Hello everyone
When I run this program, I get an error.
can you please check why I get it.
Lx = 5 # length of system along x-axis
Ly = 10 # length of system along y-axis
n_ele = 10 # number of element
mesh = RectangleMesh(Point( 0 , -Ly/2 ) , Point(Lx, Ly / 2) , n_ele , n_ele)
domains = MeshFunction("size_t", mesh, 2)
f = TrialFunction(V)
g = TestFunction(V)
def boundary(x):
tol = 1E-14
return near(x[0], 0, tol)
bc = DirichletBC(V, 0.0, boundary)
r = Expression("x[0] ", degree = 1)
l = Expression("5 / x[0]" , degree=1)
a = r * (inner(nabla_grad(f), nabla_grad(g)) + 5 * f * g) * dx + l * f * g * dx
b = r * f * g * dx
H = PETScMatrix()
M = PETScMatrix()
assemble(a, tensor=H)
bc.apply(H)
assemble(b, tensor=M)
bc.apply(M)
# Create eigensolver for generalized EVP
eigensolver = SLEPcEigenSolver(H, M)
eigensolver.parameters["spectrum"] = "smallest magnitude"
eigensolver.parameters["solver"] = "lapack"
eigensolver.solve()
r, c, rx, cx = eigensolver.get_eigenpair(0)
print("lambda",r)
dokken
June 27, 2020, 5:50am
2
Please format the code properly by encapsulating it with ```, such that it is readable and runnable for others.
Additionally, please add the error message you are receiving
Thank you for your response, the error that I get is below.
*** Error: Unable to extract eigenpair from SLEPc eigenvalue solver.
*** Reason: Requested eigenpair (0) has not been computed.
*** Where: This error was encountered inside SLEPcEigenSolver.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
*** Git changeset: 15b823f2c45d3036b6af931284d0f8e3c77b6845
Process finished with exit code 1
Can you define what each term is and what it is a function of…?
I think the problem is related to the divergent of m / x , when x takes 0 so m / x takes a infinite value.
My question rises from here , how I can add a condition as follows, x = 0 => u(0) = 0. ?
dokken
June 29, 2020, 11:51am
6
You can modify your domain, excluding x=0, as done in 1D in this post: Coupled linear problem solves to give NaN? (Describes curvature flows)
You can Also remove the singularity by multiplying all terms by x.
