I’m interpolating a Gaussian distribution as the IC for my system of time-dependent equations, but I keep getting the error: Couldn’t map ‘c_4’ to a float, returning ufl object without evaluation.
Past examples of this error include not using the in-built ufl functions for exp, which I have fixed.
I’ve tested and the issue isn’t with using multiple function spaces to account for only two of the five variables being time-dependent (would appreciate advice on whether this is a wise option too!)
Dolfinx installed via conda on Mac M1 Monterey.
Thank you so much!
Below is the minimal code:
from dolfinx import mesh, fem, io, nls, log
xmin = -5
xmax = 5
ymax = 5
domain = mesh.create_rectangle(MPI.COMM_WORLD, [(xmin,0),(xmax,ymax)], n=[200, 50])
degree = 3
P1 = ufl.FiniteElement("Lagrange", domain.ufl_cell(), degree)
element = ufl.MixedElement([P1, P1, P1, P1, P1]) #create a mixed function space
V = fem.FunctionSpace(domain, element)
#we create another function space for the t dependent h1 and h2 only
element2 = ufl.MixedElement([P1, P1])
W = fem.FunctionSpace(domain, element2)
v1, v2, v3, v4, v5 = ufl.TestFunctions(V)
u = fem.Function(V)
u_n = fem.Function(W) #update previous solution
h1, h2, p1, p2, ul = ufl.split(u)
h1_n, h2_n = ufl.split(u_n)
#Define constants
Hbath = 2.0
shape = fem.Constant(domain, PETSc.ScalarType(5.0))
Aconst = fem.Constant(domain, PETSc.ScalarType(100.0))
hinf = fem.Constant(domain, PETSc.ScalarType(0.01))
#ERROR
u.sub(1).interpolate(Hbath + hinf + ufl.sqrt(shape*pi) * ufl.exp(-shape*pow(x[0],2)) * 4./3)
u.x.scatter_forward()
