Error while implementing Petsc Tao solver for a bounded field problem
Hello Everyone,
I am trying to use petsc tao solver to obtain the solution of a bounded field problem. I am following the approach as suggested by
My code is as below
from dolfinx import fem, plot, mesh, cpp , la           # dolfinx library
import matplotlib.pyplot as plt    # Plotting Library
from ufl import replace, TestFunction, TrialFunction, nabla_div, Measure, grad, inner, dot, derivative, lhs, rhs
import pyvista
import sys, os, shutil, math
from math import pi
from dolfinx.mesh import locate_entities, meshtags
from dolfinx.fem import FunctionSpace, Function, locate_dofs_geometrical, dirichletbc, Constant
import petsc4py
from tao_problem import TAO_Problem
length = 200.
num_elem = 400
mesh = mesh.create_interval(MPI.COMM_WORLD,num_elem,[0., length])
V_u = FunctionSpace(mesh, ('Lagrange', 1))               # for displacement field)
V_alpha = FunctionSpace(mesh, ('Lagrange', 1) )             # for phase field
# Define the function, test and trial fields
u, du, v = Function(V_u), TrialFunction(V_u), TestFunction(V_u)                             # Functions, Trial Functions and Test functions for displacement field
alpha, dalpha, beta = Function(V_alpha), TrialFunction(V_alpha), TestFunction(V_alpha)      # Functions, Trial Functions and Test functions for phase field
lb = Function(V_alpha)
ub = Function(V_alpha)
alpha_0 = Function(V_alpha)
u_R = Function(V_u)
disp = Function(V_u)
dx = Measure("dx",domain=mesh)
ds = Measure("ds",domain=mesh)
# Identify the boundaries to apply boundary conditions
def on_boundary_L(x):
    return np.isclose(x[0],0.0)
dof_left_u = locate_dofs_geometrical(V_u, on_boundary_L)
bcl = dirichletbc(ScalarType(0), dof_left_u, V_u)
# Define Material Properties
E = Constant(mesh,30000.0)
nu = Constant(mesh,0.2)
# Define the data for phase field
ell = Constant(mesh,5.)
kapa = 1e-7
Gc = Constant(mesh,0.12)
c_w = 2.0
# define functions
def w(alpha):
    return alpha**2
def a(alpha):
    k_ell = Constant(mesh,1.e-6)
    return (1-alpha)**2 +k_ell
def eps(u):
    return grad(u)
def sigma_0(u):
    mu    = E / (2.0*(1.0 + nu))
    lmbda = (E * nu) / ((1.0 - 2.0*nu)*(1.0 + nu))
    return E*(eps(u))
def sigma(u,alpha):
    return (a(alpha))*sigma_0(u)
# Apply the limit on the phase field
zero_alpha = Function(V_alpha)
with zero_alpha.vector.localForm() as bc_local:
    bc_local.set(0.0)
one_alpha = Function(V_alpha)
with one_alpha.vector.localForm() as bc_local:
    bc_local.set(1.0)
ub.interpolate(one_alpha)
alpha_0.interpolate(zero_alpha)
# Governing Equations
f_ext = Constant(mesh,0.0)
external_work = dot(f_ext, u) * dx
elastic_energy = 0.5*inner(sigma(u,alpha), eps(u))*dx
dissipated_energy = Gc/float(c_w)*(w(alpha)/ell + ell*dot(grad(alpha), grad(alpha)))*dx
total_energy = elastic_energy + dissipated_energy - external_work
# First directional derivative wrt displacement field
E_u = derivative(total_energy,u,v)
# First and second directional derivative wrt phase field
E_alpha = derivative(total_energy,alpha,beta)
E_alpha_alpha = derivative(E_alpha,alpha,dalpha)
disp_a = Constant(mesh,0.0012)
def on_boundary(x):
    return np.isclose(x[0],length)
dof_right_u = locate_dofs_geometrical(V_u, on_boundary)
bcr = dirichletbc(disp_a, dof_right_u, V_u)
bc_disp = [bcl, bcr]
# Define solver parameters for displacement field
E_du = replace(E_u,{u:du})
problem_u = LinearProblem(a = lhs(E_du), L = rhs(E_du), bcs = bc_disp,u = u, petsc_options={"ksp_type": "preonly", "pc_type": "lu", "pc_factor_mat_solver_type": "umfpack"})
solver_u = problem_u.solve()
bc_alpha_L = dirichletbc(Constant(mesh,0.0), dof_left_u, V_alpha)
bc_alpha_R = dirichletbc(Constant(mesh,0.0), dof_right_u, V_alpha)
bcs_alpha = [bc_alpha_L,bc_alpha_R]
dolfinx.fem.set_bc(ub.vector, bcs_alpha)
damage_problem = TAO_Problem(E_alpha, E_alpha_alpha, total_energy, alpha, bcs_alpha)
b = la.create_petsc_vector(V_alpha.dofmap.index_map, V_alpha.dofmap.index_map_bs)
J = dolfinx.fem.petsc.create_matrix(damage_problem.a)
T_E = la.create_petsc_vector(V_alpha.dofmap.index_map, V_alpha.dofmap.index_map_bs)
solver_alpha_tao = PETSc.TAO().create()
solver_alpha_tao.setType("tron")
solver_alpha_tao.setFromOptions()
solver_alpha_tao.setObjectiveGradient(damage_problem.F,b)
solver_alpha_tao.setObjective(damage_problem.f,T_E)
solver_alpha_tao.setGradient(damage_problem.J,J)
solver_alpha_tao.setTolerances(gatol=1.0e-5,grtol=1.0e-5)
solver_alpha_tao.getKSP().setType("preonly")
solver_alpha_tao.getKSP().setTolerances(rtol=1.0e-5)
solver_alpha_tao.getKSP().getPC().setType("lu")
solver_alpha_tao.setVariableBounds(lb.vector,ub.vector)
solver_alpha_tao.solve(alpha.vector)
Module tao_problem
from typing import List
class TAO_Problem:
    """Nonlinear problem class compatible with PETSC.SNES solver.
    def __init__(self, F: ufl.form.Form, J: ufl.form.Form, f: ufl.form.Form, alpha_u: dolfinx.fem.Function, bcs: List[dolfinx.fem.dirichletbc]):
        """This class set up structures for solving a non-linear problem using Newton's method.
        Parameters
        F: Residual.
        J: Jacobian.
        alpha_u: Solution.
        bcs: Dirichlet boundary conditions.
        F, J = dolfinx.fem.form(F), dolfinx.fem.form(J)
        f = dolfinx.fem.form(f)
        self.L = F
        self.a = J
        self.K = f
        self.bcs = bcs
        self.alpha_u = alpha_u
        # Create matrix and vector to be used for assembly
        # of the non-linear problem
        self.A = dolfinx.fem.petsc.create_matrix(self.a)
        self.b = dolfinx.fem.petsc.create_vector(self.L)
        self.ob = self.K
    def F(self, x: PETSc.Vec, b: PETSc.Vec):
        """Assemble the gradiant vector.
        Parameters
        x: Vector containing the latest solution.
        A: vector to assemble the gradiant into.
        x.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
        x.copy(self.alpha_u.vector)
        self.alpha_u.vector.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
        # Zero the residual vector
        with b.localForm() as b_local:
            b_local.set(0.0)
        dolfinx.fem.petsc.assemble_vector(b, self.L)
        # Apply boundary conditions
        dolfinx.fem.petsc.apply_lifting(b, [self.a], [self.bcs], [x])
        b.ghostUpdate(addv=PETSc.InsertMode.ADD,mode=PETSc.ScatterMode.REVERSE)
        dolfinx.fem.petsc.set_bc(b, self.bcs, x)
    def J(self, x: PETSc.Vec, A: PETSc.Mat):
        """Assemble the Jacobian matrix.
        Parameters
        A: Matrix to assemble the Jacobian into.
        A.zeroEntries()
        dolfinx.fem.petsc.assemble_matrix(A, self.a, self.bcs)
    def f(self, x: PETSc.Vec, ob: PETSc.Vec):
        """Assemble the objective vector.
        Parameters
        ob: vector to assemble the objective.
            b_local.set(0.0)
        dolfinx.fem.petsc.assemble_vector(ob, self.K)
        dolfinx.fem.petsc.apply_lifting(ob, [self.a], [self.bcs], [x])
        dolfinx.fem.petsc.set_bc(ob, self.bcs, x)
When I run this code, it keep on running and at last get killed without showing any error. I am not able understand why this is happening.
Can someone please help me to find the reason of this issue and how I can correct it.
Thank you
Manish
