Hello Dokken,
Thanks to the code you provided, I managed to implement the original local post-processing I was interested in.
Now I want to study a different local post-processing defined as: For each element K, find (z_h, p_h) \in RT_1(K) \times P_1(K) such that
\int_K z_h \cdot v_h \textrm{ dx} \,- \int_K p_h \, \textrm{div} v_h \textrm{ dx} = - \int_{\partial K} s_e \, (v_h \cdot n) \textrm{ ds} \quad \forall v_h \in RT_1(K)
\int_K \textrm{div} z_h \, q_h \textrm{dx} = \int_K u_e \, q_h \textrm{ dx} \quad \forall q_h \in P_1(K),
where RT_1(K) is the Raviart-Thomas vector space of index 1 on K, P_1(K) is the space of linear polynomials over K, s_e and u_e are previously computed scalar functions, and n is the unitary normal vector.
Here is my attempt to modify your code to implement such mixed post-processing (I did not modify the LocalAssembler class, only the code right after).
# Copyright (C) 2023 Jørgen S. Dokken
# Local assembly in DOLFINx using numpy
# SPDX-License-Identifier: MIT
import time
import cffi
import dolfinx.fem.petsc as petsc
from ufl import div, ds, dx, grad, inner, dot
import os
class LocalAssembler():
def __init__(self, form):
self.form = fem.form(form)
self.update_coefficients()
self.update_constants()
subdomain_ids = self.form.integral_ids(fem.IntegralType.cell)
assert(len(subdomain_ids) == 1)
assert(subdomain_ids[0] == -1)
is_complex = np.issubdtype(ScalarType, np.complexfloating)
nptype = "complex128" if is_complex else "float64"
self.kernel = getattr(self.form.ufcx_form.integrals(fem.IntegralType.cell)[0], f"tabulate_tensor_{nptype}")
self.active_cells = self.form.domains(fem.IntegralType.cell, -1)
assert len(self.form.function_spaces) == self.form.rank
self.local_shape = [0 for _ in range(self.form.rank)]
for i, V in enumerate(self.form.function_spaces):
self.local_shape[i] = V.dofmap.dof_layout.block_size * V.dofmap.dof_layout.num_dofs
e0 = self.form.function_spaces[0].element
if self.form.rank == 1:
e1 = self.form.function_spaces[0].element
elif self.form.rank == 2:
e1 = self.form.function_spaces[1].element
raise RuntimeError(f"Assembly for tensor of tensor of {rank=} is not supported")
needs_transformation_data = e0.needs_dof_transformations or e1.needs_dof_transformations or \
self.form.needs_facet_permutations
if needs_transformation_data:
raise NotImplementedError("Dof transformations not implemented")
self.ffi = cffi.FFI()
V = self.form.function_spaces[0]
self.x_dofs = V.mesh.geometry.dofmap
self.local_tensor = np.zeros(self.local_shape, dtype=ScalarType)
def update_coefficients(self):
self.coeffs = fem.assemble.pack_coefficients(self.form)[(fem.IntegralType.cell, -1)]
def update_constants(self):
self.consts = fem.assemble.pack_constants(self.form)
def update(self):
def assemble(self, i:int):
x = self.form.function_spaces[0].mesh.geometry.x
x_dofs = self.x_dofs.links(i)
geometry = np.zeros((len(x_dofs), 3), dtype=np.float64)
geometry[:, :] = x[x_dofs]
facet_index = np.zeros(0, dtype=np.intc)
facet_perm = np.zeros(0, dtype=np.uint8)
if self.coeffs.shape == (0, 0):
coeffs = np.zeros(0, dtype=ScalarType)
coeffs = self.coeffs[i,:]
ffi_fb = self.ffi.from_buffer
self.local_tensor.fill(0)
self.kernel(ffi_fb(self.local_tensor), ffi_fb(coeffs), ffi_fb(self.consts), ffi_fb(geometry),
ffi_fb(facet_index), ffi_fb(facet_perm))
return self.local_tensor
# No modifications until here -------------------------------------------------
N = 30
msh = mesh.create_rectangle(MPI.COMM_WORLD, [np.array([0.0, 0.0]),
np.array([0.5, 0.5])], [N, N],
mesh.CellType.triangle)
x = ufl.SpatialCoordinate(msh) # Spatial coordinates
nn = ufl.FacetNormal(msh) # Unitary normal vector
# Source terms
se_ = lambda x: ufl.sin(ufl.pi*x[0])*ufl.sin(ufl.pi*x[1])
ue_ = lambda x: 2*ufl.pi*ufl.pi*ufl.sin(ufl.pi*x[0])*ufl.sin(ufl.pi*x[1])
se = se_(x)
ue = ue_(x)
# Mixed approximation space
el_vd = ufl.FiniteElement('DRT', msh.ufl_cell(), 2)
el_p = ufl.FiniteElement('DG', msh.ufl_cell(), 1)
W = fem.FunctionSpace(msh, ufl.MixedElement([el_vd, el_p]))
# Test and trial functions
TrialF = ufl.TrialFunction(W)
TestF = ufl.TestFunction(W)
(z,p) = ufl.split(TrialF)
(v,q) = ufl.split(TestF)
a = inner(z, v)*dx
a += -inner(p, div(v))*dx
a += inner(div(z), q)*dx
L = -se*dot(v, nn)*ds
L += inner(ue, q)*dx
lhs_assembler = LocalAssembler(a)
rhs_assembler = LocalAssembler(L)
wh = fem.Function(W)
bs = W.dofmap.bs
for cell in range(msh.topology.index_map(msh.topology.dim).size_local):
A = lhs_assembler.assemble(cell)
b = rhs_assembler.assemble(cell)
cell_dofs = W.dofmap.cell_dofs(cell)
unrolled_dofs = np.zeros(len(cell_dofs)*bs, dtype=np.int32)
for i, dof in enumerate(cell_dofs):
for j in range(bs):
unrolled_dofs[i*bs+j] = dof*bs+j
wh.x.array[unrolled_dofs] = np.linalg.solve(A, b)
wh.x.scatter_forward()
(vdh, ph) = wh.split()
However, the solutions I got seem wrong. In particular, the y component of z_h has a noticeable problem in the top boundary, as shown in the figure below.
My guess is that the problem is in the term - \int_{\partial K} s_e \, (v_h \cdot n) \textrm{ ds}. For the post-processing to be correct, the normal vectors n must be outwards (relative to the element K), and I think that is not always satisfied when using ufl.FacetNormal.
Any ideas on how to fix it?
Sorry to take more of your time,
Giovanni
