Hi everyone
I am using Fenics 2018.1.0 installed via Anaconda. However, this version does not have MPI-enabled HDF5. I also so use XML format but I get some issues such as Fenics can not read GMSH tag files, i.e.
domains = MeshFunction(“size_t”, mesh, “mesh_name_physical_region.xml”)
boundaries = MeshFunction(“size_t”, mesh, “mesh_name_facet_region.xml”)
Do you have any idea?
Thanks
Best regards
