Error with PETSc
hi everyone.
I’m trying to solve a linear system with PETSc, but I get the following error
 File "/home/c.ruiz/Fenicx/Venturi/Codes/Venturi_adjoint_laminar_nobl.py", line 356, in <module>
    wa = problem.solve()
  File "/opt/ohpc/pub/apps/miniconda/miniconda3/envs/fenicsx-env-0.5.2/lib/python3.10/site-packages/dolfinx/fem/petsc.py", line 618, in solve
    self._solver.solve(self._b, self._x)
  File "PETSc/KSP.pyx", line 403, in petsc4py.PETSc.KSP.solve
petsc4py.PETSc.Error: error code 378
[0] KSPSolve() at /home/conda/feedstock_root/build_artifacts/petsc_1656827302664/work/src/ksp/ksp/interface/itfunc.c:1078
[0] KSPSolve_Private() at /home/conda/feedstock_root/build_artifacts/petsc_1656827302664/work/src/ksp/ksp/interface/itfunc.c:843
[0] KSPSetUp() at /home/conda/feedstock_root/build_artifacts/petsc_1656827302664/work/src/ksp/ksp/interface/itfunc.c:407
[0] PCSetUp() at /home/conda/feedstock_root/build_artifacts/petsc_1656827302664/work/src/ksp/pc/interface/precon.c:990
[0] PCSetUp_LU() at /home/conda/feedstock_root/build_artifacts/petsc_1656827302664/work/src/ksp/pc/impls/factor/lu/lu.c:93
[0] MatLUFactorSymbolic() at /home/conda/feedstock_root/build_artifacts/petsc_1656827302664/work/src/mat/interface/matrix.c:2966
[0] MatLUFactorSymbolic_SeqAIJ() at /home/conda/feedstock_root/build_artifacts/petsc_1656827302664/work/src/mat/impls/aij/seq/aijfact.c:378
[0] PetscMallocA() at /home/conda/feedstock_root/build_artifacts/petsc_1656827302664/work/src/sys/memory/mal.c:401
[0] PetscMallocAlign() at /home/conda/feedstock_root/build_artifacts/petsc_1656827302664/work/src/sys/memory/mal.c:49
The code is
import math
from ufl import (FacetNormal, FiniteElement, Identity, Measure, TestFunction, TrialFunction, VectorElement,
                 as_vector, div, dot, ds, dx, inner, lhs, grad, nabla_grad, rhs, sym, MixedElement)
                               create_vector, create_matrix, set_bc)
from dolfinx.fem import (Constant, Function, FunctionSpace,
                         assemble_scalar, dirichletbc, form, locate_dofs_topological, set_bc)
with dolfinx.io.XDMFFile(MPI.COMM_WORLD, "Mesh_nobl/venturi_nobl.xdmf", "r") as xdmf:
    domain = xdmf.read_mesh(name="Grid")
    cf = xdmf.read_meshtags(domain, name = 'Grid')
tdim = domain.topology.dim
tree = dolfinx.geometry.BoundingBoxTree(domain, tdim)
num_entities_local = domain.topology.index_map(tdim).size_local + domain.topology.index_map(tdim).num_ghosts
entities = np.arange(num_entities_local, dtype = np.int32)
mid_tree = dolfinx.geometry.create_midpoint_tree(domain, tdim,entities)
mesh_geom = domain.geometry.x
tol = 1e-8
def closest_point(mesh, point,tol):
    points = point
    while True:
        try:
            entity = dolfinx.geometry.compute_closest_entity(tree, mid_tree, mesh, points)
            break
        except RuntimeError:
            print(points)
            for j in range(len(mesh.geometry.x)):
                if (np.abs(mesh_geom[j][0]-points[0])< tol and np.abs(mesh_geom[j][1]-points[1])< tol and np.abs(mesh_geom[j][2]-points[2])< tol):
                     return points, j
    geom_dof = dolfinx.cpp.mesh.entities_to_geometry(mesh,tdim,[entity], False)
    #print('geom',geom_dof)
    mesh_nodes = mesh_geom[geom_dof][0]
    #print('mesh_nodes', mesh_nodes)
    dis = dolfinx.geometry.compute_distance_gjk(points, mesh_nodes)
    index = -100
    for i in range(len(mesh_nodes)):
        #print(mesh_nodes[i])
        if np.abs(mesh_nodes[i][0]-points[0]+ dis[0]) < tol and np.abs(mesh_nodes[i][1]-points[1]+ dis[1]) < tol and np.abs(mesh_nodes[i][2]-points[2]+ dis[2]) < tol :
            index = i
    if (index == -100):
        return point, index
        return points - dis , geom_dof[0][index]
vx_np = np.loadtxt('Data_nobl/data_vp.txt')
vx_aux = vx_np[:,1:4]
b = []
indices = []
ind = int(0)
for i in range(len(vx_aux)):
    a,j = closest_point(domain,vx_aux[i],tol)
    indices.append(int(j))
    # Definition of Spaces. (dim and polinomial type)
v_cg2 = VectorElement("CG", domain.ufl_cell(), 2)
v_cg1 = VectorElement("CG", domain.ufl_cell(), 1)
s_cg1 = FiniteElement("CG", domain.ufl_cell(), 1)
V = dolfinx.fem.FunctionSpace(domain, v_cg1)
Q = dolfinx.fem.FunctionSpace(domain, s_cg1)
Z = MixedElement([v_cg2, s_cg1])
W = dolfinx.fem.FunctionSpace(domain, Z)
# In[4]:
Lx  =0.945
def upstream(x):
    return np.isclose(x[0],0)
def downstream(x):
    return np.isclose(x[0],Lx)
def walls(x):
    a = np.greater(x[0],0)
    b = np.less(x[0],Lx)
    return np.logical_and(np.greater(x[2]**2+x[1]**2, 0.00000001), np.logical_and(a,b))
fdim = domain.topology.dim -1
up_facets = dolfinx.mesh.locate_entities_boundary(domain, fdim, upstream)
down_facets = dolfinx.mesh.locate_entities_boundary(domain, fdim, downstream)
wall_facets = dolfinx.mesh.locate_entities_boundary(domain, fdim, walls)
V1, _ = W.sub(0).collapse()
Q1, _ = W.sub(1).collapse()
uuw_condition = Function(V1)
pd_condition = Function(Q1)
up_f = dolfinx.fem.locate_dofs_topological((W.sub(0),V1), fdim, up_facets)
w_f = dolfinx.fem.locate_dofs_topological((W.sub(0),V1), fdim, wall_facets)
d_f = dolfinx.fem.locate_dofs_topological((W.sub(1),Q1), fdim, down_facets)
bc_u = dirichletbc(uuw_condition, up_f,W.sub(0))
bc_w = dirichletbc(uuw_condition, w_f,W.sub(0))
bc_p = dirichletbc(pd_condition, d_f,W.sub(1))
bc = [bc_u, bc_w, bc_p]
boundaries = [(1,up_facets),(2,down_facets),(3,wall_facets)]
for (marker, face ) in boundaries:
    facet_indices.append(face)
    facet_markers.append(np.full_like(face, marker))
facet_tag = dolfinx.mesh.meshtags(domain, fdim, facet_indices[sorted_facets], facet_markers[sorted_facets])
ds = Measure("ds", domain=domain, subdomain_data=facet_tag)
    # Parameters
mu = Constant(domain, PETSc.ScalarType(0.0303))
    # Normal and operators
n = FacetNormal(domain)
    return sym(nabla_grad(u))
# Define stress tensor
def sigma(u, p):
    return 2*mu*epsilon(u) - p*Identity(len(u))
dataname = 'Data_nobl/data_vp.txt'
data_np = np.loadtxt(dataname)
u = Function(V1)
p = Function(Q1)
u_aux = Function(V)
for i in range(len(indices)):
    u_aux.x.array[3*indices[i]]=data_np[i,6]
    u_aux.x.array[3*indices[i]+1]=data_np[i,5]
    u_aux.x.array[3*indices[i]+2]=data_np[i,4]
    p.x.array[indices[i]]=data_np[i,7]
u.interpolate(u_aux)
print(len(p.x.array))
print(len(indices))
wa = TrialFunction(W)
ua, pa = ufl.split(wa)
wtest = TestFunction(W)
va,qa = ufl.split(wtest)
f = Function(Q1)
x_upstream = 0.1
x_downstream = 0.8
x_throat = 0.3
x_up, ind_up =closest_point(domain,[x_upstream,0,0],0.001)
x_throat, ind_throat =closest_point(domain,[x_throat,0,0],0.001)
x_down, ind_down =closest_point(domain,[x_downstream,0,0],0.01)
delta_up = Function(Q1)
delta_up.name = "d_u"
delta_down = Function(Q1)
delta_down.name = "d_d"
delta_throat = Function(Q1)
delta_throat.name = "d_t"
delta_up.x.array[ind_up] = 1
delta_throat.x.array[ind_throat] = 1
delta_down.x.array[ind_down] = 1
# In[9]:
p_up = p.x.array[ind_up]
p_throat = p.x.array[ind_throat]
p_dn = p.x.array[ind_down]
umd = (p_up-p_dn)**2
di_ua = Function(Q1)
di_ua.x.array[:] = 1/(umd)*((p_throat - p_dn)*delta_up.x.array[:] + (p_dn-p_up)*delta_throat.x.array[:] + (p_up - p_throat)*delta_down.x.array[:] )
a1 = dot(dot(ua,nabla_grad(u).T),va)*dx - dot(dot(nabla_grad(ua).T,u),va)*dx + inner(sigma(ua,-pa),epsilon(va))*dx + dot(div(ua),qa)*dx + dot(dot(u,n)*ua,va)*ds - dot(pa*n,va)*ds - mu*dot(dot(nabla_grad(ua),n),va)*ds
a2 = dot(div(ua),qa)*dx
#a2 = dot(div(ua)-f,qa)*dx
a3 = dot(dot(u,n)*ua,va)*ds - dot(pa*n,va)*ds - mu*dot(dot(nabla_grad(ua),n),va)*ds
a0 = a1+a2+a3
L = dot(di_ua,qa)*dx
problem = dolfinx.fem.petsc.LinearProblem(a0, L, bcs=bc, petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
ua,pa = wa.split()
with dolfinx.io.XDMFFile(domain.comm, "Plot/ua.xdmf", "w") as file:
    file.write_mesh(domain)
    file.write_function(ua)
with dolfinx.io.XDMFFile(domain.comm, "Plot/pa.xdmf", "w") as file:
    file.write_function(pa)
The files are here:
Any suggestions?
Thank you!
I don’t have the bandwidth to try and run your example, but are you sure you’re not running out of memory? You could also specify which LU solver you’re employing as UMFPACK, for example, has a very small memory limit as a default.
I am working with my university’s supercomputer, memory should not be a problem, how can I check what kind of LU I am applying?
Add "pc_factor_mat_solver_type": "mumps" to petsc_options to use something else than the default (“umfpack”).
Thank you @dokken and @nate!
