Error with 1d mesh immersed in 2d with dolfinx
I’m trying dolfinX to generate a line mesh in 2d, where I want to define a form depending on stretching and curvature (double derivative of vertical displacement). I don’t know the meaning of the error message I’m getting, code is as follows
comm = MPI.COMM_WORLD
gdim = 2
omega_0 = 1
boundary0 = 2
if comm.rank == 0:
    gmsh.model.add("telaio")
    factory = gmsh.model.geo
    h = 0.1
    square_points = [
        factory.addPoint(0.0, 0.0, 0.0, h),
        factory.addPoint(0.0, 1.0, 0.0, h),
    square_lines = [
        factory.addLine(square_points[0], square_points[1]),
    square_curve = factory.addCurveLoop(square_lines)
    factory.synchronize()
    gmsh.model.addPhysicalGroup(1, square_lines, omega_0)
    gmsh.model.addPhysicalGroup(0, square_points, boundary0)
    gmsh.model.mesh.generate(1)
partitioner = mesh.create_cell_partitioner(mesh.GhostMode.shared_facet)
msh, ct, ft = io.gmshio.model_to_mesh(
    gmsh.model, comm, 0, gdim=gdim, partitioner=partitioner
gmsh.finalize()
dx = ufl.Measure("dx", domain=msh, subdomain_data=ct)
DEGREE = 2
Ue = ufl.FiniteElement("CG", msh.ufl_cell(), DEGREE)
Um = ufl.MixedElement([Ue, Ue])
V_0 = fem.FunctionSpace(msh, Um)
# Test and trial functions
u_0 = ufl.TrialFunction(V_0)
v_0 = ufl.TestFunction(V_0)
w0, v0 = ufl.split(u_0)
w0t, v0t = ufl.split(v_0)
eps0, th0 = ufl.grad(w0)[1], ufl.grad(v0)[1]
eps0t, th0t = ufl.grad(w0t)[1], ufl.grad(v0t)[1]
chi0, chi0t = ufl.grad(th0)[1], ufl.grad(th0t)[1]
a = (
    ufl.inner(chi0, chi0t) * dx
    + ufl.inner(eps0, eps0t) * dx
a = fem.form(a)
and results in the error
Info    : Meshing 1D...
Info    : Meshing curve 1 (Line)
Info    : Done meshing 1D (Wall 0.000160543s, CPU 0.000146s)
Info    : 11 nodes 12 elements
  File "/root/shared/prova.py", line 69, in <module>
    a = fem.form(a)
  File "/usr/local/dolfinx-real/lib/python/dist-packages/dolfinx/fem/forms.py", line 194, in form
    return _create_form(form)
  File "/usr/local/dolfinx-real/lib/python/dist-packages/dolfinx/fem/forms.py", line 189, in _create_form
    return _form(form)
  File "/usr/local/dolfinx-real/lib/python/dist-packages/dolfinx/fem/forms.py", line 152, in _form
  File "/usr/local/dolfinx-real/lib/python/dist-packages/dolfinx/jit.py", line 56, in mpi_jit
  File "/usr/local/dolfinx-real/lib/python/dist-packages/dolfinx/jit.py", line 204, in ffcx_jit
  File "/usr/local/lib/python3.10/dist-packages/ffcx/codegeneration/jit.py", line 199, in compile_forms
    raise e
  File "/usr/local/lib/python3.10/dist-packages/ffcx/codegeneration/jit.py", line 190, in compile_forms
    impl = _compile_objects(decl, forms, form_names, module_name, p, cache_dir,
  File "/usr/local/lib/python3.10/dist-packages/ffcx/codegeneration/jit.py", line 260, in _compile_objects
    _, code_body = ffcx.compiler.compile_ufl_objects(ufl_objects, prefix=module_name, options=options)
  File "/usr/local/lib/python3.10/dist-packages/ffcx/compiler.py", line 102, in compile_ufl_objects
    ir = compute_ir(analysis, object_names, prefix, options, visualise)
  File "/usr/local/lib/python3.10/dist-packages/ffcx/ir/representation.py", line 198, in compute_ir
    irs = [_compute_integral_ir(fd, i, analysis.element_numbers, integral_names, finite_element_names,
  File "/usr/local/lib/python3.10/dist-packages/ffcx/ir/representation.py", line 198, in <listcomp>
  File "/usr/local/lib/python3.10/dist-packages/ffcx/ir/representation.py", line 493, in _compute_integral_ir
    integral_ir = compute_integral_ir(itg_data.domain.ufl_cell(), itg_data.integral_type,
  File "/usr/local/lib/python3.10/dist-packages/ffcx/ir/integral.py", line 84, in compute_integral_ir
    mt_table_reference = build_optimized_tables(
  File "/usr/local/lib/python3.10/dist-packages/ffcx/ir/elementtables.py", line 382, in build_optimized_tables
    t = get_ffcx_table_values(quadrature_rule.points, cell,
  File "/usr/local/lib/python3.10/dist-packages/ffcx/ir/elementtables.py", line 144, in get_ffcx_table_values
    tbl = tbl[basix_index(derivative_counts)]
IndexError: index 3 is out of bounds for axis 0 with size 3
I’ve made an issue at: Double derivative on manifold · Issue #575 · FEniCS/ffcx · GitHub
Fixed in: Resolve double derivatives for manifolds by jorgensd · Pull Request #576 · FEniCS/ffcx · GitHub, feel free to try the branch
Thanks @dokken, I tried the script above on the nightly docker image and now it runs without errors
