I am trying to reproduce the convergence behaviour for linear FE for the 1D Poisson problem with Robin boundary conditions on the interval (0,1), i.e., weak form a(u,v) = L(v) with
a(u,v) = \langle u',v'\rangle + \varepsilon^{-1}(u(0)v(0)+u(1)v(1)) \text{ and } L(v) = \langle f, v\rangle.
My code is appended below. From my lecture, I would expect that the energy norm of the error is O(h), while the L^2 norm is O(h^2). This works well in the beginning, however, after sometime the errors start to behave strange and go up again. (-> see result plot appended.) If my implementation is correct, why does this behaviour occur? If not, how can I avoid it and get even better accuracies? Thanks in advance.
n_steps = 7
mesh_factor = 10
L2_error_list = []
energy_error_list = []
numbers = []
for step in range(n_steps):
print('Step', step)
n_parts = mesh_factor**(step+1)
numbers.append(n_parts)
mesh = IntervalMesh(n_parts, 0, 1)
#Define VP
eps = 10**(-4)
f = Expression('pow((2*pi),2)*sin(2*pi*x[0]) + pow((4*pi),2)*sin(4*pi*x[0]) + pow((6*pi),2)*sin(6*pi*x[0])', degree = 2)
a = dot(grad(u),grad(v))*dx + pow(eps,-1)*(u*v*ds)
L = f*v*dx
sol = Function(V)
solve(a==L, sol)
true_sol = Expression('sin(2*pi*x[0]) + sin(4*pi*x[0]) + sin(6*pi*x[0]) + pow(1+2*eps,-1)*(-24*pi*eps*x[0]+12*pi*eps)', degree = 5, domain = mesh, eps = eps)
#L2 error
L2_squared = (sol- true_sol)**2*dx
L2_error = sqrt(abs(assemble(L2_squared)))
L2_error_list.append(L2_error)
#Energy error
energy_squared = dot(grad(sol)-grad(true_sol),grad(sol)-grad(true_sol))*dx + pow(eps,-1)*((sol-true_sol)*(sol-true_sol)*ds)
energy_error = sqrt(assemble(energy_squared))
energy_error_list.append(energy_error)
print('L2', L2_error_list)
print('Energy', energy_error_list)
Here a graphical visualization of the values:
