Expression degree is not creating polynomial
Hello everyone,
I am trying to fit a cubic polynomial into my step function, and I have encountered a problem with expression degree. In my attached minimal code, I have an elliptical crack and for my crack vector, I am assigning the value of one when inside the crack, and zero for outside the crack.
My problem is when I use expression degree = 1 (d_initial= EllipticalCrackExpression(degree=1)), I get a step function with sharp endpoints. However, when I change the degree of expression to 3 in order to get a cubic polynomial, I am getting some oscillating crack vector with sharp points. Now, I am wondering how I can get a cubic curve that fits into my step function?
I have seen this post (How to evaluate a UserExpression on each gauss-quadrature point during assembly?), which I think has the same issue as mine. Here, as a solution, it is mentioned that we can use quadrature elements, but since I will use a variational problem, I think it might be buggy based on what has been mentioned in the response.
Thanks in advance for your great help and support
parameters["form_compiler"]["quadrature_degree"] = 5
mesh = RectangleMesh(Point(-1,-1),Point(1,1), 100, 100)
V = VectorFunctionSpace(mesh, "CG", 1)
# Expression for elliptical crack geometry
class EllipticalCrackExpression(UserExpression):
    def eval(self, value, x):
        a=0.5
        b=0.1
        A = 1.2
        a_1 = 2/((A-1)**3)
        b_1 =-(3/2) *(1+A) * a_1
        c_1= -3*a_1 -2*b_1
        d_1 = 1 - a_1 - b_1 - c_1
        if (x[0]/a)**2 + (x[1]/b)**2 <=1:
            value[0] = 0
            value[1] = 1
        elif (x[0]/a)**2 + (x[1]/b)**2 >= A:
            value[0] = 0
            value[1] = 0
            value[0] = 0
            value[1] = (a_1 *((x[0] /a)**2 + (x[1]/b)**2)**3 \
                          + b_1*((x[0] /a)**2 + (x[1]/b)**2)**2 \
                              + c_1* ((x[0] /a)**2 + ( x[1]/b)**2) + d_1)
    def value_shape(self):
        return (2,)
d = Function(V)
d_initial= EllipticalCrackExpression(degree=1) #degree=3
d=project(d_initial,V)
d.rename("d", "crack_vector")
fileD = File("Crack_vector.pvd")
fileD << d
Apologies for being lazy and not reading your post in detail.
Is your question essentially “how can I avoid Gibbs phenomenon when interpolating data to finite element spaces?”?.
Many thanks for your response. Yes, that’s my question. Also, please note that I will use a variational problem in the rest of my code.
Thanks again,
The project function internally minimizes the L2 norm between a function in V and your UserExpression, i.e., solves the linear problem of finding w\in V such that
\int_{\Omega} u \cdot v ~ d\Omega = \int_{\Omega} f \cdot v ~ d\Omega, \qquad \forall v \in V,
which I believe is the cause of your issue.
To avoid that you can simply interpolate your expression into V using:
d=interpolate(d_initial,V)
which evaluates your expression on the degrees of freedom of V. However, I cannot understand why you want to project a UserExpression of higher degree into a CG1 space (the accuracy that you get using degree=3 is lost with the projection/interpolation).
@hernan, thank you very much for your response. You are right, I should use a CG3 space. However, after I tried interpolation and space of CG3, although I am not getting the Gibbs phenomenon, I am still not getting the crack vector as a cubic curve, and its shape is very close to a degree =1 step function. Other than plotting the crack vector and visually checking that, is there any other way to make sure that the vector d is a cubic curve?
Thanks a lot for your help!
@mary_h I believe that when exporting data to vtk files, dolfin takes the nodal dofs of the output if the function belongs to a CG space.
To get a function for visualization with element-wise P3 polynomials you should try the write_checkpoint method of the XDMFFile class (see the docken answer in this post for instance).
@hernan thanks for your reply. I also tried with XDMF format, but still, I am not getting a cubic curve for the vector. I am viewing the file using Paraview, could that be a problem? If yes, can you please tell me how you are viewing your output file?
Thanks so much!
@mary_h I just edited my previous answer (you need to use the write_checkpoint function)
@hernan Thanks for your responses. Now, I am using this to save the file:
fileD = XDMFFile(“Crack_vector.xdmf”)
fileD.write_checkpoint(d, “d”, 2)
fileD.close()
But, I still don’t get the cubic curve. I even tried replacing VectorFunctionSpace by V = VectorFunctionSpace(mesh, "DG", 3) , but it is not working neither.
Is there anything else that I should try?
Thanks!
I don’t know why isn’t working. As far as I have read, write_checkpoint should work to visualize CG and DG functions of orders 1,2, and 3. Maybe the developers can give you some insights.
@hernan thanks for your response. I think my problem is solved. I had to try with a smaller domain to see the curve.
Thanks again for your great support and response.
