Problem with parallel computation and dolfinx (TAO solver)
I am trying to use parallel computation in dolfinx (docker container dolfinx/dolfinx, version 0.6.0-r1) with TAO solver and MPI. I define the configuration of the TAO solver as:
a_problem = TAOProblem(functional_a, dfunctional_a, ddfunctional_a, alpha, bca)
dofs_domain_a, dofs_borders_a = V_a.dofmap.index_map, V_a.dofmap.index_map_bs
b_a = dolfinx.la.create_petsc_vector(dofs_domain_a, dofs_borders_a)
J_a = dolfinx.fem.petsc.create_matrix(a_problem.a)
# Create PETSc TAO
solver_a_tao = petsc4py.PETSc.TAO().create(comm=comm)
solver_a_tao.setType("tron")
solver_a_tao.setObjective(a_problem.f)
solver_a_tao.setGradient(a_problem.F, b_a)
solver_a_tao.setHessian(a_problem.J, J_a)
solver_a_tao.setTolerances(grtol=1e-6, gttol=1e-6)
solver_a_tao.getKSP().setType("preonly")
solver_a_tao.getKSP().setTolerances(rtol=1.0e-6)
solver_a_tao.getKSP().getPC().setType("lu")
# We set the bound (Note: they are passed as reference and not as values)
solver_a_tao.setVariableBounds(alow.vector, aupp.vector)
The function TAOproblem is:
from typing import List
class TAOProblem:
"""Nonlinear problem class compatible with PETSC.TAO solver.
def __init__(self, f: ufl.form.Form, F: ufl.form.Form, J: ufl.form.Form,
             u: dolfinx.fem.Function, bcs: List[dolfinx.fem.dirichletbc]):
    self.obj = dolfinx.fem.form(f)
    self.L = dolfinx.fem.form(F)
    self.a = dolfinx.fem.form(J)
    self.bcs = bcs
    self.u = u
    # Create matrix and vector to be used for assembly
    # of the non-linear problem
    self.A = dolfinx.fem.petsc.create_matrix(self.a)
    self.b = dolfinx.fem.petsc.create_vector(self.L)
def f(self, tao, x: PETSc.Vec):
    # .... Connection between ranks in the vector x: FORWARD
    x.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
    # ..... We copy the vector x in the vector u
    x.copy(self.u.vector)
    # .... Connection between ranks in the vector u in the class
    self.u.vector.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
    return dolfinx.fem.assemble_scalar(self.obj)
def F(self, tao: PETSc.TAO, x: PETSc.Vec, F):
    with F.localForm() as f_local:
        f_local.set(0.0)
    dolfinx.fem.petsc.assemble_vector(F, self.L)
    # .... Include the boundary conditions using the lifting technique
    dolfinx.fem.petsc.apply_lifting(F, [self.a], bcs=[self.bcs], x0=[x], scale=-1.0)
    # .... Connection between ranks in the vector x: REVERSE
    F.ghostUpdate(addv=PETSc.InsertMode.ADD, mode=PETSc.ScatterMode.REVERSE)
    # .... Redefine the function F with the boundary condition.
    dolfinx.fem.petsc.set_bc(F, self.bcs, x, -1.0)
def J(self, tao: PETSc.TAO, x: PETSc.Vec, A: PETSc.Mat, P: PETSc.Mat):
    A.zeroEntries()
    dolfinx.fem.petsc.assemble_matrix(A, self.a, self.bcs)
The code works perfectly in serial computation, but not in parallel. It doesn’t give a specific error, just it doesn’t finish the calculation. I would like to know which is my mistake, because I use the same things for SNES solver and there is no problem.
Thank you in advance
Please make a minimal reproducible problem, i.e. the smallest and simplest possible problem that can reproduce your error message. Please also post the code with 3x` encapsulation, i.e.
```python
# add code here
Sorry for my late response, I think I solved in the end, but I was a bit stressed with the end of the PhD and I could not send any message here. I attach my problem just in case someone is interested. It was related to the definition of the objective function in the TAO solver with MPI. I attach below the code I used to define the class TAO_Problem. For the phase field codes with parallel computing I strongly recommend the webpage of my network NEWFRAC (Gradient damage as phase-field models of brittle fracture: dolfinx example — FEniCSx Fracture Mechanics) where the solver SNES is used with MPI.
class TAO_Problem:
  """Nonlinear problem class compatible with PETSC.TAO solver"""
 def __init__(self, f, F, J, u, bcs):
    self.bcs = bcs                 # bcs = boundary conditions
    self.u   = u                   # u = solution
    self.L   = dolfinx.fem.form(F) # F = residual
    self.a   = dolfinx.fem.form(J) # J = jacobian
    self.obj = dolfinx.fem.form(f) # f = objective function
    # .. Generation of matrices in the no-linear problem
 def f(self, tao, x):
    return dolfinx.fem.assemble_scalar(dolfinx.fem.form(self.obj))
 def F(self, tao, x, F):
        f_local.set(0.0)
 def J(self, tao, x, A, P):
    A.zeroEntries()
