The instruction is quite clear, you should install
libgl1-mesa-glx and xvfb on your system.
If you are on a newer version of ubuntu (24.04) install: libgl1-mesa-dev instead of libgl1-mesa-glx
Did you install xvfb as well?
Thank you for your help. My Problem solved. I appreciate you. Thanks a lot
How would one proceed at this point if running macOS and cannot install neither libgl1-mesa-glx nor xvfb (the only other option available on anaconda is xvfbwrapper)
Remove the pyvista.start_xvfb() command alltogether from your code.
xvfb is mainly used when wanting off-screen plotting in docker containers (which usually run linux).
Thank you for your help!
