Evaluation of cell sizes
Hi everybody,
Currently, I translate my ‘classical’ dolfincode to dolfinx. Among others, I face the problem of evaluating all cell sizes by doing:
elemsize = [c.h() for c in cells(mesh)]
But that doesn’t work under dolfinx. As far as I noticed, the ‘hmin’ attribute (see dolfinx.cpp.mesh — DOLFINX documentation) should give me the option the get the smallest cell size (and via ‘hmax’ the maximal cell size). But unfortunately, it doesn’t work.
I should mention that I read xdmf-meshes into dolfinx that are created by converting msh files into xdmf. My python function doing this reads
import sys
# converts msh to xdmf
# essential for dolfinx
# see
# https://fenicsproject.discourse.group/t/transitioning-from-mesh-xml-to-mesh-xdmf-from-dolfin-convert-to-meshio/412/147
model_name = sys.argv[1]
dim = sys.argv[2] # 2d or 3d
import meshio # python3 -m pip install meshio
    out_mesh = meshio.Mesh(points=mesh.points, cells={cell_type: cells}, cell_data={"name_to_read":[cell_data]})
    if prune_z:
        out_mesh.prune_z_0()
    return out_mesh
# Read in mesh
msh = meshio.read(f"{model_name}.msh")
# Create and save one file for the mesh, and one file for the facets
if dim == '2d':
    meshio.write(f"{model_name}_mesh.xdmf", triangle_mesh)
    meshio.write(f"{model_name}_mt.xdmf", line_mesh)
elif dim == '3d':
    tetra_mesh = create_mesh(msh, "tetra")
    triangle_mesh = create_mesh(msh, "triangle")
    meshio.write(f"{model_name}_mesh.xdmf", tetra_mesh)
    meshio.write(f"{model_name}_mt.xdmf", triangle_mesh)
Has anybody an idea how I can get the whole array of cell sizes for doing some ‘statistics’?
Thanks for the help!
Consider:
mesh = dolfinx.UnitSquareMesh(MPI.COMM_WORLD, 10, 5)
tdim = mesh.topology.dim
num_cells = mesh.topology.index_map(tdim).size_local
h = dolfinx.cpp.mesh.h(mesh, tdim, range(num_cells))
print(h)
This code is a simplified version of dolfinx/test_mesh.py at 1087856ac3594a1c3c7d99c27a26e65f98da1fa2 · FEniCS/dolfinx · GitHub
@dokken, thank you very much!
Thank you for that helpful snippet !
I would like to extend it into a cell-valued dolfinx.Function so I could use it as an Argument to a ufl.Form. My current toy problem goes :
import dolfinx as dfx
from mpi4py.MPI import COMM_WORLD as comm
mesh = dfx.UnitSquareMesh(comm, 10, 5)
FE_constant=ufl.FiniteElement("DG",mesh.ufl_cell(),0)
W = dfx.FunctionSpace(mesh,FE_constant)
h = dfx.cpp.mesh.h(mesh, tdim, range(num_cells))
hf = dfx.Function(W)
hf.x.array[:]=h
This works in serial but fails in parallel. It’s troubling to me because you seem to have done some effort in writing a parallel snippet and using Function then x.array directly in parallel usually works well for me. Traceback goes :
  File "/home/shared/src/sanity_check.py", line 13, in <module>
    hf.x.array[:]=h
ValueError: could not broadcast input array from shape (10,) into shape (17,)
Change this to
num_cells = mesh.topology.index_map(tdim).size_local + mesh.topology.index_map(tdim).num_ghosts
Thank you ! It works beautifully.
Hi dokken,
apparently, this does not work in dolfinx 0.9.0 causing
TypeError: h(): incompatible function arguments. The following argument types are supported:
    1. h(mesh: dolfinx.cpp.mesh.Mesh_float32, dim: int, entities: ndarray[dtype=int32, writable=False, shape=(*), order='C']) -> numpy.ndarray[dtype=float32, ]
    2. h(mesh: dolfinx.cpp.mesh.Mesh_float64, dim: int, entities: ndarray[dtype=int32, writable=False, shape=(*), order='C']) -> numpy.ndarray[dtype=float64, ]
Invoked with types: dolfinx.mesh.Mesh, int, range
In general I was wondering that range(num_cells) will always start from 0 on each process. However, index 0 should be on one process only if executed in parallel.
I have worked on a different solution, which in turn results in PETSC ERROR.
mesh = dolfinx.mesh.create_unit_square(MPI.COMM_WORLD, 10, 5)
local_range = mesh.topology.index_map(tdim).local_range
h = mesh.h(tdim, np.arange(local_range[0],local_range[1]))
print(f"rank {MPI.COMM_WORLD.Get_rank()} h = \n{h}")
It works in serial, but fails in parallel on all ranks >0:
[1]PETSC ERROR: ------------------------------------------------------------------------
[1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[1]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and https://petsc.org/release/faq/
[1]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
[1]PETSC ERROR: to get more information on the crash.
[1]PETSC ERROR: Run with -malloc_debug to check if memory corruption is causing the crash.
Abort(59) on node 1 (rank 1 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 59) - process 1
Another option I tried is using
h = mesh.h(tdim, mesh.topology.original_cell_index)
causing the same error on rank 0.
I am using dolfinx 0.9.0 with petsc 3.22.0 and petsc4py 3.22.0 from conda-forge.
mesh.h takes in the local cell numbering (within a process), not the global cell numbering.
See for instance Figure 8 in https://zenodo.org/records/10447666:
To fix the first error you had, change
np.arange(num_cells, dtype=np.int32)
Perfect, that’s what I needed. However,
h = dolfinx.cpp.mesh.h(mesh, tdim, np.arange(num_cells, dtype=np.int32))
still produces TypeError. Only calling h from the mesh directly works for me:
h = mesh.h(tdim, np.arange(num_cells,dtype=np.int32))
That is because this is a C++ binding, and expecting mesh._cpp_object rather than mesh.
This is the preferred wrapper that takes care of the handling of the C++ objects
