Occurence of error "Unable to successfully call PETSc function 'MatSetValuesLocal"
Dear. Researchers
I aim at solving two coupled time-dependent problems via the following code. upon execution of the code I have received the following error:
rror: Unable to successfully call PETSc function ‘MatSetValuesLocal’.
*** Reason: PETSc error code is: 63 (Argument out of range).
*** Where: This error was encountered inside /home/conda/feedstock_root/build_artifacts/fenics-pkgs_1739259282872/work/dolfin/la/PETScMatrix.cpp.
*** Process: 0
I am not sure if this error stems from implementation or it possesses an external cause with PETSC. I would be thankful to assess the issue and give me your feedback.
import random
from ufl.algorithms.formtransformations import compute_form_arities
from ufl.algorithms import expand_derivatives
dt     = 1e-1 # time step
theta  = 0.5      # time stepping family, e.g. theta=1 -> backward Euler, theta=0.5 -> Crank-Nicolson
mesh = RectangleMesh(Point(0,0), Point(200,200), 100,100)
P1 = FiniteElement("Lagrange", triangle, 1)
ME = FunctionSpace(mesh,MixedElement(P1, P1, P1))
mesh_file = File("Mesh1D.xml")
mesh_file << mesh
plt.figure()
plot(mesh, title = "domain")
# Define functions
u   = Function(ME)  # current solution
u0  = Function(ME)  # solution from previous converged step
du    = TrialFunction(ME)
v1 ,v2, v3 = TestFunctions(ME)
u1, u2, u3 = split(u)
r1, s1, t1 = split(u0)
du1, du2, du3 = split(du)
class K(UserExpression):
      def eval(self, values, x):
          c0 = 0.5
          eps = 0.01
          eps_eta = 0.1
          Psi = 1.5
          values[0] = cos(x[0])*cos(x[1])
          values[1] = 0.0
          values[2] = cos(x[0]) * cos(x[0])
      def value_shape(self):
          return(3, )
order_value = K(mesh)
u = interpolate(order_value, ME)
u0.assign(u)
#define parameters
c_alpha = Constant(0.3)
c_beta = Constant(0.7)
ro_s = sqrt(2)
M = Constant(5)
L = Constant(5)
kappa_c = Constant(3)
kappa_eta = Constant(3)
w = Constant(1)
alpha = Constant(5)
u1 = variable(u1)
f_a = (ro_s**2)*(u1 - c_alpha)**2
f_b = (ro_s**2)*(c_beta - u1)**2
fder_a = diff(f_a , u1)
fder_b = diff(f_b, u1)
# define swtiching function
u3 = variable(u3)
hfunction = (u3**3*(6*u3**2 - 15*u3 + 10))
g = ((u3**2)*(1-u3)**2)
fchem = (f_a * (1 - hfunction) + f_b * hfunction + w*g)
fchem_c = diff(fchem,u1)
fchem_eta1 = diff(fchem,u3)
Form_cons= u1*v1*dx - r1*v1*dx + dt*M*inner(grad(u2), grad(v1))*dx
Form_mu = u2*v2*dx - fchem_c*v2*dx - kappa_c*inner(grad(u1), grad(v2))*dx
Form_eta1 = (u3*v3*dx - t1*v3*dx + dt*L*fchem_eta1*v3*dx +
            L*kappa_eta*dt*inner(grad(u3), grad(v3))*dx)
Form = Form_cons + Form_mu + Form_eta1
Gain = derivative(Form, u, du)
t = 0.0
T = 1000*dt
while (t < T):
    solve(Form == 0, u , J = Gain)
    u0.assign(u)
You have defined u twice.
Both here
The latter one should be u.interpolate(order_value)
Otherwise you differentiate F with respect to a variable that is not in your variational form.
Dear. Dr. Dokken
Thanks for your prompt response. After applying modification, the code worked but the convergence behavior was not achieved. To remedy the issue, I changed the nonlinear solver to SNES but not effective. Since I adopted all the parameter from a benchmark I expect normal solution with good convergence behavior. I am so grateful if you assess the updated code and give me your feedback.
import random
mesh_file << mesh
plt.figure()
# Define functions
          c0 = 0.5
          eps = 0.01
          eps_eta = 0.1
          Psi = 1.5
          values[0] = cos(x[0]) * cos(x[1])
          values[1] = 0.0
          values[2] = cos(x[0])*cos(x[1])
          return(3, )
file1 = File("xglobal_ini.pvd")
file2 = File("chemical potential.pvd")
file3 = File("eta1_ini.pvd")
file1 << u.split(deepcopy= True)[0]
file2 << u.split(deepcopy= True)[1]
file3 << u.split(deepcopy= True)[2]
u0.assign(u)
#define parameters
c_alpha = 0.3
c_beta = 0.7
ro_s = sqrt(2)
M = Constant(5)
L = Constant(5)
w = Constant(1)
alpha = Constant(5)
u1 = variable(u1)
u3 = variable(u3)
Form_cons = u1*v1*dx - r1*v1*dx + dt*M*inner(grad(u2), grad(v1))*dx
Formt = (u3*v3*dx - t1*v3*dx +
Form = Form_cons + Form_mu + Formt
problem = NonlinearVariationalProblem(Form, u, J = Gain)
solver.parameters['nonlinear_solver'] = 'snes'
solver.parameters['snes_solver']['linear_solver'] = 'mumps'
solver.parameters['snes_solver']['report'] = True
solver.parameters['snes_solver']['line_search'] = 'bt'
solver.parameters['snes_solver']['error_on_nonconvergence'] = False
solver.parameters['snes_solver']['absolute_tolerance'] = 1e-6
t = 0.0
T = 1000*dt
while (t < T):
    solver.solve()
    u0.assign(u)
