Error when importing msh from gmsh
HI, I was using a code written in 2021 by importing mesh from fenics and converting it to xml format using meshio-convert. Since I wanted to move to using xdmf format I used the following code from this forum.
msh = meshio.read("Rec_geo.msh")
for cell in msh.cells:
    if cell.type == "triangle":
        triangle_cells = cell.data
    elif  cell.type == "tetra":
        tetra_cells = cell.data
    if key == "triangle":
    elif key == "tetra":
        tetra_data = msh.cell_data_dict["gmsh:physical"][key]
#tetra_mesh = meshio.Mesh(points=msh.points, cells={"tetra": tetra_cells})
triangle_mesh =meshio.Mesh(points=msh.points,
#meshio.write("Rec_geo.xdmf", tetra_mesh)
meshio.write("Rgeo.xdmf", triangle_mesh)
Now I used the following code to import the mesh and tried to test if I can run.
from math import degrees
from operator import not_
import dolfin as df
from dolfin.fem.interpolation import interpolate
from dolfin.function.constant import Constant
import os
from numpy.core.fromnumeric import diagonal
from numpy.core.numeric import True_
from numpy.lib.twodim_base import _trilu_indices_form_dispatcher
import ufl as ufl
model = "plane_stress"
E = df.Constant(110000.)
nu = df.Constant(0.3)
mu = E / (2 * (1 + nu))
lmbda = (E * nu) / ((1 + nu) * (1 - 2 * nu))
if model == "plane_stress":
    lmbda = 2 * mu * lmbda / (lmbda + 2 * mu)
def eps(v):
    return df.sym(df.grad(v))
def sigmaE(v, lmbda, mu):
    sigE = lmbda * df.tr(eps(v)) * df.Identity(2) + 2.0 * mu * eps(v)
    return sigE
def sigmaA(v, sigA, lmbda, mu):
    sig = sigA + lmbda * df.tr(eps(v)) * df.Identity(2) + 2.0 * mu * eps(v)
    return sig
def load_mesh(mesh_file):
    mesh = df.Mesh()
    with df.XDMFFile(mesh_file) as infile:
        infile.read(mesh)
        # These are the markers
        ffun = df.MeshFunction("size_t", mesh, 2)
        infile.read(ffun, "name_to_read")
    return mesh, ffun
#mesh, ffun = load_mesh('Rgeo.xdmf')
mesh = df.RectangleMesh(df.Point(0,0),df.Point(10,5),10,5,diagonal="right")
V0 = df.VectorFunctionSpace(mesh, "Lagrange", degree=2)#,dim=2)#,form_degree=3)
V0sig = df.TensorFunctionSpace(mesh, 'DG', degree=2)#,shape=(2,2))
def sigA_init_turning(V,Coef_sig_A):
    ep = np.array(V.tabulate_dof_coordinates())[:, 1].max() - np.array(V.tabulate_dof_coordinates())[:, 1].min()
    x_1 = [0,0.015,0.025,0.035,0.05,0.065,0.075,0.08,0.085,0.09,0.095,0.1,0.105,0.11,0.115,0.12,0.125,0.13,0.135]
    y = [500,50,-250,-330,-300,-210,-210,-210,-210,-210,-210,-210,-210,-210,-210,-210,-210,-210,-210]
    fL= np.polyfit(x_1,y,7)
    p = np.poly1d(fL)
    s1=fL[0]
    s2=fL[1]
    s3=fL[2]
    s4=fL[3]
    s5=fL[4]
    s6=fL[5]
    s7=fL[6]
    s8=fL[7]
    depth = df.Expression('ep - x[1]', degree=1, ep=ep)
    #sig_xx = df.Expression('x[1]^7 + s1',degree = 1,s1=s1)
    sig_xx = df.Expression('s1 * y * y*y*y*y*y*y+ s2 * y*y*y*y*y*y\
     + s3 * y*y*y*y*y + s4 * y*y*y*y + s5 * y*y*y + s6* y*y + s7 * y + s8'\
    ,degree=1,s1=s1,s2=s2,s3=s3,s4=s4,s5=s5,s6=s6,s7=s7,s8=s8,y=depth)
    sigA = df.Expression((('d <= d1 ? sigA_xx : 0.0', 'd <= d1 ? 0. : 0.'), \
                          ('d <= d1 ? 0. : 0.', 'd <= d1 ? 0. : 0.')), \
                         degree=1, ep=ep, d=depth, d1=0.135,sigA_xx=sig_xx)
    return sigA
sigfun = sigA_init_turning(V0,0)
df.project(sigfun,V0sig)
du = df.TrialFunction(V0)
u_ = df.TestFunction(V0)
val=sigmaE(du, lmbda, mu)
#a = df.inner(sigmaE(du, lmbda, mu), eps(u_)) * df.dx
value=(df.grad(du))
print((value))
Now I receive the following error.
Invalid MIT-MAGIC-COOKIE-1 keyShapes do not match: <Argument id=140057592358176> and <Coefficient id=140057551284608>.
  File "testing.py", line 71, in <module>
  File "/usr/lib/petsc/lib/python3/dist-packages/dolfin/fem/projection.py", line 129, in project
    L = ufl.inner(w, v) * dx
  File "/usr/lib/python3/dist-packages/ufl/operators.py", line 158, in inner
    return Inner(a, b)
  File "/usr/lib/python3/dist-packages/ufl/tensoralgebra.py", line 147, in __new__
    error("Shapes do not match: %s and %s." % (ufl_err_str(a), ufl_err_str(b)))
  File "/usr/lib/python3/dist-packages/ufl/log.py", line 158, in error
ufl.log.UFLException: Shapes do not match: <Argument id=140057592358176> and <Coefficient id=140057551284608>.
I also tried enforcing the shape of the element.(these portions are commented), but they don’t seem to work either. If I use the mesh generated using df.rectangularMesh() there seems to be no error.
I found a workaround by defining the gradient in 2D which I would like to avoid to make the program more abstract. It would be helpful if someone can explain why the error happenes when I use *.xdmf for mesh input.
PS : mesh files generated in 2021 using gmsh the same method worked very well.
You need to remove the third dimension of msh.points as done in:
