Error in Newton solver
I have written the following code to calculate Magnetic potential in 3D.The following is my code.
from math import *
# Create Geometry
Rair = 5
cyltot = Cylinder(Point(0,0,10),Point(0,0,0),Rair,Rair)
mesh_tot = generate_mesh(cyltot,64)
vtkfile = File('/home/fenics/shared/Cylinder/Mesh_tot.pvd')
vtkfile << mesh_tot
V = FunctionSpace(mesh_tot,'P',1)`
# Subdomains
def boundary(x,on_boundary):
    return on_boundary
tol = 1E-14
class Copper(SubDomain):
        return np.sqrt(x[0]*x[0] + x[1]*x[1] ) <= 1 + tol
class Air(SubDomain):
        return np.sqrt(x[0]*x[0] + x[1]*x[1] ) >= 1 - tol
materials = MeshFunction('size_t',mesh_tot,mesh_tot.topology().dim())
Subdom_cu = Copper()
Subdom_air = Air()
materials.set_all(0)
Subdom_cu.mark(materials, 1)
file = File("/home/fenics/shared/Cylinder/Materials.pvd")
file << materials
# Defining the parameters
RCu = 1/1.256637E-6
RAir = 1/1.256629E-6
JCu = 6/(np.pi)
JAir = 0
class Rel(UserExpression):
    def __init__(self,materials,**kwargs):
        super().__init__(**kwargs)
        self._materials = materials
        if self._materials[cell.index] == 0:
            values[0] = RAir
            values[0] = RCu
Reluc = Rel(materials,degree=0)
class Jd(UserExpression):
        self.materials = materials
        if self.materials[cell.index] == 0:
            values[0] = JAir
            values[0] = JCu
Jz = Jd(materials,degree=0)
# Boundary Conditions
A_bound = Constant(0.0)
bc = DirichletBC(V,A_bound,boundary)
# Defining the Function
Ax = Function(V)
F = inner(grad(Ax*Reluc),grad(v))*dx
Ax = Function(V)
solve(F==0,Ax,bc,solver_parameters={"newton_solver":{"relative_tolerance":1e-6}})
Ay = Function(V)
F = inner(grad(Ay*Reluc),grad(v))*dx
Ay = Function(V)
solve(F==0,Ay,bc,solver_parameters={"newton_solver":{"relative_tolerance":1e-6}})
Az = Function(V)
F = inner(grad(Az*Reluc),grad(v))*dx - Jz*v*dx
Az = Function(V)
solve(F==0,Az,bc,solver_parameters={"newton_solver":{"relative_tolerance":1e-6}})
# Plotting
Vp = VectorFunctionSpace(mesh_tot,'P',1)
A_tot = Function(V)
A_tot = Expression(('Ax','Ay','Az'),Ax=Ax,Ay=Ay,Az=Az)
vtkfile = File('Vectorpotential.pvd')
vtkfile<<A_to
There are three Poisson equations here that needs to be solved.The first two were solved
,but the third Poisson equation shows a RuntimeError with regards to PETsc,which I am not able to understand.
fenics@d2cb9f28de4f:~$ python3 ~/shared/Cylinder/cylinder.py
Generating mesh with CGAL 3D mesh generator
WARNING: user expression has not supplied value_shape method or an element. Assuming scalar element.
No Jacobian form specified for nonlinear variational problem.
Differentiating residual form F to obtain Jacobian J = F’.
Newton iteration 0: r (abs) = 0.000e+00 (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-06)
Newton solver finished in 0 iterations and 0 linear solver iterations.
Newton iteration 0: r (abs) = 1.060e+00 (tol = 1.000e-10) r (rel) = 1.000e+00 (tol = 1.000e-06)
File “/home/fenics/shared/Cylinder/cylinder.py”, line 92, in
solve(F==0,Az,bc,solver_parameters={“newton_solver”:{“relative_tolerance”:1e-6}})
File “/usr/local/lib/python3.6/dist-packages/dolfin/fem/solving.py”, line 220, in solve
File “/usr/local/lib/python3.6/dist-packages/dolfin/fem/solving.py”, line 266, in _solve_varproblem
solver.solve()
RuntimeError:
*** Error: Unable to successfully call PETSc function ‘MatSetValuesLocal’.
*** Reason: PETSc error code is: 63 (Argument out of range).
*** Where: This error was encountered inside /tmp/dolfin/dolfin/la/PETScMatrix.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset: 74d7efe1e84d65e9433fd96c50f1d278fa3e3f3f
Can somebody please help me in understanding the solution?
Please format your code using ``` such that it runnable by others without having to do manual indentation and formatting
I am sorry for the inconvenience.I have made the edit as required.
There are several things in your code you need to have a look at.
as far as I can tell, the solution to this equation is 0. The same holds for the second equation.
Here is a working version of your code using linear solvers (and not user expressions, as I do not like them).
from math import *
# Create Geometry`
Rair = 5
vtkfile << mesh_tot
# Subdomains
tol = 1E-14
Subdom_air = Air()
RCu = 1/1.256637E-6
JCu = 6/(np.pi)
JAir = 0
Q = FunctionSpace(mesh_tot, "DG", 0)
Jz = Function(Q)
x = Q.tabulate_dof_coordinates()
for i in range(x.shape[0]):
    if materials.array()[i] == 0:
        Jz.vector().vec().setValueLocal(i, JAir)
        Jz.vector().vec().setValueLocal(i, JCu)
Reluc = Function(Q)
        Reluc.vector().vec().setValueLocal(i, RAir)
        Reluc.vector().vec().setValueLocal(i, RCu)
bc = DirichletBC(V,A_bound,"on_boundary")
Ax = TrialFunction(V)
a = inner(grad(Ax*Reluc),grad(v))*dx
l = inner(Constant(0), v)*dx
Ax = Function(V)
solve(a==l,Ax,bc)
Ay = TrialFunction(V)
a2 = inner(grad(Ay*Reluc),grad(v))*dx
Ay = Function(V)
solve(a2==l,Ay)
Az = TrialFunction(V)
a3 = inner(grad(Az*Reluc),grad(v))*dx - Jz*v*dx
l3 = rhs(a3)
Az = Function(V)
solve(lhs(a3)==l3,Az,bc)
Thanks! The linear solver worked.
