Hello everyone,
I’m trying to solve a problem and I’m stuck on this error and your help will be very useful.
This is actually a mechanics problem where the two sub-domains are defined by different materials and each will have a displacement u1 and u2. The lower part of the large cube is fixed and the upper part moves. To ensure continuity at the contact surfaces between the two solids, I used the Nitsche formulation. To solve this problem, I created the geometry in Gmsh and imported it into fenics using dolfin convert. only, I get this error and I don’t know how to solve it. has anyone ever solved such a problem?
your help will be very useful. thank you in advance.
here is the gmsh and fenics code.
Here is the Gmsh code
// Define parameters
SetFactory("OpenCASCADE");
Coherence;
lc = 0.09; // Characteristic mesh size
// Define points
Point(1) = {-0.5, -0.5, 0, lc};
Point(2) = {0.5, -0.5, 0, lc};
Point(3) = {0.5, 0.5, 0, lc};
Point(4) = {-0.5, 0.5, 0, lc};
Point(5) = {-0.25, -0.25, 0, lc};
Point(6) = {0.25, -0.25, 0, lc};
Point(7) = {0.25, 0.25, 0, lc};
Point(8) = {-0.25, 0.25, 0, lc};
// Define lines
Line(1) = {1, 2};
Line(2) = {2, 3};
Line(3) = {3, 4};
Line(4) = {4, 1};
Line(5) = {5, 6};
Line(6) = {6, 7};
Line(7) = {7, 8};
Line(8) = {8, 5};
// Define plane surfaces
Line Loop(1) = {1, 2, 3, 4};
Plane Surface(1) = {1};
Line Loop(2) = {5, 6, 7, 8};
Plane Surface(2) = {2};
// Extrude surfaces to create 3D solids
Extrude {0, 0, 0.15} {
Surface{1};
Surface{2};
// Subtract smaller cube from larger cube
t[] = Extrude {0, 0, 0.15} { Surface{2}; };
solid[] = BooleanDifference{ Volume{1}; Delete; }{ Volume{2}; Delete; };
Physical Surface(1) = {23}; // moving boundary
Physical Surface(2) = {18};// fixed boundary
Physical Surface(3) = {8}; // contact surface 1
Physical Surface(4) = {11}; // contact surface 2
Physical Surface(5) = {10}; // contact surface 3
Physical Surface(6) = {9}; // contact surface 4
Physical Volume(1) = {1};
Physical Volume(2) = {3};
Here is the FEniCS code
import os
os.system('dolfin-convert domain.msh domain.xml')
mesh = Mesh("domain.xml")
bdry = MeshFunction("size_t", mesh, "domain_facet_region.xml")
subdomains = MeshFunction("size_t", mesh, "domain_physical_region.xml")
mesh1 = SubMesh(mesh, subdomains, 1)
mesh2 = SubMesh(mesh, subdomains, 2)
ds = Measure("ds", subdomain_data=bdry)
dx = Measure("dx", subdomain_data=subdomains)
n1 = FacetNormal(mesh1)
n2 = FacetNormal(mesh2)
# Define function spaces for each solid
V1 = VectorFunctionSpace(mesh1, 'P', 1)
V2 = VectorFunctionSpace(mesh2, 'P', 1)
# Define material parameters
mu1 = Constant(1.0) # Shear modulus for solid 1
mu2 = Constant(0.8) # Shear modulus for solid 2
beta = Constant(10.0) # Penalty parameter
# Define test and trial functions for each solid
u1 = TrialFunction(V1)
v1 = TestFunction(V1)
u2 = TrialFunction(V2)
v2 = TestFunction(V2)
# Define boundary conditions for solid 1
bc1_fixe = DirichletBC(V1, Constant((0.0, 0.0, 0.0)), 'near(x[1], -0.5) && on_boundary') # Surface fixe
g = Constant((0.0, 0.0, -0.1)) # Prescribed displacement vector
bc1_prescrit = DirichletBC(V1, g, 'near(x[1], 0.5) && on_boundary') # Surface avec déplacement prescrit
# Define strain and stress for each solid
return sym(grad(u))
def sigma(u, mu):
return 2.0 * mu * epsilon(u)
# Define variational problem for solid 1
u1 = Function(V1)
du1 = TrialFunction(V1)
a1 = inner(sigma(du1, mu1), grad(v1)) * dx(1) + sum(beta * dot(jump(du1), jump(v1)) * dS(i) for i in range(3, 6))
L1 = Constant(0.0) * dot(v1, n1) * (ds(1) + ds(2)) # No Neumann boundary conditions on other surfaces
# Define variational problem for solid 2
u2 = Function(V2)
du2 = TrialFunction(V2)
a2 = inner(sigma(du2, mu2), grad(v2)) * dx(2) + sum(beta * dot(jump(du2), jump(v2)) * dS(i) for i in range(3, 6))
L2 = Constant(0.0) * dot(v2, n2) * (ds(3) + ds(4) + ds(5) + ds(6)) # No Neumann boundary conditions on other surfaces
# Define nonlinear variational problem
F1 = derivative(a1, u1, du1)
F2 = derivative(a2, u2, du2)
problem1 = NonlinearVariationalProblem(F1, u1, [bc1_fixe, bc1_prescrit], J=assemble(derivative(F1, u1)))
problem2 = NonlinearVariationalProblem(F2, u2, [], J=assemble(derivative(F2, u2)))
# Solve nonlinear variational problems using Newton's method
solver1 = NonlinearVariationalSolver(problem1)
solver2 = NonlinearVariationalSolver(problem2)
solver1.solve()
solver2.solve()
# Save solutions
u1.rename("Displacement_Solid1", "label")
u2.rename("Displacement_Solid2", "label")
vtkfile1 = File('solid1_displacement.pvd')
vtkfile1 << u1
vtkfile2 = File('solid2_displacement.pvd')
vtkfile2 << u2
here is the error
*** Error: Unable to extract mesh from form.
*** Reason: Non-matching meshes for function spaces and/or measures.
*** Where: This error was encountered inside Form.cpp.
*** Process: 0
*** Git changeset: unknown
Thank you in advance for your helps.
