Extract variables and splitting from mixed function space in Dolfinx
I am trying to model a two-phase fluid system and have the problem setup in FEniCS. I’d like to re-setup the problem in Dolfinx, but am having trouble with the syntax as I’m quite new to variational formulations.
Specifically, how can I extract parameters (velocity, pressure, mass fraction) from the mixed function space, and does ufl.split work in Dolfinx?
Here is my variational setup in FEniCS:
import fenics as f
mesh = f.RectangleMesh(f.Point(0, 0), f.Point(width, height), 100, 100)
V_ele = f.VectorElement("CG", mesh.ufl_cell(), 2)
Q_ele = f.FiniteElement("CG", mesh.ufl_cell(), 1)
W = f.FunctionSpace(mesh, f.MixedElement([V_ele, Q_ele, Q_ele]))
upphi = f.Function(W)
upphi_n = f.Function(W)
vu, vp, vphi = f.TestFunctions(W)
u_l, p, phi_g = f.split(upphi)
u_l_n, p_n, phi_g_n = f.split(upphi_n)
And here is my setup so far in Dolfinx:
from dolfinx import mesh
from dolfinx.fem import Function, functionspace
# Mesh definition
width, height = 0.5, 1
nx, ny = 100, 100
domain = mesh.create_rectangle(MPI.COMM_WORLD, [[0, 0], [width, height]], [nx, ny], mesh.CellType.triangle)
# Function spaces
V = functionspace(domain, ("Lagrange", 2))
Q = functionspace(domain, ("Lagrange", 1))
W = ufl.MixedFunctionSpace(V, Q)
# Functions
upphi = Function(W)
with error message:
  File "/mnt/c/Users/ckhur/Desktop/DOLFINx/Sparging/sparge_test_v1.py", line 28, in <module>
    upphi = Function(W)
  File "/home/ckhurana/anaconda3/envs/fenicsx-env/lib/python3.13/site-packages/dolfinx/fem/function.py", line 319, in __init__
    V.element.dtype, np.dtype(dtype).type(0).real.dtype
AttributeError: 'MixedFunctionSpace' object has no attribute 'element'
Thank you!
When using mixed function spaces, you don’t define coefficient in the mixed space, but in each sub-space:
p = Function(Q)
See for instance
