Hey guys,
I’m a little bit frustrated. I have following code which solves an optimal control problem with the poisson equation:
from dolfin_adjoint import *
import moola
import pandas as pd
set_log_level(LogLevel.ERROR)
# Speicher für Ergebnisse
results = []
# Verschiedene Gittergrößen
for n in [32, 64, 128, 256]:
print(f"Löse für n = {n} ...")
mesh = UnitSquareMesh(n, n)
# Lokale Verfeinerung
# cf = MeshFunction("bool", mesh, mesh.geometric_dimension())
# subdomain = CompiledSubDomain("std::abs(x[0]-0.5) < 0.25 && std::abs(x[1]-0.5) < 0.25")
# subdomain.mark(cf, True)
# mesh = refine(mesh, cf)
# Funktionräume
W = FunctionSpace(mesh, "DG", 0)
f = Function(W, name="Control")
u = Function(V, name="State")
# Zustandsgleichung
F = (inner(grad(u), grad(v)) - f * v) * dx
bc = DirichletBC(V, 0.0, "on_boundary")
solve(F == 0, u, bc)
# Steuerung & Ziel
x = SpatialCoordinate(mesh)
w = Expression("sin(pi*x[0])*sin(pi*x[1])", degree=3)
d = 1 / (2 * pi ** 2)
d = Expression("d*w", d=d, w=w, degree=3)
alpha = Constant(1e-6)
J = assemble((0.5 * inner(u - d, u - d)) * dx + alpha / 2 * f ** 2 * dx)
control = Control(f)
# reduziertes Zielfunktional
rf = ReducedFunctional(J, Control(f))
# Optimierungsproblem lösen mit CG Verfahren
problem = MoolaOptimizationProblem(rf)
f_moola = moola.DolfinPrimalVector(f)
solver = moola.NewtonCG(problem, f_moola, options={
'gtol': 1e-9,
'maxiter': 20,
'display': 0,
'ncg_hesstol': 0
sol = solver.solve()
f_opt = sol["control"].data
# Definition der analytischen Lösung um die Fehler zu berechnen
f_analytic = Expression("1/(1+alpha*4*pow(pi, 4))*w", w=w, alpha=alpha, degree=3)
u_analytic = Expression("1/(2*pow(pi, 2))*f", f=f_analytic, degree=3)
f_analytic_v = interpolate(f_analytic, W)
f.assign(f_opt)
# Zustand mit optimierter Steuerung berechnen
# Fehlerberechnung
control_error = errornorm(f_analytic, f_opt)
state_error = errornorm(u_analytic, u)
h_min = mesh.hmin()
# Ergebnis speichern
results.append((n, h_min, state_error, control_error))
# Datenframe erstellen
df = pd.DataFrame(results, columns=["n", "h_min", "state_error", "control_error"])
# Konvergenzraten berechnen
def convergence_rate(errors, hs):
return [None] + [np.log(errors[i-1]/errors[i]) / np.log(hs[i-1]/hs[i]) for i in range(1, len(errors))]
df["convergence_rate_state"] = convergence_rate(df["state_error"], df["h_min"])
df["convergence_rate_control"] = convergence_rate(df["control_error"], df["h_min"])
# Tabelle anzeigen
print("Konvergenztabelle:")
print(df.to_string(index=False, float_format="%.2e"))
# Plot
plt.figure(figsize=(8, 6))
plt.loglog(df["h_min"], df["state_error"], "o-", label="State-Fehler")
plt.loglog(df["h_min"], df["control_error"], "s--", label="Control-Fehler")
plt.loglog(df["h_min"], df["state_error"].iloc[0]*(df["h_min"]/df["h_min"].iloc[0])**2, "k:", label="O(h²)")
plt.loglog(df["h_min"], df["control_error"].iloc[0]*(df["h_min"]/df["h_min"].iloc[0])**1, "k-.", label="O(h)")
plt.xlabel(r"$h_{\min}$")
plt.ylabel("Fehler")
plt.title("Konvergenzverhalten (Log-Log)")
plt.grid(True, which="both", ls=":")
plt.legend()
plt.tight_layout()
plot(f, title="Optimale Steuerung (f)")
This works fine. But now I am trying to constrain my control on a subdomain, so it only works there and is == 0 outside of the subdomain. I tried to update my code with this class:
import moola
import pandas as pd
results = []
class ControlRegion(SubDomain):
return (0.25 < x[0] < 0.75) and (0.25 < x[1] < 0.75)
subdomain_markers = MeshFunction("size_t", mesh, mesh.topology().dim())
subdomain_markers.set_all(0)
omega = ControlRegion()
omega.mark(subdomain_markers, 1)
dx_sub = Measure("dx", domain=mesh, subdomain_data=subdomain_markers)
plot(subdomain_markers)
plt.title("Control Region (omega)")
# Funktionräume
# Zustandsgleichung
# Steuerung & Ziel
J = 0.5 * inner(u - d, u - d) * dx + alpha / 2 * f**2 * dx_sub(1)
'gtol': 1e-9,
'maxiter': 20,
'display': 0,
'ncg_hesstol': 0
f.assign(f_opt)
# Fehlerberechnung
h_min = mesh.hmin()
# Tabelle anzeigen
# Plot
plt.legend()
plt.tight_layout()
The plot of the subdomain markers shows exactly what I want but I can’t get it to run through the optimization.
Does somebody maybe have a similiar problem and can assisst me?
Thanks in advance
