Error when solving ocp with ode as a state equation
Hi everyone,
I am trying to solve an optimal control problem with an ode as a state equation. when simply solving the ode, I get the solution over all the vertices of the domain; but when I try to solve the optimal control problem, I am getting an error. Below is the code
from dolfin import*
from dolfin_adjoint import*
from collections import OrderedDict
mesh = UnitSquareMesh(10, 10)
V = FunctionSpace(mesh, "CG", 1)  # Linear function space
time = Constant(0.0)
time = float(time)
final_time = 2.0
dt = Constant(0.1)
ctrls = OrderedDict()
tt = []
while time <= final_time:
    ctrls[time] = Function(V)
    tt.append(time)
    time = round( (time + float(dt)), 1 )
y_desired = Function(V, name="desired state")
y = TrialFunction(V)
t = Constant(0.0)
form = 2*t*ctrls[float(t)]*v*dP    # variational form
y = project( Constant(2.0), V )
scheme = RK4(form, y, t)
ode_solver = PointIntegralSolver(scheme)
J = 0
num_step = int(final_time/float(dt))
for i in range(num_step):
    t1 = round( (float(t) + float(dt)), 1 )
    ode_solver.step(dt)
    J += 0.5*float(dt)*assemble( (y-y_desired)**2*dP )   # continuous time integral discretized an we obtain a discrete sum
    t.assign(t1)
m = [Control(ctrls[i]) for i in tt]
reduced_functional = ReducedFunctional(J, m)
m_opt = minimize(reduced_functional, method='L-BFGS-B')
Here is the error I am getting:
Not an UFL type: <class 'ufl.form.Form'>
UFLException                              Traceback (most recent call last)
<ipython-input-15-c180f0adc09d> in <module>
----> 1 m_opt = minimize(reduced_functional, method='L-BFGS-B')
~/.local/lib/python3.9/site-packages/pyadjoint/tape.py in wrapper(*args, **kwargs)
    107     def wrapper(*args, **kwargs):
    108         with stop_annotating():
--> 109             return function(*args, **kwargs)
    110
    111     return wrapper
~/.local/lib/python3.9/site-packages/pyadjoint/optimization/optimization.py in minimize(rf, method, scale, **kwargs)
    249         kwargs["method"] = method
    250
--> 251     opt = algorithm(rf_np, **kwargs)
    252
    253     if len(opt) == 1:
~/.local/lib/python3.9/site-packages/pyadjoint/optimization/optimization.py in minimize_scipy_generic(rf_np, method, bounds, **kwargs)
    132         res = scipy_minimize(J, m_global, method=method, bounds=bounds, **kwargs)
    133     else:
--> 134         res = scipy_minimize(J, m_global, method=method, **kwargs)
    135
    136     m = rf_np.set_controls(np.array(res["x"]))
/usr/lib/python3/dist-packages/scipy/optimize/_minimize.py in minimize(fun, x0, args, method, jac, hess, hessp, bounds, constraints, tol, callback, options)
    617                                   **options)
    618     elif meth == 'l-bfgs-b':
--> 619         return _minimize_lbfgsb(fun, x0, args, jac, bounds,
    620                                 callback=callback, **options)
    621     elif meth == 'tnc':
/usr/lib/python3/dist-packages/scipy/optimize/lbfgsb.py in _minimize_lbfgsb(fun, x0, args, jac, bounds, disp, maxcor, ftol, gtol, eps, maxfun, maxiter, iprint, callback, maxls, finite_diff_rel_step, **unknown_options)
    304             iprint = disp
    305
--> 306     sf = _prepare_scalar_function(fun, x0, jac=jac, args=args, epsilon=eps,
    307                                   bounds=new_bounds,
    308                                   finite_diff_rel_step=finite_diff_rel_step)
/usr/lib/python3/dist-packages/scipy/optimize/optimize.py in _prepare_scalar_function(fun, x0, jac, args, bounds, epsilon, finite_diff_rel_step, hess)
    259     # ScalarFunction caches. Reuse of fun(x) during grad
    260     # calculation reduces overall function evaluations.
--> 261     sf = ScalarFunction(fun, x0, args, grad, hess,
    262                         finite_diff_rel_step, bounds, epsilon=epsilon)
    263
/usr/lib/python3/dist-packages/scipy/optimize/_differentiable_functions.py in __init__(self, fun, x0, args, grad, hess, finite_diff_rel_step, finite_diff_bounds, epsilon)
    134
    135         self._update_fun_impl = update_fun
--> 136         self._update_fun()
    137
    138         # Gradient evaluation
/usr/lib/python3/dist-packages/scipy/optimize/_differentiable_functions.py in _update_fun(self)
    224     def _update_fun(self):
    225         if not self.f_updated:
--> 226             self._update_fun_impl()
    227             self.f_updated = True
    228
/usr/lib/python3/dist-packages/scipy/optimize/_differentiable_functions.py in update_fun()
    131
    132         def update_fun():
--> 133             self.f = fun_wrapped(self.x)
    134
/usr/lib/python3/dist-packages/scipy/optimize/_differentiable_functions.py in fun_wrapped(x)
    128         def fun_wrapped(x):
    129             self.nfev += 1
--> 130             return fun(x, *args)
    131
~/.local/lib/python3.9/site-packages/pyadjoint/reduced_functional_numpy.py in __call__(self, m_array)
     34         """
     35         m_copies = [control.copy_data() for control in self.controls]
---> 36         return self.rf.__call__(self.set_local(m_copies, m_array))
     37
     38     def set_local(self, m, m_array):
    110
    111     return wrapper
~/.local/lib/python3.9/site-packages/pyadjoint/reduced_functional.py in __call__(self, values)
    210                     range(len(blocks))
    211                 ):
--> 212                     blocks[i].recompute()
    213
    214         # ReducedFunctional can result in a scalar or an assembled 1-form
~/.local/lib/python3.9/site-packages/pyadjoint/block.py in recompute(self, markings)
    345             return
    346
--> 347         prepared = self.prepare_recompute_component(inputs, relevant_outputs)
    348
    349         for idx, out in relevant_outputs:
~/.local/lib/python3.9/site-packages/fenics_adjoint/blocks/solving.py in prepare_recompute_component(self, inputs, relevant_outputs)
    440
    441     def prepare_recompute_component(self, inputs, relevant_outputs):
--> 442         return self._replace_recompute_form()
    443
    444     def _replace_recompute_form(self):
~/.local/lib/python3.9/site-packages/fenics_adjoint/blocks/solving.py in _replace_recompute_form(self)
    446
    447         bcs = self._recover_bcs()
--> 448         lhs = self._replace_form(self.lhs, func=func)
    449         rhs = 0
    450         if self.linear:
~/.local/lib/python3.9/site-packages/fenics_adjoint/blocks/solving.py in _replace_form(self, form, func)
    121             dolfin.Function.assign(func, replace_map[self.func])
    122             replace_map[self.func] = func
--> 123         return ufl.replace(form, replace_map)
    124
    125     def _should_compute_boundary_adjoint(self, relevant_dependencies):
~/.local/lib/python3.9/site-packages/ufl_legacy/algorithms/replace.py in replace(e, mapping)
     54     # To fix this would require one to expand derivatives early (which
     55     # is not attractive), or make replace lazy too.
---> 56     if has_exact_type(e, CoefficientDerivative):
     57         # Hack to avoid circular dependencies
     58         from ufl_legacy.algorithms.ad import expand_derivatives
~/.local/lib/python3.9/site-packages/ufl_legacy/algorithms/analysis.py in has_exact_type(a, ufl_type)
     86     else:
     87         traversal = unique_pre_traversal
---> 88     return any(o._ufl_typecode_ == tc for e in iter_expressions(a) for o in traversal(e))
     89
     90
~/.local/lib/python3.9/site-packages/ufl_legacy/algorithms/traversal.py in iter_expressions(a)
     32     elif isinstance(a, Expr):
     33         return (a,)
---> 34     error("Not an UFL type: %s" % str(type(a)))
~/.local/lib/python3.9/site-packages/ufl_legacy/log.py in error(self, *message)
    156         "Write error message and raise an exception."
    157         self._log.error(*message)
--> 158         raise self._exception_type(self._format_raw(*message))
    159
    160     def begin(self, *message):
UFLException: Not an UFL type: <class 'ufl.form.Form'>
I understand that the error is in the variational form that I have defined but I have failed do know to get why because the error does not arise when i solve the ode simply. I will very much appreciate any help on this. thank you. The ode equation is \dfrac{dy}{dt} = 2tu(t).
