Error solving SLEPc eigenvalue solver
Hi, I am trying to solve the time Independent Schrödinger with periodic boundary conditions. I am facing a problem while solving SLEPc eigenvalue solver.
When I run the program, I get the following error:
*** Error:   Unable to extract eigenpair from SLEPc eigenvalue solver.
*** Reason:  Requested eigenpair (0) has not been computed.
*** Where:   This error was encountered inside SLEPcEigenSolver.cpp.
I am writing the code in C++. My UFC file MyForms.ufl is found below.
element = FiniteElement("Lagrange", triangle, 1)
u = TrialFunction(element)
v = TestFunction(element)
Mass = Coefficient(element)
U = Coefficient(element)
a = Mass*inner(grad(v), grad(u))*dx+v*u*U*dx
m=v*u*dx
forms=[a,m]
Additionally, the main part of my program is
#include <string>
#include <iostream>
#include <fstream>
#include "MyForms.h"
#include "input.cpp"
using namespace dolfin;
			Periodic Boundary Class
class Periodic :public SubDomain
	public:
	bool inside(const Array<double>&x,bool on_boundary) const
		bool left=std::fabs(x[0])< DOLFIN_EPS;
		bool bottom=std::fabs(x[1])<DOLFIN_EPS;
		bool right=std::fabs(x[0]-Width)<DOLFIN_EPS;
		bool top=std::fabs(x[1]-Height)<DOLFIN_EPS;
		return (left||bottom) &&(!(right||top)) &on_boundary;
	void map(const Array<double>&x,Array<double>&y) const {
		y[0]=x[0];
		y[1]=x[1];
		if(std::fabs(x[0]-Width)<DOLFIN_EPS)
			y[0]-=Width;
		if(std::fabs(x[1]-Height)<DOLFIN_EPS)
			y[1]-=Height;
	private:
				Effective Mass class
class EffectiveMass : public Expression {
	public:
		void eval(
			Array<double>& values,
			const Array<double> &x,
			const ufc::cell &cell
		) const {
			//Inside QD
			if( (*regions)[cell.index] == 1 ) {
				values[0] =-H_BAR*H_BAR/(2*ME*EFFIN*Q) ;
			//If Outside QD
			} else if( (*regions)[cell.index] == 2 ) {
				values[0] = -H_BAR*H_BAR/(2*ME*EFFOUT*Q);
		std::shared_ptr<MeshFunction<std::size_t>> regions;
	private:
					Potential Class
class Potential: public Expression{
	public:
		void eval(Array<double>&values,
			) const {
				//Inside QD
				if( (*regions)[cell.index]==1){
					values[0]=0.0;
				//If Outside QD
				} else if( (*regions)[cell.index]==2){
					values[0]=OFFSET;
	private:
int main(int argc, char** argv){
//Input mesh from file
File meshData("Total.xml");
auto mesh=std::make_shared<Mesh>();
meshData >> *mesh;
//Input physical regions from file
auto  MyFunction=std::make_shared<MeshFunction<std::size_t>>(mesh,"./Total_physical_region.xml");//get physic
//Check if MyFunction is empty... if it is then exit with warrning
if( MyFunction->empty()){
	std::cerr<<"Could not find make MeshFunction for subdomains";
	return 1;
//create periodic boundary condition and FunctionSpace
auto pcb=std::make_shared<Periodic>();
auto V=std::make_shared<MyForms::FunctionSpace>(mesh,pcb);
//set up  Av=EMv
//Assemble A Matrix
MyForms::Form_a a(V,V);
auto Mass=std::make_shared<EffectiveMass>();
Mass->regions=MyFunction;
auto Pot =std::make_shared<Potential>();
Pot->regions=MyFunction;
a.Mass=Mass;
a.U=Pot;
auto A=std::make_shared<PETScMatrix>();
assemble(*A,a);
//Assemble M Matrix
MyForms::Form_m m(V,V);
auto M=std::make_shared<PETScMatrix>();
assemble(*M,m);
//Create eigensolver
SLEPcEigenSolver esolver(A,M);
esolver.parameters["solver"]="krylov-schur";
esolver.parameters["problem_type"]="gen_hermitian";
esolver.parameters["spectrum"]="smallest real";
esolver.parameters["tolerance"]=1e-14;
esolver.solve();
double r,c;
PETScVector rx,cx;
Function u(V);
//First specified number of quantum states
for(int i=0;i<SavedStates;i++)
	esolver.get_eigenpair(r,c,rx,cx,i);
	*u.vector()=rx;
	File file("./DNSSolutions/WF"+std::to_string(i)+".pvd");
	file<<u;
	HDF5File file2(MPI_COMM_SELF,"./DNSSolutions/WF"+std::to_string(i)+".hdf5","w");
	file2.write(u,"WF"+std::to_string(i));
//Save EigenValues to a file
for(int i=0;i<SavedStates;i++){
	std::ofstream file;
	file.open("./DNSSolutions/Eigenvalue"+std::to_string(i)+".txt");
	file<<r;
	file.close();
Thanks
