fem.Function vs ufl.TrialFunctions
Hi all,
I’m defining a mixed function space in the following:
element_mix = ufl.MixedElement(element_u, element_p)
V = fem.FunctionSpace(domain, element_mix)
When I define the trial function for displacement and pressure fields:
(1)
state = fem.Function(V, name='state')
u, p = ufl.split(state)
(2)
u, p = ufl.TrialFunctions(V)
Which one is correct? What’s the difference between them?
Thanks
This depends on how you want to set up your system.
A TestFunction and a TrialFunction are both arguments, instructing UFL what kind of object that you would like to assemble.
If you have no test or trial function in a variational form, the resulting assembled object will be a scalar value.
If you have either a test or a trial function in your variational form, the assembled result will be a vector.
If you have both a test and trial function in your variational form, the result will be a matrix.
This is for instance described at: Form language — Unified Form Language (UFL) 2021.1.0 documentation
If you solve a non-linear problem, it is common to define the residual of the variational form F(u,v)=0 and then differentiate it to get the linearized Jacobian (for instance described at: Custom Newton solvers — FEniCSx tutorial). Then you would use a dolfinx.fem.Function, and not a ufl.TrialFunction to define the “unknown” in your form.
Thanks a lot dokken for your clear explanation!
