Adding a crack seems to mess up the node ordering. Consider the indices array. The values there range range from 0 to 50, while you only have 43 points in points.shape.
You would need to renumber the topology.
I’ve done this below.
import dolfinx.io.gmshio as gmshio
from dolfinx.io.utils import distribute_entity_data
L = 1
H = 0.1
l = 0.05 #length of the crack
lc = 0.01 # mesh size around the crack
tdim = 2 #domain dimension
gdim = 2
# Initialise gmsh and set options
model = gmsh.model()
# surface without crack
s = model.occ.addRectangle(0.0, 0.0, 0.0, H, L)
# crack
p4 = model.occ.addPoint(H / 2, L / 2 - l / 2, 0, lc, tag=10)
p5 = model.occ.addPoint(H / 2, L / 2 + l / 2, 0, lc, tag=11)
crack = model.occ.addLine(p4, p5, tag=12)
o, m = gmsh.model.occ.fragment([(tdim, s)], [(tdim - 1, crack)])
model.occ.synchronize()
new_surf = m[0][0][1]
model.addPhysicalGroup(tdim, [new_surf], 100)
model.setPhysicalName(tdim, new_surf, "Rectangular surface")
model.addPhysicalGroup(tdim - 1, [12], tag=12)
model.setPhysicalName(tdim - 1, 12, "crack")
gmsh.model.addPhysicalGroup(0, [p4], 13)
model.mesh.generate(tdim)
indices1, points1, _ = model.mesh.getNodes()
gmsh.plugin.setNumber("Crack", "Dimension", tdim - 1)
gmsh.plugin.setNumber("Crack", "PhysicalGroup", 12)
gmsh.plugin.setNumber("Crack", "DebugView", tdim - 1)
gmsh.plugin.setNumber("Crack", "OpenBoundaryPhysicalGroup", 13)
gmsh.plugin.run("Crack")
indices, points, _ = model.mesh.getNodes()
points = points.reshape(-1, 3)
# Gmsh indices starts at 1. We therefore subtract one to use
# zero-based numbering
indices -= 1
# In some cases, Gmsh does not return the points in the same
# order as their unique node index. We therefore sort nodes in
# geometry according to the unique index
perm_sort = np.argsort(indices)
points = points[perm_sort]
# Remap missing points to a contiguous index
index_to_renumbered = np.full(int(indices[perm_sort[-1]]+1), -1, dtype=np.int64)
index_to_renumbered[indices[perm_sort]] = np.arange(len(indices))
topologies = gmshio.extract_topology_and_markers(model)
comm = MPI.COMM_WORLD
rank = 0
for key, val in topologies.items():
val["topology"] = index_to_renumbered[val["topology"]]
# Extract Gmsh cell id, dimension of cell and number of nodes to
# cell for each
num_cell_types = len(topologies.keys())
cell_information = dict()
cell_dimensions = np.zeros(num_cell_types, dtype=np.int32)
for i, element in enumerate(topologies.keys()):
_, dim, _, num_nodes, _, _ = model.mesh.getElementProperties(element)
cell_information[i] = {"id": element, "dim": dim, "num_nodes": num_nodes}
cell_dimensions[i] = dim
# Sort elements by ascending dimension
perm_sort = np.argsort(cell_dimensions)
# Broadcast cell type data and geometric dimension
cell_id = cell_information[perm_sort[-1]]["id"]
tdim = cell_information[perm_sort[-1]]["dim"]
num_nodes = cell_information[perm_sort[-1]]["num_nodes"]
cell_id, num_nodes = comm.bcast([cell_id, num_nodes], root=rank)
# Check for facet data and broadcast relevant info if True
has_facet_data = False
if tdim - 1 in cell_dimensions:
has_facet_data = True
dtype = dolfinx.default_real_type
has_facet_data = comm.bcast(has_facet_data, root=rank)
if has_facet_data:
num_facet_nodes = comm.bcast(cell_information[perm_sort[-2]]["num_nodes"], root=rank)
gmsh_facet_id = cell_information[perm_sort[-2]]["id"]
marked_facets = np.asarray(topologies[gmsh_facet_id]["topology"], dtype=np.int64)
facet_values = np.asarray(topologies[gmsh_facet_id]["cell_data"], dtype=np.int32)
cells = np.asarray(topologies[cell_id]["topology"], dtype=np.int64)
cell_values = np.asarray(topologies[cell_id]["cell_data"], dtype=np.int32)
cell_id, num_nodes = comm.bcast([None, None], root=rank)
cells, x = np.empty([0, num_nodes], dtype=np.int32), np.empty([0, gdim], dtype=dtype)
cell_values = np.empty((0,), dtype=np.int32)
has_facet_data = comm.bcast(None, root=rank)
if has_facet_data:
num_facet_nodes = comm.bcast(None, root=rank)
marked_facets = np.empty((0, num_facet_nodes), dtype=np.int32)
facet_values = np.empty((0,), dtype=np.int32)
# Create distributed mesh
ufl_domain = gmshio.ufl_mesh(cell_id, gdim, dtype=dtype)
gmsh_cell_perm = gmshio.cell_perm_array(dolfinx.cpp.mesh.to_type(str(ufl_domain.ufl_cell())), num_nodes)
cells = cells[:, gmsh_cell_perm].copy()
mesh = dolfinx.mesh.create_mesh(comm, cells, points[:, :gdim].astype(dtype, copy=False), ufl_domain)
# Create MeshTags for cells
local_entities, local_values = distribute_entity_data(
mesh._cpp_object, mesh.topology.dim, cells, cell_values
mesh.topology.create_connectivity(mesh.topology.dim, 0)
adj = dolfinx.cpp.graph.AdjacencyList_int32(local_entities)
ct = dolfinx.mesh.meshtags_from_entities(
mesh, mesh.topology.dim, adj, local_values.astype(np.int32, copy=False)
ct.name = "Cell tags"
# Create MeshTags for facets
topology = mesh.topology
tdim = topology.dim
if has_facet_data:
# Permute facets from MSH to DOLFINx ordering
# FIXME: This does not work for prism meshes
if topology.cell_type == dolfinx.mesh.CellType.prism or topology.cell_type == dolfinx.mesh.CellType.pyramid:
raise RuntimeError(f"Unsupported cell type {topology.cell_type}")
facet_type = dolfinx.cpp.mesh.cell_entity_type(
dolfinx.cpp.mesh.to_type(str(ufl_domain.ufl_cell())), tdim - 1, 0
gmsh_facet_perm = gmshio.cell_perm_array(facet_type, num_facet_nodes)
marked_facets = marked_facets[:, gmsh_facet_perm]
mesh._cpp_object, tdim - 1, marked_facets, facet_values
mesh.topology.create_connectivity(topology.dim - 1, tdim)
ft = dolfinx.mesh.meshtags_from_entities(mesh, tdim - 1, adj, local_values.astype(np.int32, copy=False))
ft.name = "Facet tags"
ft = dolfinx.mesh.meshtags(mesh, tdim - 1, np.empty(0, dtype=np.int32), np.empty(0, dtype=np.int32))
print("Crack surface", dolfinx.fem.assemble_scalar(dolfinx.fem.form(1*ufl.ds(domain=mesh, subdomain_data=ft, subdomain_id=12))),2*l)
print("vol", dolfinx.fem.assemble_scalar(dolfinx.fem.form(1*ufl.dx(domain=mesh))),L*H)
print(dolfinx.fem.assemble_scalar(dolfinx.fem.form(1*ufl.ds(domain=mesh))),2*(L+H+l))
# b_indices = dolfinx.mesh.exterior_facet_indices(mesh.topology)
# ft = dolfinx.mesh.meshtags(mesh, mesh.topology.dim-1, b_indices, np.arange(len(b_indices), dtype=np.int32))
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, "mesh.xdmf", "w") as xdmf:
xdmf.write_mesh(mesh)
xdmf.write_meshtags(ct, mesh.geometry)
xdmf.write_meshtags(ft, mesh.geometry)
It seems like the crack in the mesh is slightly bigger than what has been marked with 12.
I do not have time to debug this further today.
