Error in using Newton's method in mixed formulation
Hi everyone,
I would like to use Newton’s method to solve a nonlinear problem in a mixed formulation, but I encountered the following error and would like to ask what might be missing in my code.
As far as I know, in DG methods, the mixed formulation is usually transformed into a primal formulation before solving. Therefore, I am unsure whether Newton’s method can be directly applied to the mixed formulation. Apologies, as I am not very familiar with this aspect.
import math
p = 4
pdeg = 1
size = 10
def vecnorm(vec):
  return pow(inner(vec,vec),0.5)
def ConvergenceFunction(iteration, v, v0, abs_tol, rel_tol, convergence):
    absolute = v.norm("l2")
    if (iteration == 0):
        absolute0 = absolute
        absolute0 = v0
    relative = absolute/absolute0
    if absolute < abs_tol or relative < rel_tol:
        convergence = True
    return convergence, absolute, relative
mesh = RectangleMesh(Point(0, 0), Point(1, 1), size, size)
uex = Expression(" sin(pi*x[0])*sin(pi*x[1])",degree=5,pi=math.pi)
Lex = Expression((" pi*sin(pi*x[1])*cos(pi*x[0]) "," pi*sin(pi*x[0])*cos(pi*x[1]) "),degree=5,pi=math.pi)
Coe = Expression("pow((pow(pi,2)*pow(sin(pi*x[0]),2)*pow(cos(pi*x[1]),2) + pow(pi,2)*pow(sin(pi*x[1]),2)*pow(cos(pi*x[0]),2)),1.0)", degree=5,pi=math.pi)
Aex = Expression((" Coe*pi*sin(pi*x[1])*cos(pi*x[0]) "," Coe*pi*sin(pi*x[0])*cos(pi*x[1]) "),degree=5,pi=math.pi,Coe=Coe)
f = Expression(" (0.5*pow(pi,4.0)*(-cos(pi*(2*x[0] - 2*x[1])) - cos(pi*(2*x[0] + 2*x[1])) + 2) - 2.0*pow(pi,4)*pow(cos(pi*x[0]),2)*cos(2*pi*x[1]) - 2.0*pow(pi,4)*cos(2*pi*x[0])*pow(cos(pi*x[1]),2))*sin(pi*x[0])*sin(pi*x[1])", degree=5,pi=math.pi)
P1 = VectorElement("DG", triangle, pdeg)
P2 = VectorElement("DG", triangle, pdeg)
P3 = FiniteElement("DG", triangle, pdeg)
P1P2P3 = MixedElement([P1, P2, P3])
W = FunctionSpace(mesh, P1P2P3)
w = Function(W)
(L,A,u) = w.split()
(X,Y,z) = TestFunctions(W)
h = CellDiameter(mesh)
h_avg = (h('+') + h('-'))/2
V1 = FunctionSpace(mesh, P1)
V2 = FunctionSpace(mesh, P2)
V3 = FunctionSpace(mesh, P3)
uD = uex
uD = project(uD, V3)
bc = DirichletBC(W.sub(2), uD, "on_boundary")
# bc = DirichletBC(W, uD, "on_boundary")
# Primal formulation and iter
delta = Constant(1e-10)
alpha = Constant(10.0)
u = project(uex, V3)
L = project(Lex, V1)
# u = un
# L = Ln
# A = project(Aex, V2)
Nonlinear1 = (delta + pow((vecnorm(L)),p-2))*L
Nonlinear2 = (delta + pow((vecnorm((1/h_avg)*jump(u,n))),p-2))*(1/h_avg)*jump(u,n)
Nonlinear3 = (delta + pow((vecnorm((1/h)*(u-uD)*n)),p-2))*(1/h)*(u-uD)
a = inner(Nonlinear1 , Y)*dx + alpha*inner(Nonlinear2,jump(z,n))*dS + alpha*Nonlinear3*z*ds
b1 = - inner(A,Y)*dx + inner(A,grad(z))*dx - inner(avg(A),jump(z,n))*dS - inner(A,n)*z*ds
b2 = - inner(X,L)*dx + inner(X,grad(u))*dx - inner(avg(X),jump(u,n))*dS - inner(X,n)*u*ds
F = f*z*dx
G = -uD*inner(X,n)*ds
Lhs = a + b1 + b2
Rhs =  F + G
form = Lhs-Rhs
dw  = TrialFunction(W)
dw_ = Function(W)
w_  = Function(W)
solve(form == 0, w, bc, J = derivative(form, u, du),
solver_parameters={"newton_solver":{"relative_tolerance":1e-6, "absolute_tolerance":1e-10, "convergence_criterion":"incremental"}})
*** Error: Unable to successfully call PETSc function ‘MatSetValuesLocal’.
*** Reason: PETSc error code is: 63 (Argument out of range).
*** Where: This error was encountered inside /tmp/dolfin-src/dolfin/la/PETScMatrix.cpp.
*** Process: 0
*** Git changeset: 1c52e837eb54cc34627f90bde254be4aa8a2ae17
Hi.
Your code is not reproducible because of the line
solve(form == 0, w, bc, J=derivative(form, u, du),
      solver_parameters={"newton_solver": {"relative_tolerance": 1e-6, "absolute_tolerance": 1e-10, "convergence_criterion": "incremental"}})
since du is not defined. Changing to
solve(form == 0, w, bc, J=derivative(form, w, dw),
yields to the error you described. By taking a glimpse on your code, I noted that you are using (L, A, u) = w.split(). The correct line is
(L, A, u) = split(w)
This will make your code run. The last is necessary in non-linear problems (see for example Function.split() vs Split(Function)). However, I’m not getting any convergence, so you maybe want to debug further. For example, use interpolate instead of `project for exact solutions.
Cheers.
Thank you. I have two more questions I’d like to ask.
How can I print out iteration information, for example:
Newton iteration = … : r (abs) = … (tol = 1.000000e-10), r (rel) = … (tol = 1.000000e-06)
And how can I transform it into a primal formulation to implement Newton’s method? If you have any information on this, it would be a huge help.
Your code is printing exactly what you are requiring.
  Newton iteration 0: r (abs) = nan (tol = 1.000e-10) r (rel) = nan (tol = 1.000e-06)
  Newton iteration 1: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-06)
  Newton iteration 2: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-06)
  Newton iteration 3: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-06)
  Newton iteration 4: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-06)
  Newton iteration 5: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-06)
  Newton iteration 6: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-06)
  Newton iteration 7: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-06)
  Newton iteration 8: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-06)
  Newton iteration 9: r (abs) = -nan (tol = 1.000e-10) r (rel) = -nan (tol = 1.000e-06)
There is no useful information because your scheme is diverging.
I cannot help you very much in this sense. Maybe @nate can give you some clues on that.
Cheers.
Thank you for your response, but on my Google Colab, I only see these error messages and no iteration information is printed.
in <cell line: 35>()
179 w_ = Function(W)
180
→ 181 solve(form == 0, w, bc, J = derivative(form, w, dw),
182 solver_parameters={“newton_solver”:{“relative_tolerance”:1e-6, “absolute_tolerance”:1e-10, “convergence_criterion”:“incremental”}})
183
1 frames
/usr/local/lib/python3.10/dist-packages/dolfin/fem/solving.py in solve(*args, **kwargs)
231 # tolerance)
232 elif isinstance(args[0], ufl.classes.Equation):
→ 233 _solve_varproblem(*args, **kwargs)
234
235 # Default case, just call the wrapped C++ solve function
/usr/local/lib/python3.10/dist-packages/dolfin/fem/solving.py in _solve_varproblem(*args, **kwargs)
312 solver = NonlinearVariationalSolver(problem)
313 solver.parameters.update(solver_parameters)
→ 314 solver.solve()
315
316
RuntimeError:
*** https://fenicsproject.discourse.group/
*** Error: Unable to solve nonlinear system with NewtonSolver.
*** Reason: Newton solver did not converge because maximum number of iterations reached.
*** Where: This error was encountered inside NewtonSolver.cpp.
*** Process: 0
