Function.split() vs Split(Function)
Hi I was trying to understand what the difference between the two splits. In particular I would really appreciate an example of different use cases.
For example if I have the following:
U2 = ufl.VectorElement("Lagrange", domain.ufl_cell(), 2) # For displacement
P1 = ufl.FiniteElement("Lagrange", domain.ufl_cell(), 1) # For  pressure
TH = ufl.MixedElement([U2, P1])     # Taylor-Hood style mixed element
ME = FunctionSpace(domain, TH)    # Total space for all DOFs
w = Function(ME)
I understand u, p = split(w) would give me the functions for the two subelements
However I don’t understand what u, p = w.split() would output.
Thanks again for the help.
ufl.split splits it into ufl representations of the sub function, i.e.
u, p = ufl.split(w)
print(type(u), type(p)))
returns
<class 'ufl.tensors.ListTensor'> <class 'ufl.indexed.Indexed'>
while
u,p = w.split()
returns dolfinx functions, which can in turn be collapsed to give contiguous views into dof data
So just to confirm my understanding u,p = ufl.split(w) is normally used when creating the variational forms to then put into a solver.
Meanwhile u,p = w.split()`` is the same as calling u = w.sub(0) p = w.sub(1)``` and would be used when post processing data.
Yes. You can also w.split to access things such as interpolation into a component of a Mixed space
Hi, I have an additional question.
Can Function.split() and split(Function) all be used to assemble the bilinear form and linear form in variational formulation?
The reason why I guess this is that in my code, both methods can work.
You should not use Function.split() in a variational form.
ufl.split should be used in variational forms.
Function.split should be used for interpolation etc.
Hi, Dokken. I have an additional question.
the u and p in
u, p = split(w)
are references for components of w according to a fenics official demo fenics demo: Cahn-Hilliard equation.
What about the u and p in u, p = w.split()? Are they references or copies for the components of w?
Thank you very much in advance.
They are still references, you need to use _u = u.collapse() to get the copy.
See:
https://docs.fenicsproject.org/dolfinx/v0.8.0/python/generated/dolfinx.fem.html#dolfinx.fem.Function.split
Got it. Thank you very much.
Hi, Dokken. Sorry to bother you again. I have another related question. Do you know how to assign a value to the component of w? I used the following code:
u, p = split(w)
p.interpolate(Constant(5))
But I got an error:
AttributeError: 'Indexed' object has no attribute 'interpolate'
Could you please tell me how to do it correctly? Thank you very much in advance.
w.sub(1).interpolate(….) in DOLFINx. I am not sure about legacy dolfin syntax of the top of my head, and are currently not at a computer to test it
