I construct a mesh with two subdomains. I create two meshviews from theses subdomains and I want to interpolate a function from one meshview to the other. Using LagrangeInterpolator the code runs fine in serial but I got the following error when running the code in parallel (with mpirun -np 5
File "interpolation_meshview.py", line 42, in <module>
LagrangeInterpolator.interpolate(u2, u1)
RuntimeError:
*** Error: Unable to initialize mapping of degrees of freedom.
*** Reason: Missing entities of dimension 0. Try calling mesh.init(0).
*** Where: This error was encountered inside DofMap.cpp.
*** Process: 4
*** Git changeset: f0a90b8fffc958ed612484cd3465e59994b695f9
Even more strange, when I run the code with 3 processors, I get no error but the resulting interpolated function is wrong…
Here is a minimal example:
# Parameters
N = 30
xc, yc = 0.5, 0.5
rc = 0.12
# Construct the mesh and mark subdomains (a disk in a square)
mesh = UnitSquareMesh(N,N)
subdomains = MeshFunction("size_t", mesh, 2, 1)
for cell in cells(mesh):
if (cell.midpoint()[0]-xc)**2 + (cell.midpoint()[1]-yc)**2 < rc**2:
subdomains.set_value(cell.index(),2)
# create meshviews
submesh1 = MeshView.create(subdomains, 1)
submesh2 = MeshView.create(subdomains, 2)
# Define functon spaces, functions and expression to interpolate
V1 = FunctionSpace(submesh1, "CG", 1)
V2 = FunctionSpace(submesh2, "CG", 1)
u1 = Function(V1)
u2 = Function(V2)
expr = Expression("x[0]*x[1] + 2*x[1]", degree=1)
LagrangeInterpolator.interpolate(u1, expr)
# Interpolation with LagrangeInterpolator
# Save results
with XDMFFile(MPI.comm_world, "u1.xdmf") as file:
file.write(u1)
with XDMFFile(MPI.comm_world, "u2.xdmf") as file:
file.write(u2)
Any help would be appreciated.
Cheers,
Fabien
