Hi all,
I am trying to include a term to the weak form that involved integrating over parts of the domain surface. After some headaches with the actual problem, I boiled down the error to this MWE (slightly obscuring the mathematics):
import dolfinx as dfx
from mpi4py.MPI import COMM_WORLD as comm
def create_boundary_measure(mesh, marker):
tdim = mesh.topology.dim
fdim = tdim - 1
facets = dfx.mesh.locate_entities(mesh, fdim, marker)
facet_markers = np.full_like(facets, 42)
facet_tag = dfx.mesh.meshtags(mesh, fdim, facets, facet_markers)
ds = ufl.Measure("ds", domain=mesh, subdomain_data=facet_tag)
ds = ds(42)
return ds
mesh = dfx.mesh.create_rectangle(comm, ((0., 0.), (1, 42)), (128, 128))
V = dfx.fem.functionspace(mesh, "P1")
V0 = dfx.fem.functionspace(mesh, "P2")
M = dfx.fem.Function(V)
M0 = dfx.fem.Function(V0)
vel = ufl.as_vector([dfx.fem.Function(V),
dfx.fem.Function(V)])
n = ufl.FacetNormal(mesh)
un_out = (ufl.dot(vel, n) + abs(ufl.dot(vel, n))) / 2.0 # type: ignore
form = -ufl.dot(ufl.nabla_grad(v), M * vel) * ufl.dx # type: ignore
form += ufl.dot(v, un_out * M) * ufl.ds # <- Apparently this term causes the issue in conjunction with.
form += v * (vel[1] * M0).dx(1) * ufl.dx
ds_outer = create_boundary_measure(mesh, lambda x: np.isclose(x[0], 1))
M_outer = dfx.fem.Constant(mesh, 0.5 * 1**2)
un_in = (ufl.dot(vel, n) - abs(ufl.dot(vel, n))) / 2.0 # type: ignore
form += ufl.inner(v, un_in * M_outer) * ds_outer # <- ... this term.
dfx.fem.form(form)
The error message is
File "/Users/---/Python/facet_measure_bug_MWE.py", line 57, in <module>
dfx.fem.form(form)
File "/Users/---/.local/miniforge/envs/hurr_bl/lib/python3.13/site-packages/dolfinx/fem/forms.py", line 337, in form
return _create_form(form)
File "/Users/---/.local/miniforge/envs/hurr_bl/lib/python3.13/site-packages/dolfinx/fem/forms.py", line 331, in _create_form
return _form(form)
File "/Users/---/.local/miniforge/envs/hurr_bl/lib/python3.13/site-packages/dolfinx/fem/forms.py", line 249, in _form
assert all([d is data[0] for d in data])
AssertionError
indicating some error related to integrating over different subdomains. This is not what I am intending, so I guess I do not understand how to construct the integral measure ds_outer properly.
Interestingly, if I comment-out either of the two lines containing the surface measures ufl.ds and ds_outer, the compilation runs through.
Is this intended behavior, and if so, how would I achieve and integration over the sub-portion of the surface?
Thanks in advance for your help!
Best,
Tom
PS: My env is
# Name Version Build Channel
adios2 2.10.2 mpi_openmpi_py313he8d0cd2_5 conda-forge
aiohappyeyeballs 2.6.1 pyhd8ed1ab_0 conda-forge
aiohttp 3.11.16 py313ha9b7d5b_0 conda-forge
aiosignal 1.3.2 pyhd8ed1ab_0 conda-forge
anyio 4.9.0 pyh29332c3_0 conda-forge
aom 3.9.1 h7bae524_0 conda-forge
appnope 0.1.4 pyhd8ed1ab_1 conda-forge
argon2-cffi 23.1.0 pyhd8ed1ab_1 conda-forge
argon2-cffi-bindings 21.2.0 py313h20a7fcf_5 conda-forge
arrow 1.3.0 pyhd8ed1ab_1 conda-forge
asttokens 3.0.0 pyhd8ed1ab_1 conda-forge
async-lru 2.0.5 pyh29332c3_0 conda-forge
attrs 25.3.0 pyh71513ae_0 conda-forge
babel 2.17.0 pyhd8ed1ab_0 conda-forge
beautifulsoup4 4.13.3 pyha770c72_0 conda-forge
bleach 6.2.0 pyh29332c3_4 conda-forge
bleach-with-css 6.2.0 h82add2a_4 conda-forge
blosc 1.21.6 h7dd00d9_1 conda-forge
brotli 1.1.0 hd74edd7_2 conda-forge
brotli-bin 1.1.0 hd74edd7_2 conda-forge
brotli-python 1.1.0 py313h3579c5c_2 conda-forge
bzip2 1.0.8 h99b78c6_7 conda-forge
c-ares 1.34.5 h5505292_0 conda-forge
c-blosc2 2.17.1 h9cbb436_0 conda-forge
ca-certificates 2025.4.26 hbd8a1cb_0 conda-forge
cached-property 1.5.2 hd8ed1ab_1 conda-forge
cached_property 1.5.2 pyha770c72_1 conda-forge
cairo 1.18.4 h6a3b0d2_0 conda-forge
cctools_osx-arm64 1010.6 h3b4f5d3_6 conda-forge
certifi 2025.4.26 pyhd8ed1ab_0 conda-forge
cffi 1.17.1 py313hc845a76_0 conda-forge
cftime 1.6.4.post1 pypi_0 pypi
charset-normalizer 3.4.1 pyhd8ed1ab_0 conda-forge
clang 18.1.8 default_h474c9e2_9 conda-forge
clang-18 18.1.8 default_hf90f093_9 conda-forge
clang_impl_osx-arm64 18.1.8 h2ae9ea5_24 conda-forge
clang_osx-arm64 18.1.8 h07b0088_24 conda-forge
clangxx 18.1.8 default_h1ffe849_9 conda-forge
colorama 0.4.6 pyhd8ed1ab_1 conda-forge
colorcet 3.1.0 pyhd8ed1ab_1 conda-forge
comm 0.2.2 pyhd8ed1ab_1 conda-forge
compiler-rt 18.1.8 h856b3c1_1 conda-forge
compiler-rt_osx-arm64 18.1.8 h832e737_1 conda-forge
contourpy 1.3.1 py313h0ebd0e5_0 conda-forge
coverage 7.8.0 py313ha9b7d5b_0 conda-forge
cycler 0.12.1 pyhd8ed1ab_1 conda-forge
cyrus-sasl 2.1.27 h60b93bd_7 conda-forge
dav1d 1.2.1 hb547adb_0 conda-forge
dbus 1.13.6 h3818c69_3 conda-forge
debugpy 1.8.13 py313h928ef07_0 conda-forge
decorator 5.2.1 pyhd8ed1ab_0 conda-forge
defusedxml 0.7.1 pyhd8ed1ab_0 conda-forge
dolfiny 0.9.0 pypi_0 pypi
double-conversion 3.3.1 h286801f_0 conda-forge
exceptiongroup 1.2.2 pyhd8ed1ab_1 conda-forge
executing 2.1.0 pyhd8ed1ab_1 conda-forge
expat 2.7.0 h286801f_0 conda-forge
fenics-basix 0.9.0 py313hd7981f8_2 conda-forge
fenics-basix-nanobind-abi 0.2.1.18 h9b63b7c_2 conda-forge
fenics-dolfinx 0.9.0 py313h7880e45_111 conda-forge
fenics-ffcx 0.9.0 pyh2e48890_0 conda-forge
fenics-libbasix 0.9.0 hf7ae0cd_2 conda-forge
fenics-libdolfinx 0.9.0 py313h113a825_111 conda-forge
fenics-ufcx 0.9.0 hb7f7608_0 conda-forge
fenics-ufl 2024.2.0 pyhd8ed1ab_1 conda-forge
ffmpeg 7.1.1 gpl_h583251a_104 conda-forge
fftw 3.3.10 mpi_openmpi_h260600c_10 conda-forge
fltk 1.3.10 h46aaf7c_0 conda-forge
fmt 11.1.4 h440487c_1 conda-forge
font-ttf-dejavu-sans-mono 2.37 hab24e00_0 conda-forge
font-ttf-inconsolata 3.000 h77eed37_0 conda-forge
font-ttf-source-code-pro 2.038 h77eed37_0 conda-forge
font-ttf-ubuntu 0.83 h77eed37_3 conda-forge
fontconfig 2.15.0 h1383a14_1 conda-forge
fonts-conda-ecosystem 1 0 conda-forge
fonts-conda-forge 1 0 conda-forge
fonttools 4.57.0 py313ha9b7d5b_0 conda-forge
fqdn 1.5.1 pyhd8ed1ab_1 conda-forge
freeimage 3.18.0 h2e169f6_22 conda-forge
freetype 2.13.3 h1d14073_0 conda-forge
fribidi 1.0.10 h27ca646_0 conda-forge
frozenlist 1.5.0 py313ha9b7d5b_1 conda-forge
gdk-pixbuf 2.42.12 h7ddc832_0 conda-forge
gmp 6.3.0 h7bae524_2 conda-forge
gmsh 4.13.1 h88a6c1f_1 conda-forge
graphite2 1.3.13 hebf3989_1003 conda-forge
h11 0.14.0 pyhd8ed1ab_1 conda-forge
h2 4.2.0 pyhd8ed1ab_0 conda-forge
h5py 3.13.0 mpi_openmpi_py313hd9536a5_0 conda-forge
harfbuzz 11.0.1 h371b746_0 conda-forge
hdf4 4.2.15 h2ee6834_7 conda-forge
hdf5 1.14.3 mpi_openmpi_h91eef8b_9 conda-forge
hpack 4.1.0 pyhd8ed1ab_0 conda-forge
httpcore 1.0.7 pyh29332c3_1 conda-forge
httpx 0.28.1 pyhd8ed1ab_0 conda-forge
hyperframe 6.1.0 pyhd8ed1ab_0 conda-forge
hypre 2.32.0 mpi_openmpi_h19a00c9_1 conda-forge
icu 75.1 hfee45f7_0 conda-forge
idna 3.10 pyhd8ed1ab_1 conda-forge
imageio 2.37.0 pyhfb79c49_0 conda-forge
imageio-ffmpeg 0.6.0 pyhd8ed1ab_0 conda-forge
imath 3.1.12 h025cafa_0 conda-forge
importlib-metadata 8.6.1 pyha770c72_0 conda-forge
importlib_resources 6.5.2 pyhd8ed1ab_0 conda-forge
iniconfig 2.0.0 pyhd8ed1ab_1 conda-forge
ipykernel 6.29.5 pyh57ce528_0 conda-forge
ipympl 0.9.7 pyhd8ed1ab_1 conda-forge
ipython 9.1.0 pyhfb0248b_0 conda-forge
ipython_pygments_lexers 1.1.1 pyhd8ed1ab_0 conda-forge
ipywidgets 8.1.5 pyhd8ed1ab_1 conda-forge
isoduration 20.11.0 pyhd8ed1ab_1 conda-forge
jedi 0.19.2 pyhd8ed1ab_1 conda-forge
jinja2 3.1.6 pyhd8ed1ab_0 conda-forge
json5 0.12.0 pyhd8ed1ab_0 conda-forge
jsoncpp 1.9.6 h726d253_1 conda-forge
jsonpointer 3.0.0 py313h8f79df9_1 conda-forge
jsonschema 4.23.0 pyhd8ed1ab_1 conda-forge
jsonschema-specifications 2024.10.1 pyhd8ed1ab_1 conda-forge
jsonschema-with-format-nongpl 4.23.0 hd8ed1ab_1 conda-forge
jupyter 1.1.1 pyhd8ed1ab_1 conda-forge
jupyter-lsp 2.2.5 pyhd8ed1ab_1 conda-forge
jupyter_client 8.6.3 pyhd8ed1ab_1 conda-forge
jupyter_console 6.6.3 pyhd8ed1ab_1 conda-forge
jupyter_core 5.7.2 pyh31011fe_1 conda-forge
jupyter_events 0.12.0 pyh29332c3_0 conda-forge
jupyter_server 2.15.0 pyhd8ed1ab_0 conda-forge
jupyter_server_terminals 0.5.3 pyhd8ed1ab_1 conda-forge
jupyterlab 4.3.6 pyhd8ed1ab_0 conda-forge
jupyterlab_pygments 0.3.0 pyhd8ed1ab_2 conda-forge
jupyterlab_server 2.27.3 pyhd8ed1ab_1 conda-forge
jupyterlab_widgets 3.0.13 pyhd8ed1ab_1 conda-forge
jxrlib 1.1 h93a5062_3 conda-forge
kahip 3.18 py313hbe5273b_0 conda-forge
kiwisolver 1.4.7 py313hf9c7212_0 conda-forge
krb5 1.21.3 h237132a_0 conda-forge
lame 3.100 h1a8c8d9_1003 conda-forge
lcms2 2.17 h7eeda09_0 conda-forge
ld64_osx-arm64 951.9 hb6b49e2_6 conda-forge
lerc 4.0.0 h9a09cb3_0 conda-forge
libabseil 20250127.1 cxx17_h07bc746_0 conda-forge
libadios2 2.10.2 mpi_openmpi_h374d91b_5 conda-forge
libaec 1.1.3 hebf3989_0 conda-forge
libamd 3.3.3 h5087772_7100102 conda-forge
libass 0.17.3 h68e5b86_2 conda-forge
libblas 3.9.0 31_h10e41b3_openblas conda-forge
libboost 1.86.0 hc9fb7c5_3 conda-forge
libboost-devel 1.86.0 hf450f58_3 conda-forge
libboost-headers 1.86.0 hce30654_3 conda-forge
libbrotlicommon 1.1.0 hd74edd7_2 conda-forge
libbrotlidec 1.1.0 hd74edd7_2 conda-forge
libbrotlienc 1.1.0 hd74edd7_2 conda-forge
libbtf 2.3.2 h99b4a89_7100102 conda-forge
libcamd 3.3.3 h99b4a89_7100102 conda-forge
libcblas 3.9.0 31_hb3479ef_openblas conda-forge
libccolamd 3.3.4 h99b4a89_7100102 conda-forge
libcholmod 5.3.1 hbba04d7_7100102 conda-forge
libclang-cpp18.1 18.1.8 default_hf90f093_9 conda-forge
libclang13 20.1.2 default_h81d93ff_0 conda-forge
libcolamd 3.3.4 h99b4a89_7100102 conda-forge
libcurl 8.13.0 h73640d1_0 conda-forge
libcxx 20.1.2 ha82da77_0 conda-forge
libcxx-devel 18.1.8 h6dc3340_8 conda-forge
libdeflate 1.23 hec38601_0 conda-forge
libedit 3.1.20250104 pl5321hafb1f1b_0 conda-forge
libev 4.33 h93a5062_2 conda-forge
libevent 2.1.12 h2757513_1 conda-forge
libexpat 2.7.0 h286801f_0 conda-forge
libfabric 2.1.0 hce30654_0 conda-forge
libfabric1 2.1.0 h5505292_0 conda-forge
libffi 3.4.6 h1da3d7d_1 conda-forge
libgfortran 14.2.0 heb5dd2a_105 conda-forge
libgfortran5 14.2.0 h2c44a93_105 conda-forge
libglib 2.84.0 hdff4504_0 conda-forge
libhwloc 2.11.2 default_hbce5d74_1001 conda-forge
libiconv 1.18 hfe07756_1 conda-forge
libintl 0.23.1 h493aca8_0 conda-forge
libjpeg-turbo 3.0.0 hb547adb_1 conda-forge
libklu 2.3.5 h4370aa4_7100102 conda-forge
liblapack 3.9.0 31_hc9a63f6_openblas conda-forge
libllvm18 18.1.8 hc4b4ae8_3 conda-forge
libllvm20 20.1.2 hc4b4ae8_0 conda-forge
liblzma 5.8.1 h39f12f2_0 conda-forge
libmpdec 4.0.0 h99b78c6_0 conda-forge
libnetcdf 4.9.2 nompi_h610d594_116 conda-forge
libnghttp2 1.64.0 h6d7220d_0 conda-forge
libntlm 1.8 h5505292_0 conda-forge
libogg 1.3.5 h99b78c6_0 conda-forge
libopenblas 0.3.29 openmp_hf332438_0 conda-forge
libopenvino 2025.0.0 h3f17238_3 conda-forge
libopenvino-arm-cpu-plugin 2025.0.0 h3f17238_3 conda-forge
libopenvino-auto-batch-plugin 2025.0.0 h7f72211_3 conda-forge
libopenvino-auto-plugin 2025.0.0 h7f72211_3 conda-forge
libopenvino-hetero-plugin 2025.0.0 h718ad69_3 conda-forge
libopenvino-ir-frontend 2025.0.0 h718ad69_3 conda-forge
libopenvino-onnx-frontend 2025.0.0 h1ae5b81_3 conda-forge
libopenvino-paddle-frontend 2025.0.0 h1ae5b81_3 conda-forge
libopenvino-pytorch-frontend 2025.0.0 h286801f_3 conda-forge
libopenvino-tensorflow-frontend 2025.0.0 heb6e3e1_3 conda-forge
libopenvino-tensorflow-lite-frontend 2025.0.0 h286801f_3 conda-forge
libopus 1.4 h48c0fde_0 conda-forge
libpmix 5.0.7 h6500a5a_0 conda-forge
libpng 1.6.47 h3783ad8_0 conda-forge
libpq 17.4 h6896619_1 conda-forge
libprotobuf 5.29.3 hccd9074_0 conda-forge
libptscotch 7.0.6 hcb9bb0f_1 conda-forge
libraw 0.21.3 hee66ff5_0 conda-forge
librsvg 2.58.4 h266df6f_3 conda-forge
libscotch 7.0.6 he56f69b_1 conda-forge
libsodium 1.0.20 h99b78c6_0 conda-forge
libspqr 4.3.4 h775d698_7100102 conda-forge
libsqlite 3.49.1 h3f77e49_2 conda-forge
libssh2 1.11.1 h9cc3647_0 conda-forge
libsuitesparseconfig 7.10.1 h4a8fc20_7100102 conda-forge
libtheora 1.1.1 h99b78c6_1006 conda-forge
libtiff 4.7.0 h551f018_3 conda-forge
libumfpack 6.3.5 h7c2c975_7100102 conda-forge
libusb 1.0.28 h5505292_0 conda-forge
libvorbis 1.3.7 h9f76cd9_0 conda-forge
libvpx 1.14.1 h7bae524_0 conda-forge
libwebp-base 1.5.0 h2471fea_0 conda-forge
libxcb 1.17.0 hdb1d25a_0 conda-forge
libxml2 2.13.7 h52572c6_1 conda-forge
libzip 1.11.2 h1336266_0 conda-forge
libzlib 1.3.1 h8359307_2 conda-forge
llvm-openmp 20.1.2 hdb05f8b_0 conda-forge
llvm-tools 18.1.8 hc4b4ae8_3 conda-forge
llvm-tools-18 18.1.8 hc4b4ae8_3 conda-forge
llvmlite 0.44.0 py313hd06b435_1 conda-forge
loguru 0.7.2 py313h8f79df9_2 conda-forge
lz4-c 1.10.0 h286801f_1 conda-forge
markupsafe 3.0.2 py313ha9b7d5b_1 conda-forge
matplotlib-base 3.10.1 py313haaf02c0_0 conda-forge
matplotlib-inline 0.1.7 pyhd8ed1ab_1 conda-forge
metis 5.1.0 h15f6cfe_1007 conda-forge
mistune 3.1.3 pyh29332c3_0 conda-forge
mpi 1.0 openmpi conda-forge
mpi4py 4.0.3 py313h7222c6d_0 conda-forge
msgpack-python 1.1.0 py313hf9c7212_0 conda-forge
multidict 6.3.2 py313h6347b5a_0 conda-forge
mumps-include 5.7.3 he67b4ff_9 conda-forge
mumps-mpi 5.7.3 ha27d91b_9 conda-forge
munkres 1.1.4 pyh9f0ad1d_0 conda-forge
mysql-common 9.2.0 hd7719f6_0 conda-forge
mysql-libs 9.2.0 ha8be5b7_0 conda-forge
nbclient 0.10.2 pyhd8ed1ab_0 conda-forge
nbconvert-core 7.16.6 pyh29332c3_0 conda-forge
nbformat 5.10.4 pyhd8ed1ab_1 conda-forge
ncurses 6.5 h5e97a16_3 conda-forge
nest-asyncio 1.6.0 pyhd8ed1ab_1 conda-forge
netcdf4 1.7.2 pypi_0 pypi
nlohmann_json 3.11.3 h00cdb27_1 conda-forge
notebook 7.3.3 pyhd8ed1ab_0 conda-forge
notebook-shim 0.2.4 pyhd8ed1ab_1 conda-forge
numba 0.61.2 py313h8aea8d6_0 conda-forge
numpy 2.2.4 py313h41a2e72_0 conda-forge
occt 7.8.1 novtk_hbec2736_103 conda-forge
openexr 3.3.3 h10b4c9a_0 conda-forge
openh264 2.6.0 hb5b2745_0 conda-forge
openjpeg 2.5.3 h8a3d83b_0 conda-forge
openldap 2.6.9 hbe55e7a_0 conda-forge
openmpi 5.0.7 h31ce4ef_100 conda-forge
openssl 3.5.0 h81ee809_1 conda-forge
overrides 7.7.0 pyhd8ed1ab_1 conda-forge
packaging 24.2 pyhd8ed1ab_2 conda-forge
pandas 2.2.3 pypi_0 pypi
pandocfilters 1.5.0 pyhd8ed1ab_0 conda-forge
pango 1.56.3 h5fd7515_1 conda-forge
parmetis 4.0.3 he8458ae_1007 conda-forge
parso 0.8.4 pyhd8ed1ab_1 conda-forge
pcre2 10.44 h297a79d_2 conda-forge
petsc 3.22.3 real_h824c086_103 conda-forge
petsc4py 3.22.4 np2py313h03d4cd5_0 conda-forge
pexpect 4.9.0 pyhd8ed1ab_1 conda-forge
pickleshare 0.7.5 pyhd8ed1ab_1004 conda-forge
pillow 11.1.0 py313hb37fac4_0 conda-forge
pip 25.0.1 pyh145f28c_0 conda-forge
pixman 0.44.2 h2f9eb0b_0 conda-forge
pkg-config 0.29.2 hde07d2e_1009 conda-forge
pkgutil-resolve-name 1.3.10 pyhd8ed1ab_2 conda-forge
platformdirs 4.3.7 pyh29332c3_0 conda-forge
pluggy 1.5.0 pyhd8ed1ab_1 conda-forge
pooch 1.8.2 pyhd8ed1ab_1 conda-forge
proj 9.6.0 h1318a7e_1 conda-forge
prometheus_client 0.21.1 pyhd8ed1ab_0 conda-forge
prompt-toolkit 3.0.50 pyha770c72_0 conda-forge
prompt_toolkit 3.0.50 hd8ed1ab_0 conda-forge
propcache 0.2.1 py313ha9b7d5b_1 conda-forge
psutil 7.0.0 py313h90d716c_0 conda-forge
pthread-stubs 0.4 hd74edd7_1002 conda-forge
ptyprocess 0.7.0 pyhd8ed1ab_1 conda-forge
pugixml 1.15 hd3d436d_0 conda-forge
pure_eval 0.2.3 pyhd8ed1ab_1 conda-forge
pycparser 2.22 pyh29332c3_1 conda-forge
pygments 2.19.1 pyhd8ed1ab_0 conda-forge
pymobimp 0.1 pypi_0 pypi
pyobjc-core 11.0 py313hb6afeec_0 conda-forge
pyobjc-framework-cocoa 11.0 py313hb6afeec_0 conda-forge
pyparsing 3.2.3 pyhd8ed1ab_1 conda-forge
pysocks 1.7.1 pyha55dd90_7 conda-forge
pytest 8.3.5 pyhd8ed1ab_0 conda-forge
pytest-cov 6.1.1 pyhd8ed1ab_0 conda-forge
python 3.13.2 h81fe080_101_cp313 conda-forge
python-dateutil 2.9.0.post0 pyhff2d567_1 conda-forge
python-fastjsonschema 2.21.1 pyhd8ed1ab_0 conda-forge
python-gmsh 4.13.1 h57928b3_1 conda-forge
python-json-logger 2.0.7 pyhd8ed1ab_0 conda-forge
python_abi 3.13 6_cp313 conda-forge
pytz 2025.2 pyhd8ed1ab_0 conda-forge
pyvista 0.44.1 pyhd8ed1ab_0 conda-forge
pyyaml 6.0.2 py313ha9b7d5b_2 conda-forge
pyzmq 26.4.0 py313he6960b1_0 conda-forge
qhull 2020.2 h420ef59_5 conda-forge
qt6-main 6.8.3 hca13b62_2 conda-forge
rapidjson 1.1.0.post20240409 ha1acc90_2 conda-forge
readline 8.2 h1d1bf99_2 conda-forge
referencing 0.36.2 pyh29332c3_0 conda-forge
requests 2.32.3 pyhd8ed1ab_1 conda-forge
rfc3339-validator 0.1.4 pyhd8ed1ab_1 conda-forge
rfc3986-validator 0.1.1 pyh9f0ad1d_0 conda-forge
rpds-py 0.24.0 py313hb5fa170_0 conda-forge
scalapack 2.2.0 ha79e478_4 conda-forge
scifem 0.5.0 py313hfd1d6c2_0 conda-forge
scipy 1.15.2 py313h9a24e0a_0 conda-forge
scooby 0.10.0 pyhd8ed1ab_1 conda-forge
sdl2 2.32.54 h994913f_0 conda-forge
sdl3 3.2.10 he842692_0 conda-forge
send2trash 1.8.3 pyh31c8845_1 conda-forge
setuptools 78.1.0 pyhff2d567_0 conda-forge
sharpie 0.0.1 pypi_0 pypi
sigtool 0.1.3 h44b9a77_0 conda-forge
six 1.17.0 pyhd8ed1ab_0 conda-forge
slepc 3.22.2 real_h6dfd3a0_300 conda-forge
slepc4py 3.22.2 py313h12d5f4c_0 conda-forge
snappy 1.2.1 h98b9ce2_1 conda-forge
sniffio 1.3.1 pyhd8ed1ab_1 conda-forge
soupsieve 2.5 pyhd8ed1ab_1 conda-forge
spdlog 1.15.2 h008cadb_0 conda-forge
sqlite 3.49.1 hd7222ec_2 conda-forge
stack_data 0.6.3 pyhd8ed1ab_1 conda-forge
superlu 7.0.0 h742a510_1 conda-forge
superlu_dist 9.1.0 h6ba37e7_0 conda-forge
svt-av1 3.0.2 h8ab69cd_0 conda-forge
tapi 1300.6.5 h03f4b80_0 conda-forge
tbb 2022.1.0 h9541205_0 conda-forge
terminado 0.18.1 pyh31c8845_0 conda-forge
tinycss2 1.4.0 pyhd8ed1ab_0 conda-forge
tk 8.6.13 h5083fa2_1 conda-forge
toml 0.10.2 pyhd8ed1ab_1 conda-forge
tomli 2.2.1 pyhd8ed1ab_1 conda-forge
tornado 6.4.2 py313h90d716c_0 conda-forge
tqdm 4.67.1 pyhd8ed1ab_1 conda-forge
traitlets 5.14.3 pyhd8ed1ab_1 conda-forge
types-python-dateutil 2.9.0.20241206 pyhd8ed1ab_0 conda-forge
typing-extensions 4.13.1 hf5ce1d7_0 conda-forge
typing_extensions 4.13.1 pyh29332c3_0 conda-forge
typing_utils 0.1.0 pyhd8ed1ab_1 conda-forge
tzdata 2025.2 pypi_0 pypi
uri-template 1.3.0 pyhd8ed1ab_1 conda-forge
urllib3 2.3.0 pyhd8ed1ab_0 conda-forge
utfcpp 4.0.6 h54c0426_0 conda-forge
vtk 9.4.1 hff47c66_2 conda-forge
vtk-base 9.4.1 py313h4a1e8f4_2 conda-forge
vtk-io-ffmpeg 9.4.1 h3d0ef82_2 conda-forge
wcwidth 0.2.13 pyhd8ed1ab_1 conda-forge
webcolors 24.11.1 pyhd8ed1ab_0 conda-forge
webencodings 0.5.1 pyhd8ed1ab_3 conda-forge
websocket-client 1.8.0 pyhd8ed1ab_1 conda-forge
widgetsnbextension 4.0.13 pyhd8ed1ab_1 conda-forge
wslink 2.3.3 pyhd8ed1ab_0 conda-forge
x264 1!164.3095 h57fd34a_2 conda-forge
x265 3.5 hbc6ce65_3 conda-forge
xarray 2025.4.0 pypi_0 pypi
xorg-libice 1.1.2 h5505292_0 conda-forge
xorg-libsm 1.2.6 h5505292_0 conda-forge
xorg-libx11 1.8.12 h6a5fb8c_0 conda-forge
xorg-libxau 1.0.12 h5505292_0 conda-forge
xorg-libxdmcp 1.1.5 hd74edd7_0 conda-forge
xorg-libxext 1.3.6 hd74edd7_0 conda-forge
xorg-libxfixes 6.0.1 hd74edd7_0 conda-forge
xorg-libxrender 0.9.12 h5505292_0 conda-forge
yaml 0.2.5 h3422bc3_2 conda-forge
yarl 1.18.3 py313ha9b7d5b_1 conda-forge
zeromq 4.3.5 hc1bb282_7 conda-forge
zfp 1.0.1 h1c5d8ea_2 conda-forge
zipp 3.21.0 pyhd8ed1ab_1 conda-forge
zlib-ng 2.2.4 h13dfb9a_0 conda-forge
zstandard 0.23.0 py313h90d716c_1 conda-forge
zstd 1.5.7 h6491c7d_2 conda-forge
