Error in demos codes of LocalAssembler for dolfinx0.10.0
The code is
import time
import cffi
import dolfinx.fem.petsc as petsc
from petsc4py.lib.PETSc import ScalarType
from ufl import div, ds, dx, grad, inner, rank
class LocalAssembler():
    def __init__(self, form):
        self.form = fem.form(form)
        self.update_coefficients()
        self.update_constants()
        subdomain_ids = self.form.integral_ids(fem.IntegralType.cell)
        assert(len(subdomain_ids) == 1)
        assert(subdomain_ids[0] == -1)
        is_complex = np.issubdtype(ScalarType, np.complexfloating)
        nptype = "complex128" if is_complex else "float64"
        self.kernel = getattr(self.form.ufcx_form.integrals(fem.IntegralType.cell)[0], f"tabulate_tensor_{nptype}")
        self.active_cells = self.form.domains(fem.IntegralType.cell, -1)
        assert len(self.form.function_spaces) == self.form.rank
        self.local_shape = [0 for _ in range(self.form.rank)]
        for i, V in enumerate(self.form.function_spaces):
            self.local_shape[i] = V.dofmap.dof_layout.block_size * V.dofmap.dof_layout.num_dofs
        e0 = self.form.function_spaces[0].element
        if self.form.rank == 1:
            e1 = self.form.function_spaces[0].element
        elif self.form.rank == 2:
            e1 = self.form.function_spaces[1].element
            raise RuntimeError(f"Assembly for tensor of tensor of {rank=} is not supported")
        needs_transformation_data = e0.needs_dof_transformations or e1.needs_dof_transformations or \
            self.form.needs_facet_permutations
        if needs_transformation_data:
            raise NotImplementedError("Dof transformations not implemented")
        self.ffi = cffi.FFI()
        V = self.form.function_spaces[0]
        self.x_dofs = V.mesh.geometry.dofmap
        self.local_tensor = np.zeros(self.local_shape, dtype=ScalarType)
    def update_coefficients(self):
        self.coeffs = fem.assemble.pack_coefficients(self.form)[(fem.IntegralType.cell, -1)]
    def update_constants(self):
        self.consts = fem.assemble.pack_constants(self.form)
    def update(self):
    def assemble(self, i:int):
        x = self.form.function_spaces[0].mesh.geometry.x
        x_dofs = self.x_dofs.links(i)
        geometry = np.zeros((len(x_dofs), 3), dtype=np.float64)
        geometry[:, :] = x[x_dofs]
        facet_index = np.zeros(0, dtype=np.intc)
        facet_perm = np.zeros(0, dtype=np.uint8)
        if self.coeffs.shape == (0, 0):
            coeffs = np.zeros(0, dtype=ScalarType)
            coeffs = self.coeffs[i,:]
        ffi_fb = self.ffi.from_buffer
        self.local_tensor.fill(0)
        self.kernel(ffi_fb(self.local_tensor), ffi_fb(coeffs), ffi_fb(self.consts), ffi_fb(geometry),
               ffi_fb(facet_index), ffi_fb(facet_perm), self.ffi.NULL,)
        return self.local_tensor
N = 20
msh = mesh.create_box(MPI.COMM_WORLD, [np.array([0.0, 0.0, 0.0]),
                                  np.array([2.0, 1.0, 1.0])], [N, N, N],
                 mesh.CellType.tetrahedron)
Q = fem.functionspace(msh, ("DG", 2))
p = ufl.TrialFunction(Q)
q = ufl.TestFunction(Q)
a = inner(p, q) *dx
lhs_assembler = LocalAssembler(a)
Which is from Element-wise post-processing
Then when I try to run it in FEnicsx, errors say that
  File "/home/a/PycharmProjects/Explode/main.py", line 89, in <module>
  File "/home/a/PycharmProjects/Explode/main.py", line 17, in __init__
  File "/home/a/PycharmProjects/Explode/main.py", line 50, in update_coefficients
KeyError: (_IntegralType.cell, -1)
How to fix this
########################EDIT##################################################
I edit the code, then the latest code is
    def __init__(self, form, integral_type: fem.IntegralType =fem.IntegralType.cell):
        self.integral_type = integral_type
        # subdomain_ids = self.form.integral_ids(integral_type)
        # assert(len(subdomain_ids) == 1)
        # assert(subdomain_ids[0] == -1)
        o_s = self.form.ufcx_form.form_integral_offsets[_type_to_offset_index[integral_type]]
        o_e = self.form.ufcx_form.form_integral_offsets[_type_to_offset_index[integral_type]+1]
        assert o_e - o_s == 1
        self.kernel = getattr(self.form.ufcx_form.form_integrals[o_s], f"tabulate_tensor_{nptype}")
        self.active_cells = self.form._cpp_object.domains(integral_type, 0)
        #assert len(self.form.function_spaces) == 2
        self.local_shape = [0,0]
                                    self.form._cpp_object.needs_facet_permutations
        #e0 = self.form.function_spaces[0].element
        #e1 = self.form.function_spaces[1].element
        self.coeffs = fem.assemble.pack_coefficients(self.form)[(self.integral_type, 0)]
    def update(self):
    def assemble_matrix(self, i:int, local_index:int = 0):
        x_dofs = self.x_dofs[i]
        #A_local = np.zeros((self.local_shape[0], self.local_shape[0]), dtype=ScalarType)
        facet_index = np.array([local_index], dtype=np.intc)
                    ffi_fb(facet_index), ffi_fb(facet_perm), self.ffi.NULL, )
then an error
  File "/home/a/PycharmProjects/Explode/main.py", line 114, in <module>
    A = lhs_assembler.assemble_matrix(cell)
  File "/home/a/PycharmProjects/Explode/main.py", line 87, in assemble_matrix
TypeError: implicit cast from 'char *' to a different pointer type: (check that the types are as you expect; use an explicit ffi.cast() if they are correct)
occurs, how to fix this?
See:
and in particular
I add
self.ffi.NULL,
and also the update_coefficients is
the full code is
import time
import cffi
_type_to_offset_index = {fem.IntegralType.cell: 0, fem.IntegralType.exterior_facet: 1}
    def update(self):
N = 20
a = inner(p, q) *dx
W = fem.functionspace(msh, ("Lagrange", 1, (msh.geometry.dim,)))
uh = fem.Function(W)
uh.interpolate(lambda x: (x[0], 2*x[1], x[2]**2))
l = inner(div(uh), q)*dx
rhs_assembler = LocalAssembler(l)
w1 = fem.Function(Q)
bs = Q.dofmap.bs
start = time.perf_counter()
for cell in range(msh.topology.index_map(msh.topology.dim).size_local):
    b = rhs_assembler.assemble_matrix(cell)
    cell_dofs = Q.dofmap.cell_dofs(cell)
    unrolled_dofs = np.zeros(len(cell_dofs)*bs, dtype=np.int32)
    for i, dof in enumerate(cell_dofs):
        for j in range(bs):
            unrolled_dofs[i*bs+j] = dof*bs+j
    w1.x.array[unrolled_dofs] = np.linalg.solve(A, b)
w1.x.scatter_forward()
end = time.perf_counter()
print(f"Local assembly {end-start:.2e}")
w2 = fem.Function(Q)
problem = petsc.LinearProblem(a, l, u=w2)
problem.solve()
w2.x.scatter_forward()
print(f"Global assembly {end-start:.2e}")
with VTXWriter(msh.comm, "w1.bp", [w1]) as vtx:
    vtx.write(0)
with VTXWriter(msh.comm, "w2.bp", [w2]) as vtx:
    vtx.write(0)
assert np.allclose(w1.x.array, w2.x.array)
