Error in defining the integral over subdomain
In order to calculate J-Integral, I want to calculate integration over subdomain. So I defined the subdomain as
But error encountered as
Please help me to define subdomain for integration
Complete Code is as Follows:
import math
parameters[‘form_compiler’][‘cpp_optimize’] = True
parameters[‘form_compiler’][‘optimize’] = True
from mshr import*
set_log_active(False)
Mesh Generation
#mesh_size = 400
#mesh = RectangleMesh(Point(-0.5,-0.5),Point(0.5,0.5),mesh_size,mesh_size)
#mesh = UnitSquareMesh(mesh_size,mesh_size)
mesh = Mesh(“mesh7.xml”)
plot(mesh,title=“Mesh”)
plt.xlabel(“X”)
plt.ylabel(“Y”)
‘’‘Printing Mesh parameters’’’
print(‘calculating the Length Scale Parameter and Total no of Elements’)
print (‘Length Scale Parameter =’,2*mesh.hmin())
print ('Total no of Elements = ', mesh.num_cells())
ndim = mesh.geometry().dim()
Defining Functionspaces
V = FunctionSpace(mesh,“CG”,1)
W = VectorFunctionSpace(mesh,“CG”,1)
WW = FunctionSpace(mesh,“DG”,0)
p , q = TrialFunction(V) , TestFunction(V)
u , v = TrialFunction(W) , TestFunction(W)
Material Properties
E = 210e3
nu = 0.31
k1c = 9.6
G_c = 1000*(1-nu*nu)k1c**2/E
#l = 0.015 # Characterstic Length scale parameter
l = 2
mesh.hmin()
lmbda , mu = Constant(Enu/((1.0 + nu )(1.0-2.0nu))) , Constant(E/(2(1+nu)))
Constitutive Relations
return sym(grad(u))
def sigma(u):
return 2muepsilon(u) + lmbda*tr(epsilon(u))*Identity(ndim)
‘’‘Strain Energy Functional and History Field Variable’’’
def psi(u):
return 0.5*(lmbda + mu)(0.5(tr(epsilon(u)) + abs(tr(epsilon(u)))))**2 +
mu*inner(dev(epsilon(u)),dev(epsilon(u)))
def H(uold,unew,Hold):
return conditional(lt(psi(uold),psi(unew)),psi(unew),Hold)
def Crack(x):
return abs(x[1]) < (2*mesh.hmin()) and x[0] <= 0.0
Subdividing Boundaries
top = CompiledSubDomain(“near(x[1],0.5,1e-8) and on_boundary”)
bottom = CompiledSubDomain(“near(x[1],-0.5,1e-8) and on_boundary”)
left = CompiledSubDomain("(near(x[0],-0.5) or near(x[0],0.5)) and on_boundary")
domain1= CompiledSubDomain(“x[0]*x[0] + x[1]*x[1] - 0.0625 > 0 and x[0]*x[0] + x[1]*x[1] - 0.25 < 0”)
Boundaries Conditions
load = Expression(“t”,t=0,degree=1)
bcbot = DirichletBC(W,Constant((0,0)),bottom)
bcleft = DirichletBC(W.sub(0),Constant(0),left)
bctop = DirichletBC(W.sub(1),load,top)
bc_u = [bcbot,bctop]
bc_phi = [DirichletBC(V, Constant(1.0), Crack)]
Numbering the Boundaries
Boundaries = MeshFunction(‘size_t’,mesh,ndim-1)
Boundaries.set_all(0)
top.mark(Boundaries,1)
bottom.mark(Boundaries,2)
ds = Measure(‘ds’)(subdomain_data = Boundaries)
boundaries = MeshFunction(‘size_t’,mesh,mesh.topology().dim(),0)
boundaries.set_all(0)
domain1.mark(boundaries,1)
dA = Measure(‘dA’)(subdomain_data = boundaries)
Variational Formulation
unew , uold = Function(W) , Function(W)
pnew , pold ,Hold = Function(V) , Function(V) , Function(V)
E_du = ((1 - pold)**2)inner(sigma(u),grad(v))dx
E_phi = (G_c
l
inner(grad§,grad(q)) + (((G_c/l) + 2*H(uold,unew,Hold))inner(p,q))
- 2
H(uold,unew,Hold)*q)*dx
p_disp = LinearVariationalProblem(lhs(E_du),rhs(E_du),unew,bc_u)
p_phi = LinearVariationalProblem(lhs(E_phi),rhs(E_phi),pnew,bc_phi)
solver_disp = LinearVariationalSolver(p_disp)
solver_phi = LinearVariationalSolver(p_phi)
Initialization of Iterative Process parameters
Staggered Scheme
t = 0
u_r = 0.007
deltaT = 0.01
tol = 1e-3
conc_f = File ("./ResultsDir/phi.pvd")
fname = open(‘ForcevsDisp.txt’, ‘w’)
uyy_0 =[]
Reaction_0 = []
Staggered scheme
while t<=0.45:
t += deltaT
if t >=0.34:
deltaT = 0.001
load.t=t*u_r
iter = 0
err = 1
while err > tol:
    iter += 1
    solver_disp.solve()
    solver_phi.solve()
    err_u = errornorm(unew,uold,norm_type = 'l2',mesh = None)
    err_phi = errornorm(pnew,pold,norm_type = 'l2',mesh = None)
    err = max(err_u,err_phi)
    uold.assign(unew)
    pold.assign(pnew)
    Hold.assign(project(psi(unew), WW))
    if err < tol:
        print ('Iterations:', iter, ', Total time', t)
        if round(t*1e4) % 10 == 0:
            conc_f << pnew
            Traction = dot(sigma(unew),n)
            fy = Traction[1]*ds(1)
            fname.write(str(t*u_r) + "\t")
            fname.write(str(assemble(fy)) + "\n")
            uyy_0.append(t*u_r)
            Reaction_0.append(assemble(fy))
            print(assemble(fy))
fname.close()
print (‘Simulation done with no error’)
Post Processing
ux,uy = split(unew)
plot(ux)
plt.colorbar(plot(ux))
plt.xlabel(‘x’)
plt.ylabel(‘ux’)
plot(uy)
plt.colorbar(plot(uy))
plt.xlabel(‘x’)
plt.ylabel(‘uy’)
#load/displacement applied
plot(unew,title =‘U’ )
plt.colorbar(plot(unew,title = ‘U’))
plt.xlabel(‘x’)
plt.ylabel(‘y’)
stress(yy)
plot(sigma(unew)[1,1],title= "\sigma_{yy} [MPa]")
plt.colorbar(plot(sigma(unew)[1,1]))
#Phase-Field variable
plot(pnew,range_min = 0.,range_max = 1., title = ‘Phase Field Parameter’)
plt.colorbar(plot(pnew,range_min = 0.,range_max = 1))
plt.xlabel(‘x’)
plt.ylabel(‘Phi’)
#Reaction Vs Displacement
plt.plot(uyy_0,Reaction_0)
plt.xlabel(“Displacement”)
plt.ylabel(“Reaction Force”)
Writing Excel File
from xlsxwriter import *
outWorkbook = Workbook(“out.xlsx”)
outsheet = outWorkbook.add_worksheet()
for i in range(len(uyy_0)):
outsheet.write(i,0,uyy_0[i])
for j in range(len(Reaction_0)):
outsheet.write(j,1,Reaction_0[j])
print(“Results written successfully”)
Please encapsulate your code with ``` to for at it properly. However, i do not know Which measure A is supposed to be, as the measures in ufl are defined as:
_integral_types = [
    # === Integration over full topological dimension:
    ("cell", "dx"),                     # Over cells of a mesh
    # ("macro_cell", "dE"),              # Over a group of adjacent cells (TODO: Arbitrary cell group? Not currently used.)
    # === Integration over topological dimension - 1:
    ("exterior_facet", "ds"),           # Over one-sided exterior facets of a mesh
    ("interior_facet", "dS"),           # Over two-sided facets between pairs of adjacent cells of a mesh
    # === Integration over topological dimension 0
    ("vertex", "dP"),                    # Over vertices of a mesh
    # ("vertex", "dV"),                  # TODO: Use this over vertices?
    # ("point", "dP"),                   # TODO: Use this over arbitrary points inside cells?
    # === Integration over custom domains
    ("custom", "dc"),                 # Over custom user-defined domains (run-time quadrature points)
    ("cutcell", "dC"),                # Over a cell with some part cut away (run-time quadrature points)
    ("interface", "dI"),              # Over a facet fragment overlapping with two or more cells (run-time quadrature points)
    ("overlap", "dO"),                # Over a cell fragment overlapping with two or more cells (run-time quadrature points)
I encounter above error. I modified my code according to infromation provided by you.
import math
from mshr import*
Mesh Generation
mesh_size = 64
#mesh = Mesh(“mesh7.xml”)
plt.xlabel(“X”)
plt.ylabel(“Y”)
Material Properties
E = 210e3
nu = 0.31
k1c = 9.6
l = 2
mesh.hmin()
return sym(grad(u))
def sigma(u):
def psi(u):
def Crack(x):
domain1= CompiledSubDomain(’(x[0]*x[0] + x[1]*x[1] - 0.0625) >= 0’)
dc = Measure(‘dc’)(subdomain_data = boundaries)
E_phi = (G_c
l
- 2
Staggered Scheme
t = 0
u_r = 0.007
deltaT = 0.01
tol = 1e-3
uyy_0 =[]
Reaction_0 = []
Staggered scheme
while t<=0.45:
t += deltaT
if t >=0.34:
deltaT = 0.001
load.t=t*u_r
iter = 0
err = 1
while err > tol:
    iter += 1
    solver_disp.solve()
    solver_phi.solve()
    uold.assign(unew)
    pold.assign(pnew)
    if err < tol:
            conc_f << pnew
            uyy_0.append(t*u_r)
            print(assemble(fy))
fname.close()
You are using the wrong backticks to encapsulate code, Please Edit your post with the correct ones.
Also, Please adds description of what you want to obtain with your dc integral, and remove all code the is after the error, to make the example smaller.
