Error in extracting surface and boundary markers for a compiled subdomain from its parent mesh
Here is the problem. I have a geometry imported from gmsh. There are 4 subdomains. Let’s call them mesh1, mesh2, mesh3 and mesh4. After importing the mesh, I define my boundary and surface markers. Then I use the surface markers to create a compiled subdomain of mesh2 + mesh3 + mesh4. The problem is creating surface and boundary measures for the compiled subdomain using surface and boundary markers of the parent mesh.
The geometry looks like
# Importing mesh from gmsh and defining surface and boundary markers
msh = meshio.read("mesh.msh")
triangle_mesh = create_mesh(msh, "triangle", True)
line_mesh = create_mesh(msh, "line", True)
meshio.write("mf.xdmf", line_mesh)
mesh = Mesh()
   infile.read(mesh)
# Compiling subdomains
combined_subdomains = MeshFunction("size_t", mesh, mesh.topology().dim(), 0)
combined_subdomains.array()[cf.array()==5] = 1
combined_subdomains.array()[cf.array()==6] = 1
combined_subdomains.array()[cf.array()==7] = 1
mesh_ima = SubMesh(mesh, combined_subdomains, 1)
# Defining measures for the compiled subdomain
mvc_ima = MeshValueCollection("size_t", mesh_ima, mesh_ima.topology().dim())
   infile.read(mesh_ima)
   infile.read(mvc_ima, "name_to_read")
cf_ima = cpp.mesh.MeshFunctionSizet(mesh_ima, mvc_ima)
mvc_ima = MeshValueCollection("size_t", mesh_ima, mesh_ima.topology().dim()-1)
mf_ima = cpp.mesh.MeshFunctionSizet(mesh_ima, mvc_ima)
ds_custom = Measure("dS", domain=mesh_ima, subdomain_data=mf_ima)
dx_custom = Measure("dx", domain=mesh_ima, subdomain_data=cf_ima)
I believe that in ds_custom and dx_custom, the domain and subdomain data are for the compiled subdomain, but that seems not to be the case. So is there anything wrong in creating dx_custom and ds_custom?
Let me know if you need any other information.
As you are not supplying the geo file (or gmsh python scrupt) that generates the mesh, it is hard to give you any further assistance.
Hi @dokken , here is the gmsh script:
SetFactory("OpenCASCADE");
x1 = 0;
x2 = 2*Pi;
n =200;
lc1 = 0.08;
lc2 = 0.08;
lc3 = 0.08;
lc4 = 0.08;
//First interface Points and Lines for the endothelium
For i In {0:n-1}
  x = x1 + (x2 - x1) * i/n;
  r = 1.7217+0.2858*Cos (x)-0.2452*Sin (x)+0.0204*Cos (2*x)+0.0345*Sin (2*x)-0.1876*Cos (3*x)+0.0348*Sin (3*x)-0.0358*Cos (4*x)+0.0329*Sin (4*x)-0.0101*Cos (5*x)+0.1119*Sin (5*x);
  pList1[i] = newp;
  Point (pList1[i]) = {r*Cos (x),r*Sin (x), 0}; //if you want the inner boundary mesh to be more refined change lc1 to a smaller number
EndFor
//Spline creates a continuous boundary using the points above
s1 = newreg;
Spline(s1) = {pList1[{0:n-1}],1};
//Second interface Points and Lines for the IEL
For i In {n:2*n-1}
  r = 2.4656+0.2869*Cos(x)-0.2907*Sin(x)-0.0445*Cos(2*x)-0.0129*Sin(2*x)-0.1528*Cos(3*x)+0.0131*Sin(3*x)-0.0457*Cos(4*x)-0.0665*Sin(4*x)+0.0186*Cos(5*x)-0.0081*Sin(5*x);
  pList2[i] = newp;
  Point (pList2[i]) = {r*Cos (x),r*Sin (x), 0};
EndFor
s2 = newreg;
Spline(s2) = {pList2[{n:2*n-1}],n+1};
//Second interface Points and Lines for the MEDIA-ADVENTITIA interface
For i In {2*n:3*n-1}
  r = 4.9314+0.1441*Cos(x)-0.2625*Sin(x)-0.1752*Cos(2*x)-0.2901*Sin(2*x)+0.1908*Cos(3*x)+0.0297*Sin(3*x)+0.2856*Cos(4*x)-0.2104*Sin(4*x)-0.0537*Cos(5*x)-0.1570*Sin(5*x);
  pList3[i] = newp;
  Point (pList3[i]) = {r*Cos (x),r*Sin (x), 0};
EndFor
s3 = newreg;
Spline(s3) = {pList3[{2*n:3*n-1}],2*n+1};
//Second interface Points and Lines for the ADVENTITIA outermost boundary
For i In {3*n:4*n-1}
  r = 7.9536+0.0443*Cos(x)-0.5983*Sin(x)-0.0620*Cos(2*x)+0.1528*Sin(2*x)+0.4119*Cos(3*x)-0.1249*Sin(3*x)-0.1130*Cos(4*x)-0.2179*Sin(4*x)+0.0910*Cos(5*x)+0.1176*Sin(5*x);
  pList4[i] = newp;
  Point (pList4[i]) = {r*Cos (x),r*Sin (x), 0};
EndFor
s4 = newreg;
Spline(s4) = {pList4[{3*n:4*n-1}],3*n+1};
Physical Curve("C1", 1) = {1};
Physical Curve("C2", 2) = {2};
Physical Curve("C3", 3) = {3};
Physical Curve("C4", 4) = {4};
Curve Loop(1) = {2};
Curve Loop(2) = {1};
Plane Surface(1) = {1, 2};
Curve Loop(3) = {3};
Curve Loop(4) = {2};
Plane Surface(2) = {3, 4};
Curve Loop(5) = {4};
Curve Loop(6) = {3};
Plane Surface(3) = {5, 6};
Physical Surface("S5", 5) = {1};
Physical Surface("S6", 6) = {2};
Physical Surface("S7", 7) = {3};
Curve Loop(7) = {1};
Plane Surface(4) = {7};
Physical Surface("S8", 8) = {4};
I need some guidance on this.
