Error setting up the variational form in subdomains 3D
Hello, I’m working in composite domain (cylindrical carbon fibre in epoxy matrix) defining the Lamé coefs (lambda and mu) as an expression using c++ for the subdomains, normally I tested my code with a simpler uniform cube for linear elasticity and it works, but after modifying it shows an error when it try to calculate dot(f,v)dx + dot(T,v)ds, the essential part showing the problem:
from ufl import nabla_grad, nabla_div
f_func = Expression(’-10E4*(pow(x[0], 2) - 25)’, degree=2)
mesh = BoxMesh(Point(-5, -5, 0), Point(5, 5, 1), 80, 80, 10)
V = VectorFunctionSpace(mesh,‘P’, 1)
def boundary_L(x, on_boundary):
tol = 1E-14
return on_boundary and near(x[0], -5, tol)
bc_L = DirichletBC(V, Constant((0, 0, 0)), boundary_L)
def boundary_R(x, on_boundary):
tol = 1E-14
return on_boundary and near(x[0], 5, tol)
bc_R = DirichletBC(V, Constant((0, 0, 0)), boundary_R)
bcs = [bc_L, bc_R]
tol = 1E-14
lamb_0 = 6428571429
lamb_1 = 3.37E11
lambda_ = Expression(‘pow(x[0],2) + pow(x[1],2) <= 2 + tol ? lamb_1 : lamb_0’, degree=0, tol=tol, lamb_1=lamb_1, lamb_0=lamb_0)
mu_0 = 1607142857
mu_1 = 1.444E11
mu_ = Expression(‘pow(x[0],2) + pow(x[1],2) <= 2 + tol ? mu_1 : mu_0’, degree=0, tol=tol, mu_1=mu_1, mu_0=mu_0)
def sigma(u):
return lambda_*nabla_div(u)Identity(d) + 2mu_*epsilon(u)
d = u.geometric_dimension()
f = (0, f_func, 0)
T = Constant((0, 0, 0))
L = dot(f, v)*dx + dot(T, v)*ds
solve(a == L, u, bcs)
The Error:
File “my_file.py”, line 56, in
File “/usr/lib/python3/dist-packages/ufl/operators.py”, line 158, in dot
a = as_ufl(a)
File “/usr/lib/python3/dist-packages/ufl/constantvalue.py”, line 413, in as_ufl
" to any UFL type." % str(expression))
ufl.log.UFLValueError: Invalid type conversion: (0, Coefficient(FunctionSpace(None, FiniteElement(‘Lagrange’, None, 2)), 0), 0) can not be converted to any UFL type.
I’ve installed FEniCS from source files in my laptop OS Ubuntu 18.04
Thanks by advance for all your comments and help
Hi
You can try this:
f_func = Expression('-10E4*(pow(x[1], 2) - 25)', degree=2)
dd =  as_vector([0] + [f_func]+ [0])
L = dot(dd, v)*dx + dot(T, v)*ds
In addition you need to change the linear solver to mumps to avoid RuntimeError:
solve(a == L, u, bcs,solver_parameters={'linear_solver':'mumps'})
Thanks a lot, that was exactly the problem !!! have a nice day
