Explicitly defining the subdomains and boundaries return warning Found no facets matching domain for boundary condition
Hello everyone,
I am trying to solve for a fluid flow problem in a cylinder that is in a rectangular box (which representing solid). I define subdomains for the fluid and solid and the boundaries for both subdomains. After running the calculation, I got the warning *** Warning: Found no facets matching domain for boundary condition. and the result is ridiculously high. I suspect that the way I define the subdomians and the boundaries are the cause of the problem. Could anyone help me point out what is wrong in my subdomians and the boundaries definitions?
The following is the MWE that reproduces the warning:
# classes for subdomains
class fluid(SubDomain):
        return between(x[0], (0.0, 2.0)) and (x[1]**2 + x[2]**2) <= 0.5625
class solid(SubDomain):
        return between(x[0], (0.0, 2.0)) and (x[1]**2 + x[2]**2) >= 0.5625
# classes for boundaries
class fluid_in(SubDomain):
        return near(x[0], 0.0) and (x[1]**2 + x[2]**2) <= 0.5625
class fluid_side(SubDomain):
        return between(x[0], (0.0, 2.0)) and near(x[1]**2 + x[2]**2, 0.5625)
class fluid_out(SubDomain):
        return near(x[0], 2.0) and (x[1]**2 + x[2]**2) <= 0.5625
class solid_in(SubDomain):
        return near(x[0], 0.0) and (x[1]**2 + x[2]**2) >= 0.5625
class solid_sides(SubDomain):
        return near(x[1], 1.0) and near(x[2], -1.0) and near(x[2], 1.0)
class solid_bottom(SubDomain):
        return near(x[1], -1.0)
class solid_out(SubDomain):
        return near(x[0], 2.0) and (x[1]**2 + x[2]**2) >= 0.5625
# Varying cases
Re   = Constant(5E-1, name="Re")   #500
Pr   = Constant(100, name="Pr")    #0.01, 100
kCHT = Constant(20.0, name="kCHT") #1.0, 5.0, 20.0
# Solid properties
rhoS = Constant(1.0, name="rhoS")                  # density
cpS  = Constant(100.0, name="cpS")                 # heat capacity
cdS  = Constant(100.0, name="cdS")                 # heat conductivity
alpS = Constant(cdS/(rhoS*cpS), name="alpS")       # heat diffusivity
# Parameters for the problem
U_avg = Constant(0.1, name="U_avg")                # inlet velocity
L_ch = Constant(3.5, name="L_channel")             # length of the plate
h_ch = Constant(0.25, name="h_channel")            # half of the channel height
# Fluid properties
cdF  = Constant(cdS/kCHT, name="cdF")              # heat conductivity
rhoF = Constant(1.0, name="rhoF")                  # density
muF  = Constant(rhoF*U_avg*2*h_ch/Re, name="muF")  # dynamic viscosity
cpF  = Constant(cdF*Pr/muF, name="cpF")            # heat capacity
alpF = Constant(cdF/(rhoF*cpF), name="alpF")       # heat diffusivity
# Constant for Bcs
P_in  =  Constant(3*muF*L_ch*U_avg/(h_ch*h_ch), name="P_inlet")
P_out =  Constant(0.0, name="P_outlet")
# create mesh
mesh = BoxMesh(Point(0, -1, -1), Point(2, 1, 1), 20, 20, 20)
# Define markers for Subdomians, Dirichlet and Neuman bcs
subdomain_marker = MeshFunction("size_t", mesh, mesh.geometry().dim(), 0)
fluid().mark(subdomain_marker, 1)
solid().mark(subdomain_marker, 2)
boundary_marker = MeshFunction("size_t", mesh, mesh.geometry().dim()-1, 0)
fluid_in().mark(boundary_marker, 1)
fluid_side().mark(boundary_marker, 2)
fluid_out().mark(boundary_marker, 3)
solid_in().mark(boundary_marker, 4)
solid_sides().mark(boundary_marker, 5)
solid_bottom().mark(boundary_marker, 6)
solid_out().mark(boundary_marker, 7)
dx = Measure("dx", domain=mesh, subdomain_data=subdomain_marker)
ds = Measure("ds", domain=mesh, subdomain_data=boundary_marker)
V  = VectorElement("CG",  mesh.ufl_cell(), 2)       # Velocity
P  = FiniteElement("CG",  mesh.ufl_cell(), 1)       # Pressure
element = MixedElement([V, P])
W = FunctionSpace(mesh, element)
# Define boundary conditions for fluid problem
bc1 = DirichletBC(W.sub(0), Constant((0.0, 0.0, 0.0)), boundary_marker, 2)
bcs = [bc1]
# define trial functions and test functions
(u, p) = TrialFunctions(W)
(v, q) = TestFunctions(W)
# unit normal vector on the surfaces of the fluid mesh
# weak form for the Stroke-flow
a = muF*inner(grad(u), grad(v))*dx(1)\
    - p*div(v)*dx(1)\
    - q*div(u)*dx(1)
l = - P_in*inner(n, v)*ds(1)\
    - P_out*inner(n, v)*ds(3)
# Assembly the lhs and rhs matrices
A = assemble(a, keep_diagonal=True)
L = assemble(l)
# Apply boundary conditions
[bc.apply(A) for bc in bcs]
[bc.apply(L) for bc in bcs]
# solve for the solution
A.ident_zeros()
w = Function(W, name="fluid variables")
# solve(A, w.vector(), L)
solver_lin = LUSolver("mumps")
solver_lin.solve(A, w.vector(), L)
# Split using deep copy
(u, p) = w.split(True)
print('finish solving linear problem')
# save the fluid solution
out_u = File('workspace/dolfin-adjoint/3-D_application/results/u.pvd')
out_u << u
out_p = File('workspace/dolfin-adjoint/3-D_application/results/p.pvd')
out_p << p
Thank you very much
Your domain’s boundary probably doesn’t lie exactly on the circle of radius 0.5625. You should consider a geometry comparison tolerance.
Thank you for the hint, I have exported the subdomains and boundaries and have found that some of them are not highlighted properly.
