Error obtaining dofs between vertex and cell in 2D mesh
Dear FENICS community. I am trying to import meshes from gmsh using meshio to then study a problem with discontinuous elements in Dolfinx.
Provided that I have a 2D mesh file called mesh.xdmf, I execute
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, "mesh.xdmf", "r") as xdmf:
    ct = xdmf.read_meshtags(mesh, name="Grid")
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, "mt.xdmf", "r") as xdmf:
    ft = xdmf.read_meshtags(mesh, name="Grid")
Following @dokken example in Define a boundary from DG elements, I ran the lines
def boundary(x):
    return np.full(x.shape[1], True)
vertex_to_cell = mesh.topology.connectivity(0, mesh.topology.dim)
boundary_vertices = dolfinx.mesh.locate_entities(mesh, 0, boundary)
boundary_cells = []
for vertex in boundary_vertices:
    boundary_cells.append(vertex_to_cell.links(vertex))
boundary_cells = np.hstack(boundary_cells)
But this error comes out
Traceback (most recent call last):....
AttributeError: 'NoneType' object has no attribute 'links'
Since mesh.topology.connectivity(0, mesh.topology.dim) returns None. However, if I let the Python console open after the error and rerun line, sometimes it returns the vertex_to_cell dofs. I don’t now how this is happening.
On the other hand, the line
facet_to_cell = mesh.topology.connectivity(1, mesh.topology.dim)
returns the facet-to-cell dofs properly. Moreover, mesh.topology.connectivity(0, 1_or_2_here) returns None. The only one that seems to work is mesh.topology.connectivity(0, 0), i.e., vertex-to-vertex dofs
For the sake of reproducibility, I’ve made a similar code using a built-in mesh that one can write/read in the single code.
Please note that whenever you ask for a connectivity(a, b), you should make sure it as been created. This can be done by adding
mesh.topology.create_connectivity(a, b)
before requesting it as
a_to_b = mesh.topology.connectivity(a, b)
The reason for such an approach is that for many codes, you do not need these connectivities, which are time and memory consuming.
import dolfinx.io
def create_and_write_mesh(filename: str):
    mesh = dolfinx.UnitSquareMesh(MPI.COMM_WORLD, 10, 10)
    mesh.topology.create_entities(mesh.topology.dim - 1)
    # Create a facet tag that has a unique marker per facet
    num_local_facets = mesh.topology.index_map(mesh.topology.dim-1).size_local
    facet_indices = np.arange(num_local_facets, dtype=np.int32)
    ft = dolfinx.MeshTags(mesh, mesh.topology.dim-1,
                          facet_indices, facet_indices)
    ft.name = "Facetmarkers"
    # Create a cell tag that has a unique marker per cell
    num_local_cells = mesh.topology.index_map(mesh.topology.dim).size_local
    cell_indices = np.arange(num_local_cells, dtype=np.int32)
    ct = dolfinx.MeshTags(mesh, mesh.topology.dim,
                          cell_indices, cell_indices)
    ct.name = "Cellmarkers"
    with dolfinx.io.XDMFFile(mesh.mpi_comm(), filename, "w") as xdmf:
        xdmf.write_mesh(mesh)
        xdmf.write_meshtags(ct)
        xdmf.write_meshtags(ft)
filename = "cube.xdmf"
create_and_write_mesh("cube.xdmf")
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, filename, "r") as xdmf:
    mesh = xdmf.read_mesh()
    ct = xdmf.read_meshtags(mesh, name="Cellmarkers")
    ft = xdmf.read_meshtags(mesh, name="Facetmarkers")
def boundary(x):
mesh.topology.create_connectivity(0, mesh.topology.dim)
boundary_vertices = dolfinx.mesh.locate_entities_boundary(mesh, 0, boundary)
boundary_cells = []
print(boundary_cells)
