Failed to split a vector
Hi, I tried to split a vector created by ufl.nabla_grad into its components but I failed to get the correct shape. I’m providing a minimal work example that’s adapted from the tutorial:
from dolfinx import mesh
from dolfinx import fem
domain = mesh.create_unit_square(MPI.COMM_WORLD, 8, 8, mesh.CellType.quadrilateral)
V = fem.FunctionSpace(domain, ("Lagrange", 1))
uD = fem.Function(V)
uD.interpolate(lambda x: 1 + x[0]**2 + 2 * x[1]**2)
tdim = domain.topology.dim
fdim = tdim - 1
boundary_dofs = fem.locate_dofs_topological(V, fdim, boundary_facets)
bc = fem.dirichletbc(uD, boundary_dofs)
u = ufl.TrialFunction(V)
default_scalar_type = PETSc.ScalarType
f = fem.Constant(domain, default_scalar_type(-6))
a = ufl.dot(ufl.grad(u), ufl.grad(v)) * ufl.dx
L = f * v * ufl.dx
uh = problem.solve()
# solve nabla_uh
grad_uh = ufl.nabla_grad(uh)
V_ = fem.VectorFunctionSpace(domain, ("Lagrange", 1))
dx_ = ufl.dx(V_.mesh)
u_ = ufl.TrialFunction(V_)
v_ = ufl.TestFunction(V_)
a_ = ufl.inner(u_,v_) * dx_
L_ =  ufl.inner(grad_uh,v_) * dx_
problem = fem.petsc.LinearProblem(a_, L_, bcs=[], petsc_options={"ksp_type": "preonly", "pc_type": "lu"})
grad_uh_value = problem.solve()
grad_uh_x, grad_uh_y = grad_uh_value.split()
print(uh.x.array.shape, grad_uh_value.x.array.shape, grad_uh_y.x.array.shape)
uh.x.array.shape gives (81,), and grad_uh_value.x.array.shape gives (162,) these are expected. However, grad_uh_x.x.array.shape also gives (162,) but I was expecting it to be (81,). Anyone knows how I can split the grad_uh_value correctly? Thanks
Read Read before posting: How do I get my question answered?. The code you posted is not reproducible, hence it’s unlikely anyone will be able to help.
Hi Francesco, thanks for the reply and sorry for making these confusions. I have provided code adapted from the fenicsx tutorial (and I confirm it can be run on my computer) and edited my question. Can you please take a look again? Thanks a lot
Hi.
When working with mixed formulations, like VectorFunctionSpace, you need to collapse the functions (see for example Meaning of .collapse() or here):
Taking
grad_uh_x=grad_uh_x.collapse()
grad_uh_y=grad_uh_y.collapse()
gives
(81,) (162,) (81,)
as expected.
Cheers.
