@dokken
Thanks for your response. The belwoMWE show how, the [Biharmonic example solution]
(Biharmonic equation — DOLFINx 0.9.0 documentation) is compared with created normal vector from facet vector approx. . The final results fails to match. Can you provide how fact vector created normal gives same solution as FacetNormal(mesh).
import importlib.util
import basix
from dolfinx.fem.petsc import LinearProblem, assemble_matrix
from dolfinx.mesh import CellType, GhostMode
from ufl import CellDiameter, FacetNormal, avg, div, dS, dx, grad, inner, jump, pi, sin
import basix.ufl
import dolfinx as dfx
msh = mesh.create_rectangle(
comm=MPI.COMM_WORLD,
points=((0.0, 0.0), (1.0, 1.0)),
n=(2, 2),
cell_type=CellType.triangle,
ghost_mode=GhostMode.shared_facet,
V = fem.functionspace(msh, ("Lagrange", 2))
tdim = msh.topology.dim
msh.topology.create_connectivity(tdim - 1, tdim)
facets = mesh.exterior_facet_indices(msh.topology)
dofs = fem.locate_dofs_topological(V=V, entity_dim=1, entities=facets)
bc = fem.dirichletbc(value=0.0, dofs=dofs, V=V)
alpha = 8.0
h = CellDiameter(msh)
n = FacetNormal(msh)
h_avg = (h("+") + h("-")) / 2.0
###################### Copied Code ####################################
def tangential_projection(u: ufl.Coefficient, n: ufl.FacetNormal) -> ufl.Coefficient:
return (ufl.Identity(u.ufl_shape[0]) - ufl.outer(n, n)) * u
def facet_vector_approximation(V: dfx.fem.FunctionSpace,
mt: dfx.mesh.MeshTags | None = None,
mt_id: int | None = None,
tangent: bool = False,
interior: bool = False,
jit_options: dict | None = None,
form_compiler_options: dict | None = None) -> dfx.fem.Function:
jit_options = jit_options if jit_options is not None else {}
form_compiler_options = form_compiler_options if form_compiler_options is not None else {}
comm = V.mesh.comm # MPI Communicator
n = ufl.FacetNormal(V.mesh) # UFL representation of mesh facet normal
u, v = ufl.TrialFunction(V), ufl.TestFunction(V) # Trial and test functions
# Define integral measure
if interior:
# Create interior facet integral measure
dS = ufl.dS(domain=V.mesh) if mt is None else ufl.dS(domain=V.mesh, subdomain_data=mt, subdomain_id=mt_id)
# Create exterior facet integral measure
ds = ufl.ds(domain=V.mesh) if mt is None else ufl.ds(domain=V.mesh, subdomain_data=mt, subdomain_id=mt_id)
# If tangent==True, the right-hand side of the problem should be a tangential projection of the facet normal vector.
if tangent:
if V.mesh.geometry.dim == 2:
if interior:
a = (ufl.inner(u('+'), v('+')) + ufl.inner(u('-'), v('-'))) * dS
L = ufl.inner(ufl.as_vector([-n('+')[1], n('+')[0]]), v('+')) * dS \
+ ufl.inner(ufl.as_vector([-n('-')[1], n('-')[0]]), v('-')) * dS
a = ufl.inner(u, v) * ds
L = ufl.inner(ufl.as_vector([-n[1], n[0]]), v) * ds
c = dfx.fem.Constant(V.mesh, (1.0, 1.0, 1.0)) # Vector to tangentially project the facet normal vectors on
if interior:
L = ufl.inner(tangential_projection(c, n('+')), v('+')) * dS \
+ ufl.inner(tangential_projection(c, n('-')), v('-')) * dS
L = ufl.inner(tangential_projection(c, n), v) * ds
# If tangent==false the right-hand side is simply the facet normal vector.
if interior:
L = (ufl.inner(n('+'), v('+')) + ufl.inner(n('-'), v('-'))) * dS
L = ufl.inner(n, v) * ds
# Find all boundary dofs, which are the dofs where we want to solve for the facet vector approximation.
# Start by assembling test functions integrated over the boundary integral measure.
ones = dfx.fem.Constant(V.mesh, dfx.default_scalar_type((1,) * V.mesh.geometry.dim)) # A vector of ones
if interior:
local_val = dfx.fem.form((ufl.dot(ones, v('+')) + ufl.dot(ones, v('-')))*dS)
local_val = dfx.fem.form(ufl.dot(ones, ufl.TestFunction(V))*ds)
local_vec = dfx.fem.assemble_vector(local_val)
# For the dofs that do not lie on the boundary of the mesh the assembled vector has value zero.
# Extract these dofs and use them to deactivate the corresponding block in the linear system we will solve.
bdry_dofs_zero_val = np.flatnonzero(np.isclose(local_vec.array, 0))
deac_blocks = np.unique(bdry_dofs_zero_val // V.dofmap.bs).astype(np.int32)
# Create sparsity pattern by manipulating the blocks to be deactivated and set
# a zero Dirichlet boundary condition for these dofs.
bilinear_form = dfx.fem.form(a, jit_options=jit_options,
form_compiler_options=form_compiler_options)
pattern = dfx.fem.create_sparsity_pattern(bilinear_form)
pattern.insert_diagonal(deac_blocks)
pattern.finalize()
u_0 = dfx.fem.Function(V)
u_0.vector.set(0)
bc_deac = dfx.fem.dirichletbc(u_0, deac_blocks)
# Create the matrix
A = dfx.cpp.la.petsc.create_matrix(comm, pattern)
A.zeroEntries()
# Assemble the matrix with all entries
form_coeffs = dfx.cpp.fem.pack_coefficients(bilinear_form._cpp_object)
form_consts = dfx.cpp.fem.pack_constants(bilinear_form._cpp_object)
dfx.fem.petsc.assemble_matrix(A, bilinear_form, constants=form_consts, coeffs=form_coeffs, bcs=[bc_deac])
# Insert the diagonal with the deactivated blocks.
if bilinear_form.function_spaces[0] is bilinear_form.function_spaces[1]:
A.assemblyBegin(PETSc.Mat.AssemblyType.FLUSH)
A.assemblyEnd(PETSc.Mat.AssemblyType.FLUSH)
dfx.cpp.fem.petsc.insert_diagonal(A=A, V=bilinear_form.function_spaces[0], bcs=[bc_deac._cpp_object], diagonal=1.0)
# Assemble the linear form and the right-hand side vector.
linear_form = dfx.fem.form(L, jit_options=jit_options,
b = dfx.fem.petsc.assemble_vector(linear_form)
# Apply lifting to the right-hand side vector and set boundary conditions.
dfx.fem.petsc.apply_lifting(b, [bilinear_form], [[bc_deac]])
dfx.fem.petsc.set_bc(b, [bc_deac])
# Setup a linear solver using the Conjugate Gradient method.
solver = PETSc.KSP().create(MPI.COMM_WORLD)
solver.setType("cg")
solver.rtol = 1e-8
solver.setOperators(A)
# Solve the linear system and perform ghost update.
nh = dfx.fem.Function(V) # Function for the facet vector approximation
solver.solve(b, nh.vector)
nh.vector.ghostUpdate(addv=PETSc.InsertMode.INSERT, mode=PETSc.ScatterMode.FORWARD)
# Normalize the vectors to get the unit facet normal/tangent vector.
nh_norm = ufl.sqrt(ufl.inner(nh, nh)) # Norm of facet vector
cond_norm = ufl.conditional(ufl.gt(nh_norm, 1e-10), nh_norm, 1.0) # Avoid division by zero
if V.mesh.geometry.dim == 1:
nh_norm_vec = ufl.as_vector((nh[0]/cond_norm))
elif V.mesh.geometry.dim == 2:
nh_norm_vec = ufl.as_vector((nh[0]/cond_norm, nh[1]/cond_norm))
elif V.mesh.geometry.dim == 3:
nh_norm_vec = ufl.as_vector((nh[0]/cond_norm, nh[1]/cond_norm, nh[2]/cond_norm))
nh_normalized = dfx.fem.Expression(nh_norm_vec, V.element.interpolation_points())
n_out = dfx.fem.Function(V)
n_out.interpolate(nh_normalized)
return n_out
DEFAULT=2
SUBSET=3
mesh=msh
mesh.topology.create_entities(mesh.topology.dim-1)
# Create an array facet_marker which contains the facet marker value for all facets in the mesh.
facet_dim = mesh.topology.dim-1 # Topological dimension of facets
num_facets = mesh.topology.index_map(facet_dim).size_local + mesh.topology.index_map(facet_dim).num_ghosts # Total number of facets in mesh
facet_marker = np.full(num_facets, DEFAULT, dtype=np.int32) # Default facet marker value is 2
# Find the subset of facets to be marked.
boundary_facets = dolfinx.mesh.locate_entities_boundary(
mesh, 1, lambda x: np.full(x.shape[1], True, dtype=bool)) # Boundary mesh afcets
facets_ids = dolfinx.mesh.locate_entities(
mesh, 1, lambda x: np.full(x.shape[1], True, dtype=bool)) # total mesh facets
facets_int=np.setdiff1d(facets_ids,boundary_facets ) #Interior mesh facets
# subset_facets = dfx.mesh.locate_entities(mesh, facet_dim, locator) # Get subset of facets to be marked
facet_marker[facets_int] = SUBSET # Fill facet marker array with the value SUBSET
facet_tags = dfx.mesh.meshtags(mesh, facet_dim, np.arange(num_facets, dtype=np.int32), facet_marker) # Create facet meshtags
ft_id = SUBSET # Set the meshtags id for which we will approximate the facet vectors
# Create a DG1 space for the facet vectors to be approximated.
DG1 = basix.ufl.element(family="Lagrange", cell=mesh.basix_cell(), degree=1, discontinuous=True, shape=(mesh.geometry.dim,))
space = dfx.fem.functionspace(mesh=mesh, element=DG1)
# Computed facet vector approximation.
nn= facet_vector_approximation(V=space, mt=facet_tags, mt_id=ft_id, interior=True, tangent=False)
############COPIED CODE ENDS ###########################
u = ufl.TrialFunction(V)
f = 4.0 * pi**4 * sin(pi * x[0]) * sin(pi * x[1])
a_FacetNormal = (
inner(div(grad(u)), div(grad(v))) * dx
- inner(avg(div(grad(u))), jump(grad(v), n)) * dS
- inner(jump(grad(u), n), avg(div(grad(v)))) * dS
+ alpha / h_avg * inner(jump(grad(u), n), jump(grad(v), n)) * dS
a_Created_FacetNormal = (
- inner(avg(div(grad(u))), jump(grad(v), nn)) * dS
- inner(jump(grad(u), nn), avg(div(grad(v)))) * dS
+ alpha / h_avg * inner(jump(grad(u), nn), jump(grad(v), nn)) * dS
L = inner(f, v) * dx
problem_1 = LinearProblem(a_FacetNormal, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh_1 = problem_1.solve()
print('Biharmonic Sol: Using n=FacetNormal(msh)\n')
print(uh_1.vector[:])
problem_2 = LinearProblem(a_Created_FacetNormal, L, bcs=[bc], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
uh_2 = problem_2.solve()
print('\n Biharmonic Sol: Using nn=facet normal approximation \n')
print(uh_2.vector[:])
I apologize for length of problem, but majority of code is taken directly from facet vector approx.
