Hello everybody,
I want to restrict a pure Neumann PDE on a 1d boundary of a 2d domain. I use mixed-dimensional branch to define a submesh of the 2d domain and a real Element to define a lagrange multiplier for a volume constraint. The following MWE works fine at serial:
nex=100
ney=100
D=0.020
Ro=0.01485
mesh=RectangleMesh(Point(-Ro,-D),Point(Ro,0),nex,ney)
class free_surface(SubDomain):
return near(x[1],0)
boundaries=MeshFunction('size_t',mesh,mesh.topology().dim()-1)
boundaries.set_all(0)
free_surface().mark(boundaries,1)
submesh=MeshView.create(boundaries, 1)
V=FunctionSpace(submesh,'Real',0)
Unfortunately when running at parallel returns the error:
YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Floating point exception (signal 8)
The problem seems to be at the definition of the real functionspace using the submesh object.
Thanks for pointing this out, I have been able to reproduce your error. It was indeed related to the use of a Real function space with a submesh involving MeshView (more specifically the nodes ownership, that is why it was working in serial).
I have pushed a fix which seems to fix your MWE (the Docker image with latest tag is also up-to-date with this change), I hope that helps.
Thank you for the quick answer @cdaversin,
The issue was fixed with the latest docker image. However if i try to define a functionspace using a mixed element that includes a Real element like the following MWE :
nex=100
ney=100
D=0.020
Ro=0.01485
return near(x[1],0)
# it works
#P=FiniteElement('Real', submesh.ufl_cell(), 0)
#V=FunctionSpace(submesh,P)
# it works
#H=FiniteElement('Lagrange',submesh.ufl_cell(),2)
#P=FiniteElement('Lagrange', submesh.ufl_cell(), 2)
#ME=MixedElement([H,P])
#V=FunctionSpace(submesh,ME)
#this is not working
it still returns an error at parallel:
YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation fault (signal 11)
It works fine at parallel for a single element so i suspect that the issue is at the definition of mixed element using a Real element.
I cannot reproduce the error you get with this MWE. But an alternative solution would be to define your mixed space with a MixedFunctionSpace instead of a MixedElement.
Thank you again @cdaversin,
Indeed, this works and actually is better for my application.
