I believe this is a simple question but have not found a solution. I have a fem.Function with a vector function space and I am trying to interpolate a constant value onto one of the subspaces. In this attempt, I get a long error message (pasted below) and the kernel keeps running, producing the error messages, until I manually stop it. The MWE is
import numpy
from dolfinx import mesh, fem, nls, plot, cpp
import pyvista
from dolfinx.io import gmshio
dx_min = 0.1
dx_max = 0.1
cyl = gmsh.model.occ.addDisk(0, 0, 0, 1, 1)
gmsh.model.occ.synchronize()
gdim = 2
gmsh.model.addPhysicalGroup(gdim, [cyl], 1)
gmsh.option.setNumber("Mesh.CharacteristicLengthMin",dx_min)
gmsh.option.setNumber("Mesh.CharacteristicLengthMax",dx_max)
# convert to fenics format
gmsh_model_rank = 0
mesh_comm = MPI.COMM_WORLD
domain, cell_markers, facet_markers = gmshio.model_to_mesh(gmsh.model, mesh_comm, gmsh_model_rank, gdim=gdim)
# vector function space
W = fem.VectorFunctionSpace(domain, ("CG",1))
# create function and set values of sub
u = fem.Function(W)
u.sub(0).interpolate(fem.Constant(domain, PETSc.ScalarType(1)))
Error messages:
Couldn't map 'c_0' to a float, returning ufl object without evaluation. WARNING:UFL:Couldn't map 'c_0' to a float, returning ufl object without evaluation. Couldn't map 'c_0' to a float, returning ufl object without evaluation. WARNING:UFL:Couldn't map 'c_0' to a float, returning ufl object without evaluation. Couldn't map 'c_0' to a float, returning ufl object without evaluation. WARNING:UFL:Couldn't map 'c_0' to a float, returning ufl object without evaluation. Couldn't map 'c_0' to a float, returning ufl object without evaluation. WARNING:UFL:Couldn't map 'c_0' to a float, returning ufl object without evaluation. Couldn't map 'c_0' to a float, returning ufl object without evaluation. Couldn't map 'c_0' to a float, returning ufl object without evaluation. WARNING:UFL:Couldn't map 'c_0' to a float, returning ufl object without evaluation. Couldn't map 'c_0' to a float, returning ufl object without evaluation. WARNING:UFL:Couldn't map 'c_0' to a float, returning ufl object without evaluation. Couldn't map 'c_0' to a float, returning ufl object without evaluation. Couldn't map 'c_0' to a float, returning ufl object without evaluation. WARNING:UFL:Couldn't map 'c_0' to a float, returning ufl object without evaluation. Couldn't map 'c_0' to a float, returning ufl object without evaluation. WARNING:UFL:Couldn't map 'c_0' to a float, returning ufl object without evaluation. Couldn't map 'c_0' to a float, returning ufl object without evaluation. WARNING:UFL:Couldn't map 'c_0' to a float, returning ufl object without evaluation. Couldn't map 'c_0' to a float, returning ufl object without evaluation. WARNING:UFL:Couldn't map 'c_0' to a float, returning ufl object without evaluation. Couldn't map 'c_0' to a float, returning ufl object without evaluation. Couldn't map 'c_0' to a float, returning ufl object without evaluation. WARNING:UFL:Couldn't map 'c_0' to a float, returning ufl object without evaluation. Couldn't map 'c_0' to a float, returning ufl object without evaluation. Couldn't map 'c_0' to a float, returning ufl object without evaluation.
Thanks!
