Facing error while calculating dynamic parameter of structure
I am extending modal analysis code for calculating X^T*M*T with fenics. Here X^T is transpose of eigen vector/mode shape matrix, M is the mass matrix, T is the influence direction vector. I am facing some error.
L, B, H = 20., 0.5, 1.
Nx = 200
Ny = int(B/L*Nx)+1
Nz = int(H/L*Nx)+1
mesh = BoxMesh(Point(0.,0.,0.),Point(L,B,H), Nx, Ny, Nz)
E, nu = Constant(1e5), Constant(0.)
rho = Constant(1e-3)
# Lame coefficient for constitutive relation
mu = E/2./(1+nu)
lmbda = E*nu/(1+nu)/(1-2*nu)
def eps(v):
    return sym(grad(v))
def sigma(v):
    dim = v.geometric_dimension()
    return 2.0*mu*eps(v) + lmbda*tr(eps(v))*Identity(dim)
V = VectorFunctionSpace(mesh, 'Lagrange', degree=1)
u_ = TrialFunction(V)
du = TestFunction(V)
def left(x, on_boundary):
    return near(x[0],0.)
bc = DirichletBC(V, Constant((0.,0.,0.)), left)
k_form = inner(sigma(du),eps(u_))*dx
l_form = Constant(1.)*u_[0]*dx
K = PETScMatrix()
b = PETScVector()
assemble_system(k_form, l_form, bc, A_tensor=K, b_tensor=b)
m_form = rho*dot(du,u_)*dx
M = PETScMatrix()
assemble(m_form, tensor=M)
eigensolver = SLEPcEigenSolver(K, M)
eigensolver.parameters['problem_type'] = 'gen_hermitian'
eigensolver.parameters['spectral_transform'] = 'shift-and-invert'
eigensolver.parameters['spectral_shift'] = 0.
N_eig = 6   # number of eigenvalues
print("Computing {} first eigenvalues...".format(N_eig))
eigensolver.solve(N_eig)
# Exact solution computation
from scipy.optimize import root
from math import cos, cosh
falpha = lambda x: cos(x)*cosh(x)+1
alpha = lambda n: root(falpha, (2*n+1)*pi/2.)['x'][0]
# Set up file for exporting results
file_results = XDMFFile("modal_analysis.xdmf")
eig_l = []
eigenmodes = []
# Extraction
for i in range(N_eig):
    # Extract eigenpair
    r, c, rx, cx = eigensolver.get_eigenpair(i)
    # 3D eigenfrequency
    freq_3D = sqrt(r)/2/pi
    # Beam eigenfrequency
    if i % 2 == 0: # exact solution should correspond to weak axis bending
        I_bend = H*B**3/12.
    else:          #exact solution should correspond to strong axis bending
        I_bend = B*H**3/12.
    freq_beam = alpha(i/2)**2*sqrt(float(E)*I_bend/(float(rho)*B*H*L**4))/2/pi
    print("Solid FE: {:8.5f} [Hz]   Beam theory: {:8.5f} [Hz]".format(freq_3D, freq_beam))
    # Initialize function and assign eigenvector
    eigenmode = Function(V,name="Eigenvector "+str(i))
    eigenmode.vector()[:] = rx
    eigenmodes.append(eigenmode)
    eig_l.append(freq_3D)
u.interpolate(Constant((0, 1, 0)))
combined_mass = 0
q = assemble(action(action(eigenmodes.T, m_form), u))
here eigenmodes.T should be the transpose of eigen vector/mode shape matrix.
See the syntax of action https://fenicsproject.org/olddocs/ufl/1.5.0/ufl.html#ufl.formoperators.action
the correct expression is
action(action(m_form, eigenmodes[i]), u)
or equivalently since m_form is symmetric
action(action(m_form, u), eigenmodes[i])
note that eigenmodes is a list so you need to do your computation one eigenmode after the other
Sir, I am new to fenics. Can you pleasee tell what to do for getting X^T∗M∗T. I need to multiply the transpose of entire eigenmode matrix with m_form and u.
Your so called X^T\cdot M\cdot T is a vector. each
assemble(action(action(m_form, eigenmodes[i]), u))
gives you the i-th component of this vector
sir it is having all modes in one matrix
