Hi everybody, does anyone known why when I mesh my cad file, consisting in only one volume but two separate figures, i can’t mesh the ellipsoid ? The strange thing is that when I mesh the same cad but with the ellipse attached to the tails it works well.
You need to supply a minimal working example for anyone to help you.
I would also like to note that this is a gmsh/mesh generator question, and should probably be directed to the authors/community of the relevant mesh generator (for instance gmsh / gmsh · GitLab if you are using gmsh)
sure, you can delete the post I’ve solved the problem.
