How to create a MixedFunctionSpace with submesh
Dear all,
I am trying to use DolfinX to solve a problem with two different meshes.
I create the submesh from a cellmarker from gmsh.
The issue is when I try to create a function from the Mixed Function Space.
It says:
AttributeError: 'MixedFunctionSpace' object has no attribute '_cpp_object'
I cannot create a function from the space. Is this functionality not implemented in DolfinX or am I making some mistake.
Here is a MWE:
from dolfinx.fem import (Function, FunctionSpace, locate_dofs_geometrical)
from dolfinx.mesh import (create_unit_square, create_submesh,
                          locate_entities)
from ufl import (MixedFunctionSpace, FiniteElement)
def subdomain(x):
    return x[1] >= 0.5
cells_subdomain = locate_entities(mesh, mesh.topology.dim, subdomain)
submesh, vertex_map, geom_map = (mesh, mesh.topology.dim, cells_subdomain)
P1_mesh = FiniteElement("Lagrange", submesh.ufl_cell(), 1)
P1_submesh = FiniteElement("Lagrange", mesh.ufl_cell(), 1)
V_mesh = FunctionSpace(mesh, P1_mesh)
V_submesh = FunctionSpace(submesh, P1_submesh)
V = MixedFunctionSpace(V_mesh, V_submesh)
Than you so much for your help!
All the best
You may want to use GitHub - multiphenics/multiphenicsx: multiphenicsx - easy prototyping of multiphysics problems in FEniCSx (disclaimer: I am the author of that), or ping @jpdean if any of his branches are helpful for this case.
As Francesco mentioned, this is possible with the branches of FEniCSx I’ve been working on. If you are interested, please checkout GitHub - jpdean/mixed_domain_demos. However, this functionality is still a work in progress and has not yet been merged into main, so Multiphenicsx might be the better option for you.
Thanks,
Joe
Dear Francesco,
Thank you so much for your fast response!
I tried to study a bit multiphenicsx and also jpdean implementation of mixed element problems.
Unfortunately my background on applied math is not that vast.
Thus, I’d like to ask you some help.
On the MWE that I described on the post that I made, I was trying to create a Function Space that comprised both a variable defined on the whole domain, and a second one which was only defined on a subdomain. I was looking to implement on FEniCSx something that was closer to what was proposed on the latest development version of FEniCS and bumped on the fact that this is not available yet.
From what I understood, on your very nice tutorials of multiphenicsx, the proposed solution would be to create the subspaces and “bind” them through a mapping of the DOF’s. Then, create a newton solver object that could solve the problem.
Is that right?
Thank you so much!
All the best,
Murilo
Yeah. The technical description would be much more complicated, but basically if you look at multiphenicsx/tutorial_lagrange_multipliers_interface.ipynb at main · multiphenics/multiphenicsx · GitHub the key cell in that respect is
dofs_V1_Omega1 = dolfinx.fem.locate_dofs_topological(V1, subdomains.dim, cells_Omega1)
dofs_V2_Omega2 = dolfinx.fem.locate_dofs_topological(V2, subdomains.dim, cells_Omega2)
dofs_M_Gamma = dolfinx.fem.locate_dofs_topological(M, boundaries.dim, facets_Gamma)
restriction_V1_Omega1 = multiphenicsx.fem.DofMapRestriction(V1.dofmap, dofs_V1_Omega1)
restriction_V2_Omega2 = multiphenicsx.fem.DofMapRestriction(V2.dofmap, dofs_V2_Omega2)
restriction_M_Gamma = multiphenicsx.fem.DofMapRestriction(M.dofmap, dofs_M_Gamma)
restriction = [restriction_V1_Omega1, restriction_V2_Omega2, restriction_M_Gamma]
which enables multiphenicsx to determine which dofs are part of subdomain 1, subdomain 2 and interface, respectively.
Hello Francescon,
I took a look at this page in your tutorial (tutorial_block_poisson) and this one (tutorial_navier_stokes). It looks you developed a package based on fenicsx to solve a coupled system of equations. Is this one application of your package? I am looking for a way to impose two coupled equation and solve the nonlinear system simultaneously in fenicsx. It looks your package is exactly what I am looking for and your tutorial contains a lot of resouces including the implementation by just using fenicsx and also by using your package. Am I correct? Thanks!
Yes, that is correct. I imagine that your equations involve restricting unknowns to some subdomain: in that case, please have a look at the third tutorial too.
Right! Thank you very much!
Hi @jpdean, I have been trying to run your script buoyancy_driven_flow.py with the docker image dolfinx/dolfinx:v0.9.0. Is it not working, or are you using a different version of the code?
I’ve been trying to do this
# create mesh and submesh above...
V1 = dolfinx.fem.functionspace(mesh, ("Lagrange", 1))
V2 = dolfinx.fem.functionspace(submesh, ("Lagrange", 1))
W = ufl.MixedFunctionSpace(V1, V2)
wh = dolfinx.fem.Function(W)
# solve nonlinear problem
and am looking for a workaround. Looks like the same error occurs in this post: Applying ufl.action when using ufl.MixedFunctionSpace
Applying action to mixedfunctionspace problems is currently not supported.
See for instance Coupling PDEs of multiple dimensions — FEniCS Workshop for an example with mixed functionspace and submeshes.
A step towards this is getting: Extract lhs and rhs from `MixedFunctionSpace` by jorgensd · Pull Request #350 · FEniCS/ufl · GitHub
merged, as it will allow for ufl.system, ufl.rhs and ufl.lhs on forms with MixedFunctionSpace.
Edit:
Follow-up PR using ufl.action on MixedFunctionSpace is available at: Add `ufl.action` for MixedFunctionSpace by jorgensd · Pull Request #351 · FEniCS/ufl · GitHub
Hi!
Sorry, I had to update the demos past 0.9 because of a bug (which has now been fixed in main), and I forgot to update the readme.
Once the next version of DOLFINx has been released, I’ll update and tidy up the demos and then start tagging for each release. In the time being, it should work with main.
