Runtime error when interpolating between non-matching meshes with dolfinx update
Hi, I am trying to interpolate between two meshes of different shapes (for visualisation purposes) for which I’m getting an error. I’m able to do this perfectly on an older installation using dolfinx’s v0.6.0 release. However, I have unfortunately had to switch to an installation with python 3.11 which seems to require this fix. I don’t know what updates were made between v0.6.0 and this newer commit that breaks the interpolation. This does not work with an installation using git clones of all the packages at the current main, nor with an installation at the time of that commit (Jan 28th).
Below is an MWE of what I would like to do. This attempts to interpolate data from a unit square to a subdomain rectangle that is 1 x 0.5.
from dolfinx import mesh
from dolfinx.fem import FunctionSpace, Function
domain = mesh.create_unit_square(MPI.COMM_WORLD, 20, 20, mesh.CellType.quadrilateral)
subdomain = mesh.create_rectangle(MPI.COMM_WORLD, ((0., 0.), (1., 0.5)), (20, 10), mesh.CellType.quadrilateral)
V = FunctionSpace(domain, ("CG", 2))
W = FunctionSpace(subdomain, ("CG", 2))
uD = Function(V)
uSD = Function(W)
uSD.interpolate(uD)
Here is the error message I get with my new installation (everything runs fine on the older installation):
  File "/tmp_user/sator/hmmak/fenicsx-scripts/3D/test5.py", line 14, in <module>
    uSD.interpolate(uD)
  File "/tmp_user/sator/hmmak/conda/envs/fx-real/lib/python3.11/site-packages/dolfinx/fem/function.py", line 370, in interpolate
    _interpolate(u, cells)
  File "/tmp_user/sator/hmmak/conda/envs/fx-real/lib/python3.11/functools.py", line 909, in wrapper
  File "/tmp_user/sator/hmmak/conda/envs/fx-real/lib/python3.11/site-packages/dolfinx/fem/function.py", line 351, in _
    self._cpp_object.interpolate(u._cpp_object, cells, nmm_interpolation_data)
RuntimeError: In order to interpolate on nonmatching meshes, the user needs to provide the necessary interpolation data. This can be computed with fem::create_nonmatching_meshes_interpolation_data.
As the error says, you should precompute some interpolation data, see https://github.com/FEniCS/dolfinx/blob/26fbb085d5d3c39340dab91705e4c475e98f4ec5/python/test/unit/fem/test_interpolation.py#L737
for the syntax
Thank you, this works.
I’ve tested that this works on the current main (27/09/2023) but it doesn’t work for the commit of 28/01/2023; it seems create_nonmatching_meshes_interpolation_data didn’t exist at that time.
