Warning: Found no facets matching domain for boundary condition
Hello everyone,
I am trying to solve an elasticity problem for a square domain. In my problem, the right-bottom and left-bottom corners are supported by the pin and roller supports, respectively. Also, I have fixed the displacement of the top boundary to a constant amount. After applying constant traction on the bottom boundary of the domain, I get the warning Warning: Found no facets matching domain for boundary condition.
Can you please tell me why I am getting this error? I have attached my code as below:
mesh = UnitSquareMesh(4, 4)
V = VectorFunctionSpace(mesh, "CG", 1)
def bottom(x, on_boundary):
    return x[1] > DOLFIN_EPS and on_boundary
def top(x, on_boundary):
    return x[1] > 1 - DOLFIN_EPS and on_boundary
boundary_subdomains = MeshFunction("size_t", mesh, mesh.topology().dim() - 1)
boundary_subdomains.set_all(0)
AutoSubDomain(bottom).mark(boundary_subdomains, 1)
dss = ds(subdomain_data=boundary_subdomains)
y_BC = Expression(("x[0]", "1.2*x[1]"), degree=1)
BC1 = DirichletBC(V, y_BC, top)
def pin(x):
    return x[0] < DOLFIN_EPS and x[1] < DOLFIN_EPS
def roller(x):
    return x[0]-1 < DOLFIN_EPS and x[1] < DOLFIN_EPS
BC_pin = DirichletBC(V, Constant((0, 0)), pin)
BC_roller = DirichletBC(V.sub(1), Constant(0), roller)
bcs = [BC1, BC_pin, BC_roller]
# Define functions
dy = TrialFunction(V)
v  = TestFunction(V)
y  = Function(V)
y0  = Function(V)
y_reference = Expression(("x[0]","x[1]"),degree=1)
y.assign(project(y_reference, V))  #initial guess
T  = Constant((0, -1))
def W(y):
    F = grad(y)
    C = F.T*F
    J = det(F)
    energy = 0.5*tr(C) + (J-1)**2
    return energy
# Total potential energy
Pi = W(y)*dx  - dot(T, (y - y_reference))*dss(1)
residual = derivative(Pi, y, v)
jacobian = derivative(residual, y, dy)
solve(residual == 0, y, bcs, J=jacobian)
Your help is much appreciated!
You need to specify that the corner BCs are to be applied pointwise, instead of the default behavior or applying them on entire facets:
BC_pin = DirichletBC(V, Constant((0, 0)), pin, method="pointwise")
BC_roller = DirichletBC(V.sub(1), Constant(0), roller, method="pointwise")
Thank you so much for your response. This is solving the problem for this code, but in my main code, I am using this in Dolfin-adjoint. For that, instead of last line solve(residual == 0, y, bcs, J=jacobian) , I am using these scripts:
from dolfin_adjoint import *
import moola
v = project(y, V, bcs=bcs)
J = assemble( W(y)*dx  - dot(T, (y - y_reference))*dss(1) )
J_hat = ReducedFunctional(J, Control(y))
y_opt = minimize(J_hat, method = "L-BFGS-B", options = {"gtol": 1e-6, "ftol": 1e-16, "maxfun": 30000, "maxiter": 30000, "maxls": 40})
J_hat(y_opt)
y = Function(V)
y = project (y_opt, V, bcs=bcs)
However, I am getting the error: TypeError: __init__() got an unexpected keyword argument 'method'
Is there any way to fix it? (I also installed dolfin-adjoint master branch using pip3 install git+https://github.com/dolfin-adjoint/pyadjoint.git and pip3 install git+https://github.com/dolfin-adjoint/pyadjoint.git@master , but the problem is not resolved.
Thanks for your help.
Please make a minimal example, as I cannot reproduce this with the following minimal example:
mesh = UnitSquareMesh(10, 10)
bc = DirichletBC(V, 1.0, "on_boundary", method="pointwise")
x = SpatialCoordinate(mesh)
c = Constant(2)
u = project(x[0]*c, V, bcs=[bc])
J = assemble(u**2*dx)
J_hat = ReducedFunctional(J, Control(c))
print(J_hat.derivative())
Hello Mr. Dokken, and thanks for your reply.
I tried to run your code, and I am getting the same error here. This is the output of my run:
  File "example.py", line 15, in <module>
  File "/home/fenics/.local/lib/python3.8/site-packages/fenics_adjoint/projection.py", line 24, in project
    block = ProjectBlock(args[0], args[1], output, bcs, **sb_kwargs)
  File "/home/fenics/.local/lib/python3.8/site-packages/fenics_adjoint/projection.py", line 45, in __init__
    super(ProjectBlock, self).__init__(a == L, output, bcs, *args, **kwargs)
  File "/home/fenics/.local/lib/python3.8/site-packages/fenics_adjoint/solving.py", line 76, in __init__
    self._init_dependencies(*args, **kwargs)
  File "/home/fenics/.local/lib/python3.8/site-packages/fenics_adjoint/solving.py", line 152, in _init_dependencies
    self.add_dependency(bc, no_duplicates=True)
  File "/home/fenics/.local/lib/python3.8/site-packages/pyadjoint/block.py", line 51, in add_dependency
    dep._ad_will_add_as_dependency()
  File "/home/fenics/.local/lib/python3.8/site-packages/pyadjoint/overloaded_type.py", line 365, in _ad_will_add_as_dependency
    self._ad_annotate_block()
  File "/home/fenics/.local/lib/python3.8/site-packages/pyadjoint/overloaded_type.py", line 379, in _ad_annotate_block
    block = self.block_class(*self._ad_args, **self._ad_kwargs)
Please let me know if I should check anything?
Thank you so much!
Make sure that the installed vesion of dolfin-adjoint is the actual latest version. With the following I am able to run the script from the previous post:
docker run -ti -v $PWD:/home/shared -w /home/shared --rm quay.io/fenicsproject/dev
then install pyadjoint/dolfin-adjoint as:
I would suggest removing the folder /home/fenics/.local/lib/python3.8/site-packages/fenics_adjoint and reinstalling pyadjoint.
Thanks for the reply. For installing dolfin-adjoint, I have previousely used `
git clone -b libadjoint-1.6 https://bitbucket.org/dolfin-adjoint/libadjoint , which was working with Fenics that I have installed on Ubuntu. For the new version of dolfin-adjoint (Installing pyadjoint), do I need to uninstall Fenics from Ubuntu, and install it on docker? If I need to install on docker, should I install docker on Windows or virtual Ubuntu (that I was using before for running Fenics/ dolfin-adjoint)?
Thanks a lot for the help!
Libadjoint is a very old version of dolfin-adjoint, and should definitely be uninstalled before installing a new version. You do not Need to use docker to use dolfin-adjoint, I simply use docker because it makes it easy to create new environments. Use whatever system you are used to.
Thank you so much for your great help! It solved my problem.
