Hello! Sorry to bother you! I am a novice. Recently, I tried to make Stokes square cavity flow, using P2-P1 yuan. I found that my speed calculation result reached the expectation, but the pressure was very bad, I looked up the relevant materials and still couldn’t solve it. Looking forward to your reply! Here’s my program.
from dolfinx import mesh
from dolfinx import fem
from ufl import inner,grad,div,dx
from dolfinx.io import XDMFFile,VTKFile
from dolfinx import default_real_type, fem, la, io, mesh
from dolfinx.fem import (
Constant,
Function,
dirichletbc,
extract_function_spaces,
form,
functionspace,
locate_dofs_topological,
from dolfinx.fem.petsc import assemble_matrix_block, assemble_vector_block
from dolfinx.mesh import CellType, create_rectangle, locate_entities_boundary,create_unit_square
from ufl import *
msh = mesh.create_unit_square(MPI.COMM_WORLD, 40, 40, mesh.CellType.triangle)
# Function to mark x = 0, x = 1 and y = 0
def noslip_boundary(x):
return np.logical_or(np.logical_or(np.isclose(x[0], 0.0), np.isclose(x[0], 1.0)), np.isclose(x[1], 0.0))
# Function to mark the lid (y = 1)
def lid(x):
return np.isclose(x[1], 1.0)
# Lid velocity
def lid_velocity_expression(x):
return np.stack((np.ones(x.shape[1]), np.zeros(x.shape[1])))
P2 = element("Lagrange", msh.basix_cell(), 2, shape=(msh.geometry.dim,), dtype=default_real_type)
P1 = element("Lagrange", msh.basix_cell(), 1, dtype=default_real_type)
V_el = mixed_element([P2, P1])
V, Q = functionspace(msh, P2), functionspace(msh, P1)
W = functionspace(msh, V_el)
# Create the function space
# TH = P2 * P1
# W = fem.FunctionSpace(msh, TH)
W0, _ = W.sub(0).collapse() #局部空间自由度索引 sub 表示全局自由度索引
# No slip boundary condition
noslip = fem.Function(W0)
facets = mesh.locate_entities_boundary(msh, 1, noslip_boundary)
dofs = fem.locate_dofs_topological((W.sub(0), W0), 1, facets) #返回自由度索引
bc0 = fem.dirichletbc(noslip, dofs, W.sub(0))
# Driving velocity condition u = (1, 0) on top boundary (y = 1)
lid_velocity = fem.Function(W0)
lid_velocity.interpolate(lid_velocity_expression)
facets = mesh.locate_entities_boundary(msh, 1, lid)
bc1 = fem.dirichletbc(lid_velocity, dofs, W.sub(0))
# Since for this problem the pressure is only determined up to a constant, we pin the pressure at the point (0, 0)
# zero = fem.Function(Q)
# zero.x.set(0.0)
# dofs = fem.locate_dofs_geometrical((W.sub(1), Q), lambda x: np.isclose(x.T, [0, 0, 0]).all(axis=1))
# bc2 = fem.dirichletbc(zero, dofs, W.sub(1))
bcs = [bc0, bc1]
(v, q) = ufl.TestFunctions(W)
f = fem.Function(W0)
a = inner(grad(u), grad(v)) * dx - p * div(v) * dx + div(u) * q * dx - 1.e-8 * p * q * dx
L = inner(f, v) * dx
# Compute solution
solver = fem.petsc.LinearProblem(
a, L, bcs, petsc_options={"ksp_type": "preonly", "pc_type": "lu",
"pc_factor_mat_solver_type": "mumps"})
w_h = solver.solve()
u, p = w_h.split()
# Write the solution to file
with XDMFFile(MPI.COMM_WORLD, "stokesx/pressure.xdmf", "w") as pfile_xdmf:
p.x.scatter_forward()
pfile_xdmf.write_mesh(msh)
pfile_xdmf.write_function(p)
with XDMFFile(MPI.COMM_WORLD, "stokesx/velocity.xdmf", "w") as ufile_xdmf:
u.x.scatter_forward()
P1 = element(
"Lagrange", msh.basix_cell(), 1, shape=(msh.geometry.dim,), dtype=default_real_type
u1 = Function(functionspace(msh, P1))
u1.interpolate(u)
ufile_xdmf.write_mesh(msh)
ufile_xdmf.write_function(u1)
print('Execution Complete')
