I am new to Fenics and I have a Problem which I tried to solve the last days on my own but I didn’t managed.
I have a very basic example: a Neo-Hook Material Law for the calculation of sigma and I want to implement the momentum balance.
When I define u - the displacement, as a TrialFunction I get the error in the Titel, If I define it as a normal Function it works.
I have read, that you can’t use TrialFunctions for Non-Linear Problems is this also the Problem here?
I want to couple this equation in the next step with another equation and therefore want to use a mixed space which (In my understanding at least) works best if you define the Functions you use there like u,p = TrialFunctions(Name of the Space)
So it would be great if I could use the TrialFunction for the Definition of my Deformation Gradient. Is there a way to do this?
I run Fenics on ubuntu.
Thank you for you help in advanced!
Here is my code:
(the complete error message is at the end)
from future import print_function
from fenics import *Elasticity parameters
E, nu = 220, 0.45 # E in kPa
mu = Constant(E/(2*(1 + nu)))
lam = Constant(Enu/( (1+nu)(1-2*nu)))
nu = Constant(nu)
Create mesh and define function space
mesh = UnitSquareMesh(16, 16)
V = VectorFunctionSpace(mesh, ‘P’, 2)Mark boundary subdomians
left = ‘near(x[0], 0)’
bcu = DirichletBC(V, Constant((0, 0)), left)Define variational problem
d = u.geometric_dimension() # space dimension
t = Constant((0, 10))Define strain and stress
I = Identity(d)
F = I + nabla_grad(u) # Deformation Gradient
C_inv = inv(C) # Inverse of Right Cauchy-Green tensor
J = det(F)def sigma(u):
return (1/J)*mu*I -mu*pow(pow(J,2),-nu/(1-2*nu) )*C_inv*F.TL = inner(sigma(u), nabla_grad(v))*dx - dot(t, v)*ds
Compute solution
solve(L == 0, u, bcu)Plot solution
plot(u, title=‘Displacement’, mode=‘displacement’)
Error Message:
No Jacobian form specified for nonlinear variational problem.
Differentiating residual form F to obtain Jacobian J = F’.
File “/home/johannes/Desktop/Beleg/mechanik_v2_1.py”, line 38, in
File “/usr/lib/python3/dist-packages/dolfin/fem/solving.py”, line 220, in solve
File “/usr/lib/python3/dist-packages/dolfin/fem/solving.py”, line 261, in _solve_varproblem
form_compiler_parameters=form_compiler_parameters)
File “/usr/lib/python3/dist-packages/dolfin/fem/problem.py”, line 90, in init
F = Form(F, form_compiler_parameters=form_compiler_parameters)
File “/usr/lib/python3/dist-packages/dolfin/fem/form.py”, line 44, in init
mpi_comm=mesh.mpi_comm())
File “/usr/lib/python3/dist-packages/dolfin/jit/jit.py”, line 47, in mpi_jit
File “/usr/lib/python3/dist-packages/dolfin/jit/jit.py”, line 97, in ffc_jit
File “/usr/lib/python3/dist-packages/ffc/jitcompiler.py”, line 217, in jit
module = jit_build(ufl_object, module_name, parameters)
File “/usr/lib/python3/dist-packages/ffc/jitcompiler.py”, line 133, in jit_build
generate=jit_generate)
File “/usr/lib/python3/dist-packages/dijitso/jit.py”, line 165, in jit
header, source, dependencies = generate(jitable, name, signature, params[“generator”])
File “/usr/lib/python3/dist-packages/ffc/jitcompiler.py”, line 66, in jit_generate
prefix=module_name, parameters=parameters, jit=True)
File “/usr/lib/python3/dist-packages/ffc/compiler.py”, line 143, in compile_form
prefix, parameters, jit)
File “/usr/lib/python3/dist-packages/ffc/compiler.py”, line 185, in compile_ufl_objects
analysis = analyze_ufl_objects(ufl_objects, kind, parameters)
File “/usr/lib/python3/dist-packages/ffc/analysis.py”, line 90, in analyze_ufl_objects
for form in forms)
for form in forms)
File “/usr/lib/python3/dist-packages/ffc/analysis.py”, line 174, in _analyze_form
do_apply_restrictions=True)
File “/usr/lib/python3/dist-packages/ufl/algorithms/compute_form_data.py”, line 418, in compute_form_data
check_form_arity(preprocessed_form, self.original_form.arguments(), complex_mode) # Currently testing how fast this is
File “/usr/lib/python3/dist-packages/ufl/algorithms/check_arities.py”, line 177, in check_form_arity
check_integrand_arity(itg.integrand(), arguments, complex_mode)
File “/usr/lib/python3/dist-packages/ufl/algorithms/check_arities.py”, line 159, in check_integrand_arity
arg_tuples = map_expr_dag(rules, expr, compress=False)
File “/usr/lib/python3/dist-packages/ufl/corealg/map_dag.py”, line 37, in map_expr_dag
result, = map_expr_dags(function, [expression], compress=compress)
File “/usr/lib/python3/dist-packages/ufl/corealg/map_dag.py”, line 86, in map_expr_dags
r = handlers[v.ufl_typecode](v, *[vcache[u] for u in v.ufl_operands])
File “/usr/lib/python3/dist-packages/ufl/algorithms/check_arities.py”, line 48, in sum
raise ArityMismatch(“Adding expressions with non-matching form arguments {0} vs {1}.”.format(_afmt(a), _afmt(b)))
ufl.algorithms.check_arities.ArityMismatch: Adding expressions with non-matching form arguments () vs (‘v_1’,).
