Hello!
I am trying to solve a 2D eigenvalue problem in Fenics using SLEPc (the Schrodinger equation, to be more precise). I’d like to use a uniform mesh of size say 500 x 500, with polynomials of degree 5, for example. I’m looking for the smallest, say 100 eigenpairs. I find that this computation takes extremely long (at least 14 hours), or worse, does not happen at all! (It works for smaller mesh sizes). Is there a way to speed up this computation by using MPI perhaps or some other technique?
Below is a snippet of my code that outlines the eigensolver settings.
#Set up variational formulation
u = TrialFunction(Vh)
v = TestFunction(Vh)
a = inner(grad(u), grad(v))*dx + V*u*v*dx
b = u*v*dx
#Assemble stiffness and mass matrices.
A = PETScMatrix()
assemble(a, tensor=A)
B = PETScMatrix()
assemble(b, tensor=B)
#Set up SLEPc eigenvalue solver
eps = SLEPc.EPS()
eps.create()
eps.setOperators(A.mat(), B.mat())
eps.setProblemType(SLEPc.EPS.ProblemType.GHEP)
eps.setTarget(0.)
eps.setDimensions(nreq)
eps.setType(SLEPc.EPS.Type.KRYLOVSCHUR)
st = eps.getST()
st.setType(SLEPc.ST.Type.SINVERT)
ksp = st.getKSP()
ksp.setType(PETSc.KSP.Type.PREONLY)
pc = ksp.getPC()
pc.setType(PETSc.PC.Type.CHOLESKY)
#Solve the eigenvalue problem
start = time.time()
eps.solve()
nconv = eps.getConverged()
print("Number of eigenpair converged = {}".format(nconv))
end = time.time()
print("Time elapsed "+str(end-start)+" s")
Thanks in advance!
