Runtime Error, fenics.2019.**. How can I solve this problem?
File
"/home/Fenics/Code_Python_cluster/Sintering/PolyParticle.py", line 725, in <module>
    solve(CH_WeakForm_L == CH_WeakForm_R, u_new, solver_parameters=PhaseFields_params)
  File "/home/anaconda3/envs/fenics11/lib/python3.11/site-packages/dolfin/fem/solving.py", line 220, in solve
  File "/home/anaconda3/envs/fenics11/lib/python3.11/site-packages/dolfin/fem/solving.py", line 247, in _solve_varproblem
    solver.solve()
RuntimeError:
*** Error:   Unable to solve linear system using PETSc Krylov solver.
*** Reason:  Solution failed to converge in 10000 iterations (PETSc reason DIVERGED_ITS, residual norm ||r|| = 7.672363e+80).
*** Where:   This error was encountered inside PETScKrylovSolver.cpp.
*** Process: 0
*** DOLFIN version: 2019.1.0
The solver I choose for this equataion is:
PhaseFields_params = {'linear_solver': 'tfqmr', 'preconditioner': 'ilu'}
Please read Read before posting: How do I get my question answered?
As a first step, you may want to change your PhaseFields_params to use a direct solver, and see if that works or not.
