Error using Non-Linear Poisson in Complex Fenicsx. Arity Mismatch
I have a Non-Linear Poisson Solver in the complex Fenicsx type. I get an error when using the Non-Linear function. My code is
def rho_pointwise(self, phi):
    # Constants
    kB = 1.380649e-23  # [J/K]
    T = 300.0          # [K]
    KT = kB * T / 1.6e-19  # [eV]
    kbT = fem.Constant(self.domain, PETSc.ScalarType(KT - 0j))
    qval = fem.Constant(self.domain, PETSc.ScalarType(1.6e-19 - 0j))
    # Take real parts for physical calculations
    phi_real = ufl.real(phi)
    chi_real = ufl.real(self.chi)
    Eg_real = ufl.real(self.Eg)
    Nc_real = ufl.real(self.Nc)
    Nv_real = ufl.real(self.Nv)
    phiref_real = ufl.real(self.phiref)
    Ef_real = ufl.real(self.Ef)
    kbT_real = ufl.real(kbT)
    # Compute band edges (now real-valued)
    Ec = -(phi_real - phiref_real + chi_real)  # conduction band edge [eV]
    Ev = Ec - Eg_real                          # valence band edge [eV]
    # Fermi level relative to bands
    xe = (Ef_real - Ec) / kbT_real
    xh = (Ev - Ef_real) / kbT_real
    def fermi_approx_smooth(x):
        exp_part = ufl.exp(ufl.min_value(x, 50.0))  # Clamped exponential
        power_part = 0.7523 * (ufl.sqrt((x**2 + 1e-6)))**1.5  # Always positive argument
        # Transition around x = 2.5
        transition_point = 2.5
        transition_width = 2.0
        # Sigmoid function for smooth blending: 0 at -inf, 1 at +inf
        blend = 0.5 * (1.0 + ufl.tanh((x - transition_point) / transition_width))
        return (1.0 - blend) * exp_part + blend * power_part
    # Carrier densities (all real-valued)
    nval = Nc_real * fermi_approx_smooth(xe)
    pval = Nv_real * fermi_approx_smooth(xh)
    # Charge density (real-valued expression)
    rho = ufl.real(qval) * (pval - nval)
    return rho
def nonlin_solve(self, gate_voltages, ohmic_gate_name, save_file=True, max_iterations=10, tol=1e-9):
    # Create function space and functions
    V = fem.functionspace(self.domain, ('Lagrange', 1))
    phi = fem.Function(V, dtype=np.complex128)  # Solution (complex-valued)
    v = ufl.TestFunction(V)      # Test function
    u = ufl.TrialFunction(V)     # Trial function (for both linear and Newton increment)
    tdim = self.domain.topology.dim
    fdim = tdim - 1
    bcs = []
    for gate_name, voltage in gate_voltages.items():
        if gate_name not in self.device.facet_tags_map:
            continue
        tag = self.device.facet_tags_map[gate_name]
        dofs = fem.locate_dofs_topological(V, fdim, self.device.facet_tags.find(tag))
        if len(dofs) == 0:
            continue
        phi_v = voltage - (4.33 - 2.7)
        bc = fem.dirichletbc(np.complex128(phi_v + 0j), dofs, V)
        bcs.append(bc)
        if self.domain.comm.rank == 0:
            print(f"{gate_name:<20} {phi_v:>10.3f} V {len(dofs):>8}")
    phi.x.array[:] = 0.0
    F = self.eps*ufl.inner(ufl.grad(phi), ufl.grad(v))*ufl.dx - self.rho_pointwise(phi)*v*ufl.dx
    J = ufl.derivative(F, phi, ufl.conj(v))
    problem = NonlinearProblem(F, phi, bcs=bcs, J=J, petsc_options_prefix="nonlinear_poisson_")
The error that i get is
self._F = _create_form(
raise ArityMismatch(
ufl.algorithms.check_arities.ArityMismatch: Adding expressions with non-matching form arguments (‘v_0’,) vs (‘conj(v_0)’,).
Exception ignored in: <function NonlinearProblem.del at 0x146e13735800>
lambda obj: obj is not None, (self._snes, self._A, self._b, self._x, self._P_mat)
AttributeError: ‘NonlinearProblem’ object has no attribute ‘_snes’
Thank you
I don’t have time to check your code, but your formulation looks a bit strange:
Bear in mind that
(a, b) = \int_\Omega a \cdot \overline{b} \; \mathrm{d}\mathbf{x}
So I would be expecting something like
    F = ufl.inner(self.eps*ufl.grad(phi), ufl.grad(v))*ufl.dx - ufl.inner(self.rho_pointwise(phi), v)*ufl.dx
    J = ufl.derivative(F, phi, v)
Sorry, yes it is
But even with these changes I get the same error.
So it looks like the earlier issue was caused by importing NewtonSolver from the wrong module. Switching to
resolved the ArityMismatch error.
However, I’m now running into a problem when I use any ufl.conditional (or ufl.lt/le/min/max ) with complex-valued UFL expressions. I tried converting the expression to its real part for the comparison, but the generated FFCx code still attempts to evaluate the comparison on a complex value and fails at compile time.
I’ve attached my updated code below. The error I see is:
libffcx_forms_...c:880:32: error: invalid operands to binary < (have ‘complex double’ and ‘double’)
  bool sv_... = sv_... < 5.0;
Code snippet:
from dolfinx import fem, io, nls, log
V = fem.functionspace(domain, ('Lagrange', 1))
dphi = ufl.TrialFunction(V)
def rho_test(phi):
    kB = 1.380649e-23
    T  = 10.0
    KT = kB*T/1.6e-19
    kbT = KT
    q   = 1.6e-19
    Ec = -(phi - phiref + chi)
    Ev = Ec - Eg
    xe = (Ef - Ec) / kbT
    xh = (Ev - Ef) / kbT
    def cond_real(x):
        x_real = ufl.real(x)
        return ufl.conditional(ufl.lt(x_real, 5.0),
                               ufl.exp(x_real),
                               0.7523 * (x_real**1.0))
    Xe_real = cond_real(xe)
    Xp_real = cond_real(xh)
    n = Nc * Xe_real
    p = Nv * Xp_real
    return q * (p - n)
F = ufl.inner(eps*ufl.grad(phi), ufl.grad(v))*ufl.dx - rho_test(phi)*ufl.conj(v)*ufl.dx
J = ufl.derivative(F, phi, dphi)
petsc_options = {
    "snes_type": "newtonls",
    "snes_linesearch_type": "none",
    "snes_atol": 1e-6,
    "snes_rtol": 1e-5,
    "snes_monitor": None,
    "ksp_error_if_not_converged": True,
    "ksp_type": "gmres",
    "ksp_rtol": 1e-8,
    "ksp_monitor": None,
    "pc_type": "hypre",
    "pc_hypre_type": "boomeramg",
    "pc_hypre_boomeramg_max_iter": 1,
    "pc_hypre_boomeramg_cycle_type": "v",
problem = NonlinearProblem(F, phi, J=J, bcs=bcs,
                           petsc_options=petsc_options,
phi = problem.solve()
Could you please advise whether there is a supported approach for implementing conditionals in complex mode or an alternative strategy to avoid this compilation error or if I am missing something entirely?
Thank you,
Kelvin
