I’m trying to solve Lid driven cavity using Stokes equation. I am unable to export the results as xdmf file.
from dolfinx import mesh
from dolfinx import fem
from ufl import inner,grad,div,dx
from dolfinx.io import XDMFFile,VTKFile
msh = mesh.create_unit_square(MPI.COMM_WORLD, 40, 40, mesh.CellType.triangle)
# Function to mark x = 0, x = 1 and y = 0
def noslip_boundary(x):
return np.logical_or(np.logical_or(np.isclose(x[0], 0.0), np.isclose(x[0], 1.0)), np.isclose(x[1], 0.0))
# Function to mark the lid (y = 1)
def lid(x):
return np.isclose(x[1], 1.0)
# Lid velocity
def lid_velocity_expression(x):
return np.stack((np.ones(x.shape[1]), np.zeros(x.shape[1])))
P2 = ufl.VectorElement("Lagrange", msh.ufl_cell(), 2)
P1 = ufl.FiniteElement("Lagrange", msh.ufl_cell(), 1)
V, Q = fem.FunctionSpace(msh, P2), fem.FunctionSpace(msh, P1)
# Create the function space
TH = P2 * P1
W = fem.FunctionSpace(msh, TH)
W0, _ = W.sub(0).collapse()
# No slip boundary condition
noslip = fem.Function(V)
facets = mesh.locate_entities_boundary(msh, 1, noslip_boundary)
dofs = fem.locate_dofs_topological((W.sub(0), V), 1, facets)
bc0 = fem.dirichletbc(noslip, dofs, W.sub(0))
# Driving velocity condition u = (1, 0) on top boundary (y = 1)
lid_velocity = fem.Function(W0)
lid_velocity.interpolate(lid_velocity_expression)
facets = mesh.locate_entities_boundary(msh, 1, lid)
bc1 = fem.dirichletbc(lid_velocity, dofs, W.sub(0))
# Since for this problem the pressure is only determined up to a constant, we pin the pressure at the point (0, 0)
zero = fem.Function(Q)
zero.x.set(0.0)
dofs = fem.locate_dofs_geometrical((W.sub(1), Q), lambda x: np.isclose(x.T, [0, 0, 0]).all(axis=1))
bc2 = fem.dirichletbc(zero, dofs, W.sub(1))
bcs = [bc0, bc1, bc2]
(v, q) = ufl.TestFunctions(W)
f = fem.Function(W0)
a = inner(grad(u), grad(v)) * dx - p * div(v) * dx + div(u) * q * dx
L = inner(f, v) * dx
# Compute solution
solver = fem.petsc.LinearProblem(
a, L, bcs, petsc_options={"ksp_type": "preonly", "pc_type": "lu",
"pc_factor_mat_solver_type": "mumps"})
solver.solve()
u = W.sub(0).collapse()
p = W.sub(1).collapse()
# Write the solution to file
with XDMFFile(MPI.COMM_WORLD, "stokesx/pressure.xdmf", "w") as pfile_xdmf:
p.x.scatter_forward()
pfile_xdmf.write_mesh(msh)
pfile_xdmf.write_function(p)
with XDMFFile(MPI.COMM_WORLD, "stokesx/velocity.xdmf", "w") as ufile_xdmf:
u.x.scatter_forward()
ufile_xdmf.write_mesh(msh)
ufile_xdmf.write_function(u)
print('Execution Complete')
This gives an error
AttributeError: 'tuple' object has no attribute 'x'
It would be very helpful if anyone could give me the code for exporting the results.
