Hi Everyone
This is the exact solution "y_exact = curl(sin(pixy)) ". How can I define it FeniCS in a 2d domain ?
Hi Everyone
First of all, you need to specify what version of fenics you are using, ie. Legacy dolfin or dolfinx + version number.
Secondly, what is the curl of a scalar value?
Fenics version: 2019.2.0.dev0
y_exact = curl(sin(pixy)) is a vector valued function or approximated with P2 Lagrange polnomial
You cannot take a curl of a scalar function. sin(pi*x*y) is a scalar value, and the curl(a) where a is a scalar value is not defined. Are you sure you mean the curl and not the gradient or divergence?
You would need to define what the curl operator is supposed to do on a scalar value, as I do not know a scalar function called curl. See: Curl (mathematics) - Wikipedia and: https://www.quora.com/What-is-the-curl-of-a-scalar
