbb{R} which is defined as such that f(x, y) = 1 for x \leq 0.2, f(x, y) = 2 for x \geq 0.8, f(x, y) = 3 for y \geq 0.9 and 0 else. So I thought that this
N = 16
mesh = UnitSquareMesh(N, N)
class MyExpression(UserExpression):
  def eval(self, value, x):
    if x[0] <= 0.2:
        value[0] = 1
    elif x[0] >= 0.8:
        value[0] = 2
    elif x[1] >= 0.9:
        value[0] = 3
        value[0] = 0
  def value_shape(self):
    return (1,)
e = MyExpression(degree = 2)
Ie = interpolate(e, V)
should work. But I get the error
RuntimeError:
*** Error:   Unable to interpolate function into function space.
*** Reason:  Rank of function (1) does not match rank of function space (0).
*** Where:   This error was encountered inside FunctionSpace.cpp.
*** Process: 0
*** DOLFIN version: 2018.1.0
*** Git changeset:
I do not know what the reason wants me to tell. Projecting does also not work. Could there be a problem with if/else test in my expression? Thanks for help.
If I omit
    return (1,)
then I get the warning:
WARNING: user expression has not supplied value_shape method or an element. Assuming scalar element.
Could someone explain this to me?
UFL distinguishes between a scalar, and a vector of rank 1 and dimension 1. You can get rid of the warning with
    #return (1,)
    return ()
Thank you very much.
